thank you for your two responses.
Thanks to Dom's message, we realized that this error was caused by the
version of OWSLib. With a Debian Jessie, the default version of OWSLib
is 0.8.10-1. We have forced the installation of the latest version
0.11.2 (but we still use python 2.7) and it's working right !
Kind regards,
/Sophie MOLLARD/
/Pôle Géomatique/
/MSHE C. N. Ledoux (USR 3124) <http://mshe.univ-fcomte.fr>/
/Université de Franche-Comté/
/Tél : 03.81.66.51.55/
Le 17/06/2016 04:32, Dominic Lowe a écrit :
> Hi Sophie,
> This is working for me too using Python 2.7.6 on Ubuntu, inserting into Geonetwork 3.0.3.0
> I also have:
>> print sys.getdefaultencoding()
>> ascii
> This is using the latest version of OWSLib: 0.11.2.
> Regards
> Dom
> -----Original Message-----
> From: OWSLib-users [mailto:owslib-users-bounces at lists.osgeo.org] On Behalf Of Tom Kralidis
> Sent: Thursday, 16 June 2016 8:07 AM
> To: Sophie Mollard
> Cc: owslib-users at lists.osgeo.org
> Subject: Re: [OWSLib-users] OWSLib UnicodeEncodeError with accents
> Hi Sophie: FYI I'm able to insert this metadata to a CSW using OWSLib without issue. You'll want to consult your CSW server to further debug.
> ..Tom
> On Wed, Jun 8, 2016 at 8:28 AM, Sophie Mollard <sophie.mollard at mshe.univ-fcomte.fr> wrote:
>> Hi Tom,
>> Here is the metadata file attached.
>> Thank you,
>> Sophie MOLLARD
>> Pôle Géomatique
>> Le 07/06/2016 20:56, Tom Kralidis a écrit :
>> Hi Sophie: can you post a test case/XML metadata so I can try to reproduce?
>> On Tue, Jun 7, 2016 at 10:39 AM, Sophie Mollard
>> Hi list,
>> I'm using owslib to insert metadata files into GeoNetwork with a
>> python 2.7 script. It works fine except with metadatas which contain accents.
>> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
>> record=open('Haies_Franche_Comte_metadata.xml').read())
>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 432, in
>> transaction
>> self._invoke()
>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 635, in
>> _invoke
>> self.response = util.http_post(xml_post_url, self.request,
>> self.lang, self.timeout, self.username, self.password)
>> File "/usr/lib/python2.7/dist-packages/owslib/util.py", line 372, in
>> http_post
>> up = urllib2.urlopen(r,timeout=timeout);
>> File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
>> return opener.open(url, data, timeout)
>> File "/usr/lib/python2.7/urllib2.py", line 431, in open
>> response = self._open(req, data)
>> File "/usr/lib/python2.7/urllib2.py", line 449, in _open
>> '_open', req)
>> File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
>> result = func(*args)
>> File "/usr/lib/python2.7/urllib2.py", line 1227, in http_open
>> return self.do_open(httplib.HTTPConnection, req)
>> File "/usr/lib/python2.7/urllib2.py", line 1194, in do_open
>> h.request(req.get_method(), req.get_selector(), req.data, headers)
>> File "/usr/lib/python2.7/httplib.py", line 1001, in request
>> self._send_request(method, url, body, headers)
>> File "/usr/lib/python2.7/httplib.py", line 1035, in _send_request
>> self.endheaders(body)
>> File "/usr/lib/python2.7/httplib.py", line 997, in endheaders
>> self._send_output(message_body)
>> File "/usr/lib/python2.7/httplib.py", line 854, in _send_output
>> self.send(message_body)
>> File "/usr/lib/python2.7/httplib.py", line 826, in send
>> self.sock.sendall(data)
>> File "/usr/lib/python2.7/socket.py", line 224, in meth
>> return getattr(self._sock,name)(*args)
>> UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
>> position
>> 1952: ordinal not in range(128)
>> I've written at the beginning of the script :
>> !/usr/bin/python
>> # -*-coding:Utf-8 -*
>> My metadata file is in utf-8 too :
>> georchestra-ouvert at georchestra-dev:~/bin/lib$ file -i
>> Haies_Franche_Comte_metadata.xml: text/plain; charset=utf-8
>> However, my python environement is :
>> ascii
>> I've tried to change it in utf-8 but then, I've obtained this error
>> with owslib :
>> transaction
>> self._invoke()
>> _invoke
>> http_post
>> File "/usr/lib/python2.7/urllib2.py", line 437, in open
>> response = meth(req, response)
>> File "/usr/lib/python2.7/urllib2.py", line 550, in http_response
>> 'http', request, response, code, msg, hdrs)
>> File "/usr/lib/python2.7/urllib2.py", line 475, in error
>> return self._call_chain(*args)
>> File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default
>> raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
>> urllib2.HTTPError: HTTP Error 500: Erreur Interne de Servlet
>> What am I doing wrong ? Have you any idea ?
>> Thank you in advance,
>> Sophie MOLLARD
>> Pôle Géomatique
>> OWSLib-users mailing list
>> OWSLib-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/owslib-users
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20160617/3a107560/attachment.html>
