[Pacific] Fwd: [postgis-users] PostGIS 2.0.4 Released
Edwin Liava'a
liavaa.edwin at gmail.com
Fri Sep 6 17:15:40 PDT 2013
Hi All,
For advocates of PostGIS, forwarding here release of PosGIS 2.0.4.
cheers,
Edwin
---------- Forwarded message ----------
Date: Fri, 6 Sep 2013 16:02:36 -0700
Subject: [postgis-users] PostGIS 2.0.4 Released
To: postgis-devel at lists.osgeo.org, postgis-users at lists.osgeo.org
Cc: pgsql-announce at postgresql.org
http://postgis.net/2013/09/06/postgis-2-0-4
Happy to say, PostGIS 2.0.4 is now released, with a bundle of bug fixes:
* Bug Fixes *
- #2110, Equality operator between EMPTY and point on origin
- Allow adding points at precision distance with TopoGeo_addPoint
- #1968, Fix missing edge from toTopoGeom return
- #2165, ST_NumPoints regression failure with CircularString
- #2168, ST_Distance is not always commutative
- #2186, gui progress bar updates too frequent
- #2201, ST_GeoHash wrong on boundaries
- #2257, GBOX variables not initialized when testing with empty geometries
- #2271, Prevent parallel make of raster
- #2267, Server crash from analyze table
- #2277, potential segfault removed
- #2307, ST_MakeValid outputs invalid geometries
- #2351, st_distance between geographies wrong
- #2359, Incorrect handling of schema for overview constraints
- #2371, Support GEOS versions with more than 1 digit in micro
- #2372, Cannot parse space-padded KML coordinates
- Fix build with systemwide liblwgeom installed
- #2383, Fix unsafe use of \' in warning message
- #2410, Fix segmentize of collinear curve
- #2415, ST_Multi support for COMPOUNDCURVE and CURVEPOLYGON
- #2412, ST_LineToCurve support for lines with less than 4 vertices
- #2420, ST_LineToCurve: require at least 8 edges to define a full circle
- #2423, ST_LineToCurve: require all arc edges to form the same angle
- #2424, ST_CurveToLine: add support for COMPOUNDCURVE in MULTICURVE
- #2427, Make sure to retain first point of curves on ST_CurveToLine
* Enhancements *
- #2269, Avoid uselessly de-toasting full geometries on ANALYZE
* Known Issues *
- #2111, Raster bands can only reference the first 256 bands of out-db rasters
Paul Ramsey
http://opengeo.org
http://postgis.net
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
More information about the pacific-islands
