[OWSLib-users] multiple geographic bounding box
Tom Kralidis
tomkralidis at gmail.com
Tue Dec 15 03:50:28 PST 2015
Hi Julie: thanks for the info. Looks like owslib.iso.MD_Metadata is only
parsing the first extent object. iso.py could be updated to process multiple
extents by providing, instead, a list of extents. It would be valuable if you
could file a GitHub issue so someone can implement this.
..Tom
On Tue, 15 Dec 2015, Julie Pierson wrote:
> Date: Tue, 15 Dec 2015 09:08:20 +0100
> From: Julie Pierson <julie.pierson at cnrs.fr>
> To: Tom Kralidis <tomkralidis at gmail.com>
> Cc: owslib-users at lists.osgeo.org
> Subject: Re: [OWSLib-users] multiple geographic bounding box
> Thanks again for your answer Tom.
> I'm sorry but I'm not sure what you want me to send you. Here's an example of
> a metadata with 2 bounding boxes (which are in fact the same), I get only one
> with getrecords2, unless I'm mistaken ?
> Julie.
> Le 14/12/2015 21:03, Tom Kralidis a écrit :
>> On Mon, 14 Dec 2015, Julie Pierson wrote:
>>> Date: Mon, 14 Dec 2015 17:09:43 +0100
>>> To: owslib-users at lists.osgeo.org
>>> Subject: [OWSLib-users] multiple geographic bounding box
>>> Hi,
>>> I'm using csw.getrecords2 to get geographical bounding boxes. It works
>>> fine, but I only get one object for each record, whereas it is possible to
>>> have several bounding boxes for one record. Is there a problem in how
>>> owslib get the bounding boxes (it gets only the first element ?) or am I
>>> missing something ?
>>> Thanks for any help !
>>> Julie.
>> Hi Julie:
>> Can you post (or send offline) a test snippet so I can try and reproduce?
>> Thanks
>> ..Tom
> Géomaticienne
> UMR 5185 ADESS, CNRS
> Maison des Suds
> 12, Esplanade des Antilles
> 33607 Pessac Cedex
> Tel +33 (0)5 56 84 82 07
> http://www.ades.cnrs.fr/
More information about the OWSLib-users
