[OWSLib-users] error in CSW insert transaction : Document is XML, but not CSW-ish
Chiarello Ernest
Ernest.Chiarello at univ-fcomte.fr
Tue May 3 08:34:27 PDT 2016
it works now !! :-)
Le 03/05/2016 17:22, Chiarello Ernest a écrit :
> Thanks Tom
> Le 03/05/2016 14:30, Tom Kralidis a écrit :
>> Hi Ernest:
>> On Tue, 3 May 2016, Chiarello Ernest wrote:
>>> Date: Tue, 3 May 2016 11:37:47 +0200
>>> From: Chiarello Ernest <Ernest.Chiarello at univ-fcomte.fr>
>>> To: Tom Kralidis <tomkralidis at gmail.com>, OWSLib-users at lists.osgeo.org
>>> Subject: Re: [OWSLib-users] error in CSW insert transaction :
>>> Document is XML,
>>> but not CSW-ish
>>> Le 03/05/2016 11:11, Chiarello Ernest a écrit :
>>>> new idea !
>>>> Le 03/05/2016 11:05, Chiarello Ernest a écrit :
>>>>> Hi Tom,
>>>>> Le 03/05/2016 05:04, Tom Kralidis a écrit :
>>>>>> On Mon, May 2, 2016 at 6:12 AM, Chiarello Ernest
>>>>>> <Ernest.Chiarello at univ-fcomte.fr> wrote:
>>>>>>> Hi all,
>>>>>>> I am trying to insert a metadata in GeoNetwork, according OWSlib
>>>>>>> documentation but it fails with this error message :
>>>>>>> RuntimeError: Document is XML, but not CSW-ish
>>>>>>> But above all, i think quotes are missing in the csw
>>>>>>> transaction. you should
>>>>>>> write :
>>>>>>>>>> csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
>>>>>>>>>> record=open("file.xml").read())
>>>>>>> instead of :
>>>>>>>>>> record=open(file.xml).read())
>>>>>>> Next i recovered a file from another GeoNetwork, in order to be
>>>>>>> sure that
>>>>>>> the metadata file would be correct.
>>>>>>> wget
>>>>>>> https://georchestra-mshe.univ-fcomte.fr/geonetwork/srv/fre/xml.metadata.get?id=17804
>>>>>>> -O metadata.xml
>>>>>>> And then i tried to insert this metadata in my GeoNetwork Dev
>>>>>>> machine :
>>>>>>>>>> geonetwork =
>>>>>>>>>> 'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw'
>>>>>>>>>> from owslib.csw import CatalogueServiceWeb
>>>>>>>>>> csw = CatalogueServiceWeb(geonetwork)
>>>>>>>>>> record=open("metadata.xml").read())
>>>>>>> Traceback (most recent call last):
>>>>>>> File "<stdin>", line 1, in <module>
>>>>>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line
>>>>>>> 446, in
>>>>>>> transaction
>>>>>>> self._invoke()
>>>>>>> 680, in
>>>>>>> _invoke
>>>>>>> raise RuntimeError('Document is XML, but not CSW-ish')
>>>>>>> Can anybody explain to me why my metadata.xml file is not CSW-ish ?
>>>>>> My guess is that some sort of authentication is required to make
>>>>>> CSW-T
>>>>>> requests against the CSW in question. Try adding the username an
>>>>>> password parameters to the constructor?
>>>>>> ..Tom
>>>>> sorry, but i do not know how to set username and passord in the
>>>>> csw transaction.
>>>>> def transaction(self, ttype=None, typename='csw:Record',
>>>>> record=None, propertyname=None, propertyvalue=None, bbox=None,
>>>>> keywords=[], cql=None, identifier=None):
>>>>> Construct and process a Transaction request
>>>>> Parameters
>>>>> - ttype: the type of transaction 'insert, 'update', 'delete'
>>>>> - typename: the typename to describe (default is 'csw:Record')
>>>>> - record: the XML record to insert
>>>>> - propertyname: the RecordProperty/PropertyName to Filter against
>>>>> - propertyvalue: the RecordProperty Value to Filter against (for
>>>>> updates)
>>>>> - bbox: the bounding box of the spatial query in the form
>>>>> [minx,miny,maxx,maxy]
>>>>> - keywords: list of keywords
>>>>> - cql: common query language text. Note this overrides bbox,
>>>>> qtype, keywords
>>>>> - identifier: record identifier. Note this overrides bbox, qtype,
>>>>> keywords, cql
>>>>> thanks for your help,
>>>>> Ernest.
