[owslib-users] owslib and CSW authentication
Tom Kralidis
tomkralidis at hotmail.com
Sat Feb 11 15:52:38 PST 2012
FYI I had to revert these changes because of issues with downstream applications for now, and that we are coming to a release in the next week or so. You can still apply use the reverted changes to achieve the functionality you're looking for.
..Tom
> From: tomkralidis at hotmail.com
> To: ricardo.garcia.silva at gmail.com; owslib-users at lists.sourceforge.net
> Date: Sat, 11 Feb 2012 16:02:30 -0500
> Subject: Re: [owslib-users] owslib and CSW authentication
> FYI this has been implemented in svn trunk. Example http://owslib.sourceforge.net/#csw (see Authentication).
> ..Tom
> > From: ricardo.garcia.silva at gmail.com
> > Date: Fri, 10 Feb 2012 16:04:47 +0000
> > To: owslib-users at lists.sourceforge.net
> > OK, I'll look for another solution, but I'll keep an eye on the
> > progress of this feature.
> > Thank you
> > On Fri, Feb 10, 2012 at 3:53 PM, Tom Kralidis <tomkralidis at hotmail.com> wrote:
> > >> Date: Fri, 10 Feb 2012 15:50:03 +0000
> > >> Subject: [owslib-users] owslib and CSW authentication
> > >> Hello list
> > >> I'm new to owslib and I'm also still finding my way through the CSW
> > >> and XML metadata jungle, so please bear with me.
> > >> I want to use owslib for inserting records to my csw server, but I
> > >> can't seem to insert them unless I am authenticated.
> > >> I've skimmed through the documentation available on [1] and tried to
> > >> insert my data in the csw server with the following commands:
> > >> csw = CatalogueServiceWeb('private server url')
> > >> xmlFile = 'path_to_xml_file'
> > >> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
> > >> record=open(xmlFile).read())
> > >> print(csw.response)
> > >> <?xml version="1.0" encoding="UTF-8"?>
> > >> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows"
> > >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
> > >> xsi:schemaLocation="http://www.opengis.net/ows
> > >> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
> > >> <ows:Exception exceptionCode="NoApplicableCode">
> > >> <ows:ExceptionText>Cannot process transaction: User not
> > >> authenticated.</ows:ExceptionText>
> > >> </ows:Exception>
> > >> </ows:ExceptionReport>
> > >> So, how can I authenticate with the server?
> > >> Thanks in advance
> > >> [1] - http://owslib.sourceforge.net/#csw
> > > FYI there is an open ticket on this issue (https://sourceforge.net/apps/trac/owslib/ticket/7), which I'm hoping to get to in the week or so.
> > > ..Tom
> > ___________________________ ___ __
> > Ricardo Garcia Silva
> > Virtualization & Cloud Management Using Capacity Planning
> > Cloud computing makes use of virtualization - but cloud computing
> > also focuses on allowing computing to be delivered as a service.
> > http://www.accelacomm.com/jaw/sfnl/114/51521223/
> > owslib-users mailing list
> > https://lists.sourceforge.net/lists/listinfo/owslib-users
More information about the Owslib-users
