[OWSLib-users] error in CSW insert transaction : Document is XML, but not CSW-ish
Chiarello Ernest
Ernest.Chiarello at univ-fcomte.fr
Tue May 3 02:37:47 PDT 2016
Le 03/05/2016 11:11, Chiarello Ernest a écrit :
> new idea !
> Le 03/05/2016 11:05, Chiarello Ernest a écrit :
>> Hi Tom,
>> Le 03/05/2016 05:04, Tom Kralidis a écrit :
>>> On Mon, May 2, 2016 at 6:12 AM, Chiarello Ernest
>>> <Ernest.Chiarello at univ-fcomte.fr> wrote:
>>>> Hi all,
>>>> I am trying to insert a metadata in GeoNetwork, according OWSlib
>>>> documentation but it fails with this error message :
>>>> RuntimeError: Document is XML, but not CSW-ish
>>>> But above all, i think quotes are missing in the csw transaction. you should
>>>> write :
>>>>>>> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
>>>>>>> record=open("file.xml").read())
>>>> instead of :
>>>>>>> record=open(file.xml).read())
>>>> Next i recovered a file from another GeoNetwork, in order to be sure that
>>>> the metadata file would be correct.
>>>> wget
>>>> https://georchestra-mshe.univ-fcomte.fr/geonetwork/srv/fre/xml.metadata.get?id=17804
>>>> -O metadata.xml
>>>> And then i tried to insert this metadata in my GeoNetwork Dev machine :
>>>>>>> geonetwork =
>>>>>>> 'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw'
>>>>>>> from owslib.csw import CatalogueServiceWeb
>>>>>>> csw = CatalogueServiceWeb(geonetwork)
>>>>>>> record=open("metadata.xml").read())
>>>> Traceback (most recent call last):
>>>> File "<stdin>", line 1, in <module>
>>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 446, in
>>>> transaction
>>>> self._invoke()
>>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 680, in
>>>> _invoke
>>>> raise RuntimeError('Document is XML, but not CSW-ish')
>>>> Can anybody explain to me why my metadata.xml file is not CSW-ish ?
>>> My guess is that some sort of authentication is required to make CSW-T
>>> requests against the CSW in question. Try adding the username an
>>> password parameters to the constructor?
>>> ..Tom
>> sorry, but i do not know how to set username and passord in the csw
>> transaction.
>> def transaction(self, ttype=None, typename='csw:Record', record=None,
>> propertyname=None, propertyvalue=None, bbox=None, keywords=[],
>> cql=None, identifier=None):
>> Construct and process a Transaction request
>> Parameters
>> - ttype: the type of transaction 'insert, 'update', 'delete'
>> - typename: the typename to describe (default is 'csw:Record')
>> - record: the XML record to insert
>> - propertyname: the RecordProperty/PropertyName to Filter against
>> - propertyvalue: the RecordProperty Value to Filter against (for
>> updates)
>> - bbox: the bounding box of the spatial query in the form
>> [minx,miny,maxx,maxy]
>> - keywords: list of keywords
>> - cql: common query language text. Note this overrides bbox, qtype,
>> keywords
>> - identifier: record identifier. Note this overrides bbox, qtype,
>> keywords, cql
>> thanks for your help,
>> Ernest.
> I realized that username and password should be send when opening CSW !
> csw = CatalogueServiceWeb(geonetwork, skip_caps=True,
> username='admin', password='admin')
> but i have a new error...
> >>> geonetwork =
> record=open('metadata.xml').read())
> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 429, in
> transaction
> node1.append(etree.fromstring(record))
> File "src/lxml/lxml.etree.pyx", line 3213, in lxml.etree.fromstring
> (src/lxml/lxml.etree.c:82934)
> File "src/lxml/parser.pxi", line 1819, in
> lxml.etree._parseMemoryDocument (src/lxml/lxml.etree.c:124533)
> File "src/lxml/parser.pxi", line 1707, in lxml.etree._parseDoc
> (src/lxml/lxml.etree.c:123074)
> File "src/lxml/parser.pxi", line 1079, in
> lxml.etree._BaseParser._parseDoc (src/lxml/lxml.etree.c:117114)
> File "src/lxml/parser.pxi", line 573, in
> lxml.etree._ParserContext._handleParseResultDoc
> (src/lxml/lxml.etree.c:110510)
> File "src/lxml/parser.pxi", line 683, in
> lxml.etree._handleParseResult (src/lxml/lxml.etree.c:112276)
> File "src/lxml/parser.pxi", line 624, in lxml.etree._raiseParseError
> (src/lxml/lxml.etree.c:111367)
> lxml.etree.XMLSyntaxError: None
> any help ?
> Ernest.
sorry, the metadata file was empty, for an unknow reason... >:o
so, i can try another time, with user authentication :
>>> geonetwork =
transaction
self._invoke()
_invoke
it seems the error is the same...
what am i missing ?
Ernest.
>>>> Thanks in advance,
>>>> Ernest.
>> Ernest CHIARELLO -Ernest.Chiarello at univ-fcomte.fr
>> UMR6049 ThéMA - Théoriser et Modéliser pour Aménager
>> CNRS / université de Bourgogne Franche-Comté
>> 32 rue Mégevand 25030 BESANÇON Cedex
>> Tel : 03 81 66 54 80 Mob : 07 82 99 11 08
>> OWSLib-users mailing list
>> OWSLib-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/owslib-users
Ernest CHIARELLO - Ernest.Chiarello at univ-fcomte.fr
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20160503/f95ee2e4/attachment.html>
More information about the OWSLib-users
