[OWSLib-devel] [owslib-users] Bug in owslib?
Cinquini, Luca (3980) Luca.Cinquini at jpl.nasa.gov
Mon Sep 16 13:04:49 PDT 2013
Hi Chris,
I fixed the bug changing "LiteralData" to "LiteralOutput" when parsing the WPS output, all tests pass.
thanks again for reporting it,
Luca
On Sep 10, 2013, at 5:18 AM, Christopher Eykamp wrote:
Hi Luca,
Yes, of course I can.  My main goal in contacting you was 1) to make sure my local modification was correct, and 2) alert you to the issue.
Both of those goals have now been achieved.
Thanks!
Chris
PS Would you please let me know when you do push the updated code, so I know when it is safe to delete my local patch file.
On 2013-09-09 23:42, Cinquini, Luca (3980) wrote:
Hi Chris,
ok - I think you are right: when parsing the output, the element is called "LiteralOutput" and not "LiteralData".
I can make the change in the Git repo (any objections ?), although I just realized that a few tests are already not working, and it would be good to fix them before I make any changes. Can you work with a modified local copy for the time being ?
thanks for reporting this,
Luca
On Sep 9, 2013, at 6:56 AM, Christopher Eykamp wrote:
Hi Luca,
Thank you for your reply.  First off, you are right that I meant DescribeProcess.  My mind is ajumble with WxS soup.  It's easy to get mixed up!
I have a test service, implemented in pyWPS.  If I make the following request:
http://wps.iguess.tudor.lu/cgi-bin/pywps.cgi?SERVICE=WPS&VERSION=1.0.0&REQUEST=DescribeProcess&identifier=test_rand_map
I get back the following XML (excerpted):
<Output>
<ows:Identifier>num</ows:Identifier>
<ows:Title>A sample literal output.</ows:Title>
<LiteralOutput>
<ows:DataType ows:reference="http://www.w3.org/TR/xmlschema-2/#integer"<http://www.w3.org/TR/xmlschema-2/#integer>>integer</ows:DataType>
</LiteralOutput>
</Output>
A copy of the full output is available here:
http://pastebin.com/JFB603TD
This would suggest either a problem with pyWPS or owslib.
Chris
On 2013-09-07 00:32, Cinquini, Luca (3980) wrote:
Hi Chris,
        it's been a while since I used the WPS client, so I might be totally wrong here, but...
First of all, are you referring to the output of a WPS DescribeProcess request (not "DescribeCoverage") ? If so, I think the output contains "LiteralData" elements, not "LiteralOutput", for example you can run the following request straight out of the OWSlib package (see below). I don't see any "LiteralOutput" tag... But off course I could be wrong, in which case can you send an example request and response ?
thanks a lot,
Luca
brelay5:examples cinquini$ python wps-client.py -u http://rsg.pml.ac.uk/wps/vector.cgi -r DescribeProcess -i v.mkgrid -v
ARGV      : ['-u', 'http://rsg.pml.ac.uk/wps/vector.cgi', '-r', 'DescribeProcess', '-i', 'v.mkgrid', '-v']
OPTIONS   : [('-u', 'http://rsg.pml.ac.uk/wps/vector.cgi'), ('-r', 'DescribeProcess'), ('-i', 'v.mkgrid'), ('-v', '')]
http://rsg.pml.ac.uk/wps/vector.cgi?identifier=v.mkgrid&version=1.0.0&request=DescribeProcess&service=WPS
<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
<ns0:ProcessDescriptions xmlns:ns0="http://www.opengis.net/wps/1.0.0"<http://www.opengis.net/wps/1.0.0> xmlns:ows="http://www.opengis.net/ows/1.1"<http://www.opengis.net/ows/1.1> xmlns:xlink="http://www.w3.org/1999/xlink"<http://www.w3.org/1999/xlink> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"<http://www.w3.org/2001/XMLSchema-instance> service="WPS" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsDescribeProcess_response.xsd"<http://www.opengis.net/wps/1.0.0http://schemas.opengis.net/wps/1.0.0/wpsDescribeProcess_response.xsd> xml:lang="en-CA">
    <ProcessDescription statusSupported="true" storeSupported="true" ns0:processVersion="1">
        <ows:Identifier>v.mkgrid</ows:Identifier>
        <ows:Title>Creates a vector map of a user-defined grid.</ows:Title>
        <ows:Abstract>http://grass.osgeo.org/grass70/manuals/html70_user/v.mkgrid.html</ows:Abstract>
        <ows:Metadata xlink:href="http://earthserver.pml.ac.uk/wps/vector.cgi?service=WPS&request=DescribeProcess&version=1.0.0&identifier=v.mkgrid"<http://earthserver.pml.ac.uk/wps/vector.cgi?service=WPS&request=DescribeProcess&version=1.0.0&identifier=v.mkgrid> xlink:title="vector" />
        <ows:Metadata xlink:href="http://earthserver.pml.ac.uk/wps/vector.cgi?service=WPS&request=DescribeProcess&version=1.0.0&identifier=v.mkgrid"<http://earthserver.pml.ac.uk/wps/vector.cgi?service=WPS&request=DescribeProcess&version=1.0.0&identifier=v.mkgrid> xlink:title="geometry" />
        <DataInputs>
            <Input maxOccurs="2" minOccurs="0">
                <ows:Identifier>box</ows:Identifier>
                <ows:Title>Width and height of boxes in grid</ows:Title>
                <LiteralData>
                    <ows:DataType ows:reference="http://www.w3.org/TR/xmlschema-2/#float"<http://www.w3.org/TR/xmlschema-2/#float>>float</ows:DataType>
