[OWSLib-users] error in CSW insert transaction : Document is XML, but not CSW-ish
Chiarello Ernest
Ernest.Chiarello at univ-fcomte.fr
Mon May 2 03:12:56 PDT 2016
Hi all,
I am trying to insert a metadata in GeoNetwork, according OWSlib
documentation <https://geopython.github.io/OWSLib/> but it fails with
this error message :
RuntimeError: Document is XML, but not CSW-ish
But above all, i think quotes are missing in the csw transaction. you
should write :
>>>csw.transaction(ttype='insert', typename='gmd:MD_Metadata', record=open("file.xml").read()) instead of : >>>
csw.transaction(ttype='insert', typename='gmd:MD_Metadata', record=open(file.xml).read())
Next i recovered a file from another GeoNetwork, in order to be sure
that the metadata file would be correct.
wget
https://georchestra-mshe.univ-fcomte.fr/geonetwork/srv/fre/xml.metadata.get?id=17804
-O metadata.xml
And then i tried to insert this metadata in my GeoNetwork Dev machine :
>>> geonetwork =
'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw'
>>> from owslib.csw import CatalogueServiceWeb
>>> csw = CatalogueServiceWeb(geonetwork)
record=open("metadata.xml").read())
File "<stdin>", line 1, in <module>
File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 446, in
transaction
self._invoke()
File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 680, in
_invoke
raise RuntimeError('Document is XML, but not CSW-ish')
Can anybody explain to me why my metadata.xml file is not CSW-ish ?
Thanks in advance,
Ernest.
Ernest CHIARELLO - Ernest.Chiarello at univ-fcomte.fr
UMR6049 ThéMA - Théoriser et Modéliser pour Aménager
CNRS / université de Bourgogne Franche-Comté
32 rue Mégevand 25030 BESANÇON Cedex
Tel : 03 81 66 54 80 Mob : 07 82 99 11 08
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20160502/7df1e203/attachment.html>
More information about the OWSLib-users
