[OWSLib-users] GitHub Issues and Pull Requests
Seth G sethg at geographika.co.uk
Thu Oct 24 07:52:36 PDT 2024
Hi all,
If you have been following the GitHub repository for OWSLib you may have noticed there is now a stalebot setup which marks issues and pull requests as stale after 90 days, and the closes them automatically 7 days after this.
If you had an issue closed, could you please re-test against the latest version of OWSLib, and re-open if it is still relevant.
For any pull requests, adding a unit test and ensuring all the continuous integration checks pass will make it much more likely to be merged. For any significant changes, it is best to first post to the dev list [1] to avoid losing time on a feature that might not be accepted.
Thanks,
The OWSLib developer team.
[1] https://lists.osgeo.org/mailman/listinfo/owslib-devel
More information about the OWSLib-users mailing list
