[OWSLib-users] question about wcst_import and reading values
Tom Kralidis
tomkralidis at gmail.com
Mon Feb 8 14:12:50 PST 2021
Hi Mohammed:
1. I can't see your code per se, but if this is functionality for a
transactional WCS (which would be great) then I would open an
enhancement issue
2. there are not examples of working with coverage results per se.
The idea here is that you would use another package to work with the
coverage result that OWSLib would return (say xarray, rasterio, etc.).
..Tom
On Mon, Feb 8, 2021 at 7:50 AM mohammed shambakey <shambakey1 at gmail.com> wrote:
> Hi
> I'm using the OWS service from Rasdaman, and we usually use the included "wcst_import.sh" file to insert new coverages into rasdaman. I wonder if it is possible to use OWSLIB to do the same?
> Also, are there any examples of how to iterate through all values of a specific coverage using OWSLIB (the coverage is in netcdf)?
> Regards
> Mohammed
> OWSLib-users mailing list
> OWSLib-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/owslib-users
More information about the OWSLib-users
