[OWSLib-users] RuntimeError: Document is XML, but not CSW-ish
Julie Pierson julie.pierson at cnrs.fr
Tue Dec 15 05:45:34 PST 2015
Ok, thanks Tom, this gives me more information to solve my problem.
Julie.
Le 15/12/2015 12:35, Tom Kralidis a écrit :
> Hi Julie: this works in MetaSearch because MetaSearch invokes
> owslib.csw.CatalogueServiceWeb with the skip_caps option, which skips
> Capabilities XML parsing, which in the case below proves problematic.
> Hope this helps.
> ..Tom
> On Tue, 15 Dec 2015, Julie Pierson wrote:
>> Date: Tue, 15 Dec 2015 09:04:45 +0100
>> From: Julie Pierson <julie.pierson at cnrs.fr>
>> To: Tom Kralidis <tomkralidis at gmail.com>
>> Cc: owslib-users at lists.osgeo.org
>> Subject: Re: [OWSLib-users] RuntimeError: Document is XML, but not
>> CSW-ish
>> Thanks for your help Tom. I will investigate on the server side then.
>> But do you know how it's possible that the CSW seems to work ok with
>> the metasearch tool in QGIS then ?
>> Thanks again,
>> Julie.
>> Le 14/12/2015 20:57, Tom Kralidis a écrit :
>>> On Mon, 14 Dec 2015, Julie Pierson wrote:
>>>> Date: Mon, 14 Dec 2015 16:24:56 +0100
>>>> To: owslib-users at lists.osgeo.org
>>>> Subject: [OWSLib-users] RuntimeError: Document is XML, but not CSW-ish
>>>> Hi list,
>>>> I'm using csw.getrecords2 on several csw. For most of them,
>>>> everything works fine, but I encounter a problem for this one :
>>>> http://www.geocatalogue.fr/api-public/servicesRest?SERVICE=CSW
>>>> I get this error :
>>>> File "/mnt/python_modules/owslib/csw.py", line 680, in _invoke
>>>>     raise RuntimeError('Document is XML, but not CSW-ish')
>>>> I tried using the metasearch tool in QGIS and it works fine for
>>>> this same csw.
>>>> Does anyone know what may be the cause of this error ? Maybe I am
>>>> missing something obvious ?
>>> In this case, OWSLib is making a standard CSW GetRecords request.
>>> The CSW above is instead returning a SOAP encoded response. This is
>>> an error
>>> with the server.
>>> Hope this helps.
>>> ..Tom
>> Géomaticienne
>> UMR 5185 ADESS, CNRS
>> Maison des Suds
>> 12, Esplanade des Antilles
>> 33607 Pessac Cedex
>> Tel +33 (0)5 56 84 82 07
>> http://www.ades.cnrs.fr/
Géomaticienne
Maison des Suds
33607 Pessac Cedex
More information about the OWSLib-users mailing list
