[OWSLib-users] csw getrecords2 : request rejected
Julie Pierson
julie.pierson at cnrs.fr
Thu Aug 2 00:43:13 PDT 2018
Thanks for your answer James. It is indeed a French government website.
I understand the request by blocked, but would you know why ? Could I
bypass this somehow ?
Thanks
Julie.
Le 31/07/2018 à 19:43, Passmore, James H. a écrit :
> It looks very much like the request was blocked by the server you are querying.
> I've had similar messages when querying French government web sites
> James
> -----Original Message-----
> From: OWSLib-users <owslib-users-bounces at lists.osgeo.org> On Behalf Of Julie Pierson
> Sent: 31 July 2018 15:41
> To: owslib-users at lists.osgeo.org
> Subject: [OWSLib-users] csw getrecords2 : request rejected
> Hi all,
> I'm trying to get the records from this csw : http://www.data.eaufrance.fr:/geosource/srv/eng/csw?
> Getting one record with getrecordbyid works ok, but my request is rejected when I use getrecords2 or getrecords.
> Here's a snippet of code for Python2.7 :
> from owslib.csw import CatalogueServiceWeb url = 'http://www.data.eaufrance.fr:/geosource/srv/eng/csw?'
> csw = CatalogueServiceWeb(url)
> csw.getrecords2()
> And here's the error I get :
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/usr/local/lib/python2.7/dist-packages/owslib/csw.py", line 376, in getrecords2
> self._invoke()
> File "/usr/local/lib/python2.7/dist-packages/owslib/csw.py", line 676, in _invoke
> self._exml = etree.parse(BytesIO(self.response))
> File "src/lxml/lxml.etree.pyx", line 3427, in lxml.etree.parse (src/lxml/lxml.etree.c:85131)
> File "src/lxml/parser.pxi", line 1799, in lxml.etree._parseDocument (src/lxml/lxml.etree.c:124241)
> File "src/lxml/parser.pxi", line 1819, in lxml.etree._parseMemoryDocument (src/lxml/lxml.etree.c:124533)
> File "src/lxml/parser.pxi", line 1707, in lxml.etree._parseDoc (src/lxml/lxml.etree.c:123074)
> File "src/lxml/parser.pxi", line 1079, in lxml.etree._BaseParser._parseDoc (src/lxml/lxml.etree.c:117114)
> File "src/lxml/parser.pxi", line 573, in lxml.etree._ParserContext._handleParseResultDoc (src/lxml/lxml.etree.c:110510)
> File "src/lxml/parser.pxi", line 683, in lxml.etree._handleParseResult (src/lxml/lxml.etree.c:112276)
> File "src/lxml/parser.pxi", line 613, in lxml.etree._raiseParseError (src/lxml/lxml.etree.c:111124)
> lxml.etree.XMLSyntaxError: Opening and ending tag mismatch: br line 1 and body, line 1, column 242
> If I then try :
> csw.response
> I get :
> "<html><head><title>Request Rejected</title></head><body>The requested URL was rejected. Please consult with your administrator.<br><br>Your support ID is: 16327421591402261030<br><br><a href='javascript:history.back();'>[Go Back]</a></body></html>"
> getrecordbyid works fine.
> Do you know if this issue is related to the server I'm querying, or if this is a bug ? Do you have any idea which direction I should try looking into ?
> Thanks a lot,
> Julie.
> ________________________________
> This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
More information about the OWSLib-users
