[OWSLib-users] RuntimeError: Document is XML, but not CSW-ish
Julie Pierson
julie.pierson at cnrs.fr
Tue Dec 15 00:04:45 PST 2015
Thanks for your help Tom. I will investigate on the server side then.
But do you know how it's possible that the CSW seems to work ok with the
metasearch tool in QGIS then ?
Thanks again,
Julie.
Le 14/12/2015 20:57, Tom Kralidis a écrit :
> On Mon, 14 Dec 2015, Julie Pierson wrote:
>> Date: Mon, 14 Dec 2015 16:24:56 +0100
>> From: Julie Pierson <julie.pierson at cnrs.fr>
>> To: owslib-users at lists.osgeo.org
>> Subject: [OWSLib-users] RuntimeError: Document is XML, but not CSW-ish
>> Hi list,
>> I'm using csw.getrecords2 on several csw. For most of them,
>> everything works fine, but I encounter a problem for this one :
>> http://www.geocatalogue.fr/api-public/servicesRest?SERVICE=CSW
>> I get this error :
>> File "/mnt/python_modules/owslib/csw.py", line 680, in _invoke
>> raise RuntimeError('Document is XML, but not CSW-ish')
>> I tried using the metasearch tool in QGIS and it works fine for this
>> same csw.
>> Does anyone know what may be the cause of this error ? Maybe I am
>> missing something obvious ?
> In this case, OWSLib is making a standard CSW GetRecords request.
> The CSW above is instead returning a SOAP encoded response. This is
> an error
> with the server.
> Hope this helps.
> ..Tom
Géomaticienne
UMR 5185 ADESS, CNRS
Maison des Suds
12, Esplanade des Antilles
33607 Pessac Cedex
Tel +33 (0)5 56 84 82 07
http://www.ades.cnrs.fr/
More information about the OWSLib-users