>>>> I realized that username and password should be send when opening
>>>> CSW !
>>>> csw = CatalogueServiceWeb(geonetwork, skip_caps=True,
>>>> username='admin', password='admin')
>>>> but i have a new error...
>>>> >>> geonetwork =
>>>> record=open('metadata.xml').read())
>>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 429,
>>>> in transaction
>>>> node1.append(etree.fromstring(record))
>>>> File "src/lxml/lxml.etree.pyx", line 3213, in
>>>> lxml.etree.fromstring (src/lxml/lxml.etree.c:82934)
>>>> File "src/lxml/parser.pxi", line 1819, in
>>>> lxml.etree._parseMemoryDocument (src/lxml/lxml.etree.c:124533)
>>>> File "src/lxml/parser.pxi", line 1707, in lxml.etree._parseDoc
>>>> (src/lxml/lxml.etree.c:123074)
>>>> File "src/lxml/parser.pxi", line 1079, in
>>>> lxml.etree._BaseParser._parseDoc (src/lxml/lxml.etree.c:117114)
>>>> File "src/lxml/parser.pxi", line 573, in
>>>> lxml.etree._ParserContext._handleParseResultDoc
>>>> (src/lxml/lxml.etree.c:110510)
>>>> File "src/lxml/parser.pxi", line 683, in
>>>> lxml.etree._handleParseResult (src/lxml/lxml.etree.c:112276)
>>>> File "src/lxml/parser.pxi", line 624, in
>>>> lxml.etree._raiseParseError (src/lxml/lxml.etree.c:111367)
>>>> lxml.etree.XMLSyntaxError: None
>>>> any help ?
>>>> Ernest.
>>> sorry, the metadata file was empty, for an unknow reason... >:o
>>> so, i can try another time, with user authentication :
>>>>>> geonetwork =
>>>>>> username='admin',
>>> password='admin')
>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 446, in
>>> transaction
>>> self._invoke()
>>> File "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 680, in
>>> _invoke
>>> it seems the error is the same...
>> Are you able to access csw.response after the error? If not, add a
>> print
>> statment (self.response) in
>> https://github.com/geopython/OWSLib/blob/master/owslib/csw.py#L666
>> to see the actual result from the CSW?
> here is the csw.response :
> <?xml version="1.0" encoding="UTF-8"?>
> <response>
> <info>Not a CSW Discovery operation: Transaction. Did you mean to
> use the CSW Publication service? Use service name /csw-publication</info>
> </response>
> i hope it will help you.
i changed the URL, using csw-publication instead of csw, as suggested by
Kevin Dyke,
in the geonetwork-users list :
>>> geonetwork =
'http://geonetwork-mshe.univ-fcomte.fr:8080/geonetwork/srv/fre/csw-publication'
>>> # Transaction: insert
... csw.transaction(ttype='insert', typename='gmd:MD_Metadata',
<csw:TransactionResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2">
<csw:TransactionSummary>
<csw:totalInserted>1</csw:totalInserted>
<csw:totalUpdated>0</csw:totalUpdated>
<csw:totalDeleted>0</csw:totalDeleted>
</csw:TransactionSummary>
<csw:InsertResult handleRef="handleRefValue">
<csw:BriefRecord>
<identifier>7253afc776baa4ed602def02e4ef04d15ef5ebd3</identifier>
</csw:BriefRecord>
</csw:InsertResult>
</csw:TransactionResponse>
thanks to both. :-)
Ernest.
>>> what am i missing ?
>>> Ernest.
Ernest CHIARELLO - Ernest.Chiarello at univ-fcomte.fr
UMR6049 ThéMA - Théoriser et Modéliser pour Aménager
CNRS / université de Bourgogne Franche-Comté
32 rue Mégevand 25030 BESANÇON Cedex
Tel : 03 81 66 54 80 Mob : 07 82 99 11 08
More information about the OWSLib-users
