[OWSLib-users] CatalogueServiceWeb and data.gov exception
Davide Muraro
muraro_davide at hotmail.com
Fri Jun 2 22:23:45 PDT 2017
Thanks James!
from owslib.csw import CatalogueServiceWeb
from owslib.fes import PropertyIsEqualTo, PropertyIsLike, BBox
csw = CatalogueServiceWeb('https://catalog.data.gov/csw')
query = PropertyIsEqualTo('csw:AnyText', 'Africa')
csw.getrecords2(constraints=[query], maxrecords=20)
print(csw.records)
it works like a charm.
Davide
Da: Passmore, James H. <jpass at bgs.ac.uk>
Inviato: venerdì 2 giugno 2017 10.48
A: Davide Muraro; owslib-users at lists.osgeo.org
Oggetto: RE: CatalogueServiceWeb and data.gov exception
The line
csw = CatalogueServiceWeb('http://catalog.data.gov/csw?service=CSW&version=2.0.2&request=GetCapabilities')
should be:
csw = CatalogueServiceWeb('http://catalog.data.gov/csw')
or (as you’re getting redirected to an https service):
If I use (Python 3.6):
from owslib import csw as csw
c = csw.CatalogueServiceWeb('https://catalog.data.gov/csw')
c.getrecords2(maxrecords=20)
print(c.records)
I get a result (eventually ~ the service seems quite slow).
I’ve tried running a query but it seems to be taking forever to return
James
From: OWSLib-users [mailto:owslib-users-bounces at lists.osgeo.org] On Behalf Of Davide Muraro
Sent: 01 June 2017 12:44
To: owslib-users at lists.osgeo.org
Subject: [OWSLib-users] CatalogueServiceWeb and data.gov exception
Dear All,
I was doing some tests using CatalogueServiceWeb and the data.gov CSW.
Basically doing something like:
query = PropertyIsEqualTo('csw:AnyText', 'map')
print(csw.records)
i got:
*python3.5/site-packages/owslib/csw.py in getrecords2(self, constraints, sortby, typenames, esn, outputschema, format, startposition, maxrecords, cql, xml, resulttype)
380
381 # process search results attributes
--> 382 val = self._exml.find(util.nspath_eval('csw:SearchResults', namespaces)).attrib.get('numberOfRecordsMatched')
383 self.results['matches'] = int(util.testXMLValue(val, True))
384 val = self._exml.find(util.nspath_eval('csw:SearchResults', namespaces)).attrib.get('numberOfRecordsReturned')
AttributeError: 'NoneType' object has no attribute 'attrib'
Ideas?
D
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
URL: <http://lists.osgeo.org/pipermail/owslib-users/attachments/20170603/208d8639/attachment.html>
More information about the OWSLib-users