                    <ows:AnyValue />
                </LiteralData>
            </Input>
                <ows:Identifier>coor</ows:Identifier>
                <ows:Title>Lower left easting and northing coordinates of map</ows:Title>
                <LiteralData>
                    <ows:AnyValue />
                </LiteralData>
            </Input>
            <Input maxOccurs="1" minOccurs="0">
                <ows:Identifier>angle</ows:Identifier>
                <ows:Title>Angle of rotation (in degrees counter-clockwise)</ows:Title>
                <LiteralData>
                    <ows:AnyValue />
                    <DefaultValue>0.0</DefaultValue>
                </LiteralData>
            </Input>
                <ows:Identifier>breaks</ows:Identifier>
                <ows:Title>Number of horizontal vertex points per grid cell</ows:Title>
                <LiteralData>
                    <ows:AnyValue />
                    <DefaultValue>3</DefaultValue>
                </LiteralData>
            </Input>
            <Input maxOccurs="2" minOccurs="2">
                <ows:Identifier>grid</ows:Identifier>
                <ows:Title>Number of rows and columns in grid</ows:Title>
                <LiteralData>
                    <ows:AnyValue />
                </LiteralData>
            </Input>
                <ows:Identifier>-p</ows:Identifier>
                <ows:Title>Create grid of points instead of areas and centroids</ows:Title>
                <LiteralData>
                    <ows:DataType ows:reference="http://www.w3.org/TR/xmlschema-2/#boolean"<http://www.w3.org/TR/xmlschema-2/#boolean>>boolean</ows:DataType>
                    <ows:AllowedValues>
                            <ows:Value>True</ows:Value>
                            <ows:Value>False</ows:Value>
                    </ows:AllowedValues>
                    <DefaultValue>False</DefaultValue>
                </LiteralData>
            </Input>
                <ows:Identifier>position</ows:Identifier>
                <ows:Title>Where to place the grid</ows:Title>
                <LiteralData>
                    <ows:DataType ows:reference="http://www.w3.org/TR/xmlschema-2/#string"<http://www.w3.org/TR/xmlschema-2/#string>>string</ows:DataType>
                    <ows:AllowedValues>
                            <ows:Value>region</ows:Value>
                            <ows:Value>coor</ows:Value>
                    <DefaultValue>region</DefaultValue>
                </LiteralData>
            </Input>
        </DataInputs>
        <ProcessOutputs>
            <Output>
                <ows:Identifier>map</ows:Identifier>
                <ows:Title>Name for output vector map</ows:Title>
                <ComplexOutput>
                    <Default>
                        <Format>
                            <MimeType>text/xml</MimeType>
                            <Encoding>UTF-8</Encoding>
                            <Schema>http://schemas.opengis.net/gml/3.1.1/base/gml.xsd</Schema>
                        </Format>
                    </Default>
                    <Supported>
                        <Format>
                        </Format>
                        <Format>
                            <MimeType>application/xml</MimeType>
                        </Format>
                        <Format>
                            <Schema>http://schemas.opengis.net/gml/2.1.2/feature.xsd</Schema>
                        </Format>
                        <Format>
                        </Format>
                        <Format>
                            <Schema>http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd</Schema>
                        </Format>
                    </Supported>
                </ComplexOutput>
            </Output>
        </ProcessOutputs>
    </ProcessDescription>
</ns0:ProcessDescriptions>
 <class 'owslib.wps.Process'> : {'identifier': 'v.mkgrid', 'verbose': True, 'title': 'Creates a vector map of a user-defined grid.', '_root': <Element 'ProcessDescription' at 0x1007b1f10>, 'statusSupported': True, 'storeSupported': True, 'processVersion': None, 'abstract': 'http://grass.osgeo.org/grass70/manuals/html70_user/v.mkgrid.html'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Width and height of boxes in grid', 'dataType': '//www.w3.org/TR/xmlschema-2/#float', 'defaultValue': None, 'supportedValues': [], 'allowedValues': ['AnyValue'], 'maxOccurs': 2, 'identifier': 'box'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Lower left easting and northing coordinates of map', 'dataType': '//www.w3.org/TR/xmlschema-2/#float', 'defaultValue': None, 'supportedValues': [], 'allowedValues': ['AnyValue'], 'maxOccurs': 2, 'identifier': 'coor'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Angle of rotation (in degrees counter-clockwise)', 'dataType': '//www.w3.org/TR/xmlschema-2/#float', 'defaultValue': '0.0', 'supportedValues': [], 'allowedValues': ['AnyValue'], 'maxOccurs': 1, 'identifier': 'angle'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Number of horizontal vertex points per grid cell', 'dataType': '//www.w3.org/TR/xmlschema-2/#integer', 'defaultValue': '3', 'supportedValues': [], 'allowedValues': ['AnyValue'], 'maxOccurs': 1, 'identifier': 'breaks'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 2, 'title': 'Number of rows and columns in grid', 'dataType': '//www.w3.org/TR/xmlschema-2/#integer', 'defaultValue': None, 'supportedValues': [], 'allowedValues': ['AnyValue'], 'maxOccurs': 2, 'identifier': 'grid'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Create grid of points instead of areas and centroids', 'dataType': '//www.w3.org/TR/xmlschema-2/#boolean', 'defaultValue': 'False', 'supportedValues': [], 'allowedValues': ['True', 'False'], 'maxOccurs': 1, 'identifier': '-p'}
        Input:  <class 'owslib.wps.Input'> : {'minOccurs': 0, 'title': 'Where to place the grid', 'dataType': '//www.w3.org/TR/xmlschema-2/#string', 'defaultValue': 'region', 'supportedValues': [], 'allowedValues': ['region', 'coor'], 'maxOccurs': 1, 'identifier': 'position'}
        Output:  <class 'owslib.wps.Output'> : {'mimeType': None, 'reference': None, 'title': 'Name for output vector map', 'dataType': 'ComplexData', 'defaultValue': <owslib.wps.ComplexData object at 0x1007b96d0>, 'supportedValues': [<owslib.wps.ComplexData object at 0x1007b9450>, <owslib.wps.ComplexData object at 0x1007b9590>, <owslib.wps.ComplexData object at 0x1007b9610>, <owslib.wps.ComplexData object at 0x1007b9690>, <owslib.wps.ComplexData object at 0x1007b9650>], 'allowedValues': [], 'identifier': 'map', 'data': []}
WPS Process: identifier=v.mkgrid
WPS Process: title=Creates a vector map of a user-defined grid.
WPS Process: abstract=http://grass.osgeo.org/grass70/manuals/html70_user/v.mkgrid.html
Process input: identifier=box, data type=//www.w3.org/TR/xmlschema-2/#float, minOccurs=0, maxOccurs=2
Process input: identifier=coor, data type=//www.w3.org/TR/xmlschema-2/#float, minOccurs=0, maxOccurs=2
Process input: identifier=angle, data type=//www.w3.org/TR/xmlschema-2/#float, minOccurs=0, maxOccurs=1
Process input: identifier=breaks, data type=//www.w3.org/TR/xmlschema-2/#integer, minOccurs=0, maxOccurs=1
Process input: identifier=grid, data type=//www.w3.org/TR/xmlschema-2/#integer, minOccurs=2, maxOccurs=2
Process input: identifier=-p, data type=//www.w3.org/TR/xmlschema-2/#boolean, minOccurs=0, maxOccurs=1
Process input: identifier=position, data type=//www.w3.org/TR/xmlschema-2/#string, minOccurs=0, maxOccurs=1
Process output: identifier=map, data type=ComplexData
On Sep 6, 2013, at 9:15 AM, Tom Kralidis wrote:
Hi Chris: FYI looks like this got sent to the old OWSLib sourceforge mailing list (which I should turn off).  I've cc'd owslib-devel at lists.osgeo.org<mailto:owslib-devel at lists.osgeo.org>, which is the list we are currently using (more info at http://lists.osgeo.org/mailman/listinfo/owslib-devel).
I'm guessing Luca may have some comments per below.
..Tom
Date: Fri, 6 Sep 2013 16:17:12 +0200
From: christopher.eykamp at tudor.lu<mailto:christopher.eykamp at tudor.lu>
To: owslib-users at lists.sourceforge.net<mailto:owslib-users at lists.sourceforge.net>
Subject: [owslib-users] Bug in owslib?
   Hello,
   I sent this query to the owslib-devel list  a few weeks ago, and got
   no response.  I'm trying again here.  I've fixed this in my local
   copy of owslib, but want some reaffirmation that it is actually a
   bug, and that my fix makes sense.
   Thanks,
   Chris
   I found what might be a bug in owslib, and want to confirm it.
   Fortunately, if I am correct, it is a trivial fix.
   So this is the issue:
   I *think* that when parsing the results
   of a WPS DescribeCoverage request, literal outputs are included in
   the LiteralOutput tag. owslib seems to be looking for the
   LiteralData tag, which is used in the input.
   So the fix would be to replace
   self._parseLiteralData(outputElement, 'LiteralData')
   with
   self._parseLiteralData(outputElement, 'LiteralOutput')
   in wps.py, line c. 979.
   I can be more specific if there is consensus that this is indeed a
   problem.
   Thanks!
   Chris
Learn the latest--Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58041391&iu=/4140/ostg.clktrk
owslib-users mailing list
https://lists.sourceforge.net/lists/listinfo/owslib-users
OWSLib-devel mailing list
OWSLib-devel at lists.osgeo.org<mailto:OWSLib-devel at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/owslib-devel
URL: <http://lists.osgeo.org/pipermail/owslib-devel/attachments/20130916/4794fc2a/attachment-0001.html>
More information about the OWSLib-devel mailing list
