[pal-developer] setFeatureDistLabel()
Maxence Laurent
maxence.laurent at heig-vd.ch
Wed Jul 7 12:06:11 EDT 2010
wowww... this method should not exists... I'll rename it right now into
its real name : getArrange (same thing for the corresponding setter)
Actually, the JPalLayer::getArrange is part of the java jni wrapper
(JPal). It wraps the PalLayer::getArrange method
Arrangment define how the label candidates will be computed according to
the feature type.
You can find a description of the different values of this enumeration
(pal.h:~83-92) in (page 2) :
http://pal.heig-vd.ch/uploads/documentation/pal-0.2_HOWTO_Integrate.pdf
Regards
On 30/06/10 11:00, Vianney Dugrain wrote:
> Hello,
> I have a question regarding the function Layer::setFeatureDistLabel().
> Does it set the size of the symbol displayed on the map, or the size of an invisible buffer area around the symbol, where a label cannot be placed?
> Thank you for your answer.
> Best regards!
> Vianney Dugrain
> pal-developer mailing list
> pal-developer at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pal-developer
More information about the pal-developer
