[pal-developer] inactiveCost
Maxence Laurent maxence.laurent at heig-vd.ch
Thu Jul 8 07:51:38 EDT 2010
no, inactiveCost is only used when evaluating the labelling solution cost.
the solution cost equals:
   the sum of all displayed label cost + the sum of all undisplayed
feature inactiveCost
InactiveCost is computed according to the feature priority. Its purpose
is to favour labelling high priority label instead of lower ones.
You can find a technical documentation here (french only) :
http://geosysin.iict.ch/pal-svn/papers/Report/algo.pdf
On 08/07/10 12:06, Vianney Dugrain wrote:
> Hello,
> The attribute inactiveCost of the class problem : is it a weight given to the obstacles that may overlap with labels?
> I found the following formula: inactiveCost=2^(10-10*layerFactor)
> Thank you!
> Vianney_______________________________________________
> pal-developer mailing list
> pal-developer at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pal-developer
More information about the pal-developer mailing list
