[OWSLib-users] error in CSW insert transaction : Document is XML, but not CSW-ish
Chiarello Ernest
Ernest.Chiarello at univ-fcomte.fr
Tue May 3 02:05:25 PDT 2016
Hi Tom,
Le 03/05/2016 05:04, Tom Kralidis a écrit :
> On Mon, May 2, 2016 at 6:12 AM, Chiarello Ernest
> <Ernest.Chiarello at univ-fcomte.fr> wrote:
>> Hi all,
>> I am trying to insert a metadata in GeoNetwork, according OWSlib
>> documentation but it fails with this error message :
>> RuntimeError: Document is XML, but not CSW-ish
>> But above all, i think quotes are missing in the csw transaction. you should
>> write :
>>>>> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
>>>>> record=open("file.xml").read())
>> instead of :
>>>>> record=open(file.xml).read())
>> Next i recovered a file from another GeoNetwork, in order to be sure that
>> the metadata file would be correct.
>> wget
>> https://georchestra-mshe.univ-fcomte.fr/geonetwork/srv/fre/xml.metadata.get?id=17804
>> -O metadata.xml
>> And then i tried to insert this metadata in my GeoNetwork Dev machine :
>>>>> geonetwork =
>>>>> 'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw'
>>>>> from owslib.csw import CatalogueServiceWeb
>>>>> csw = CatalogueServiceWeb(geonetwork)
>>>>> record=open("metadata.xml").read())
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 446, in
>> transaction
>> self._invoke()
>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 680, in
>> _invoke
>> raise RuntimeError('Document is XML, but not CSW-ish')
>> Can anybody explain to me why my metadata.xml file is not CSW-ish ?
> My guess is that some sort of authentication is required to make CSW-T
> requests against the CSW in question. Try adding the username an
> password parameters to the constructor?
> ..Tom
sorry, but i do not know how to set username and passord in the csw
transaction.
def transaction(self, ttype=None, typename='csw:Record', record=None,
propertyname=None, propertyvalue=None, bbox=None, keywords=[], cql=None,
identifier=None):
Construct and process a Transaction request
Parameters
- ttype: the type of transaction 'insert, 'update', 'delete'
- typename: the typename to describe (default is 'csw:Record')
- record: the XML record to insert
- propertyname: the RecordProperty/PropertyName to Filter against
- propertyvalue: the RecordProperty Value to Filter against (for updates)
- bbox: the bounding box of the spatial query in the form
[minx,miny,maxx,maxy]
- keywords: list of keywords
- cql: common query language text. Note this overrides bbox, qtype,
keywords
- identifier: record identifier. Note this overrides bbox, qtype,
keywords, cql
thanks for your help,
Ernest.
>> Thanks in advance,
>> Ernest.
Ernest CHIARELLO - Ernest.Chiarello at univ-fcomte.fr
UMR6049 ThéMA - Théoriser et Modéliser pour Aménager
CNRS / université de Bourgogne Franche-Comté
32 rue Mégevand 25030 BESANÇON Cedex
Tel : 03 81 66 54 80 Mob : 07 82 99 11 08
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20160503/b19e40f4/attachment.html>
More information about the OWSLib-users
