[pal-developer] setFeatureDistLabel()
Maxence Laurent
maxence.laurent at heig-vd.ch
Wed Jun 30 10:33:53 EDT 2010
Hi
There is two cases : for point features and for line features
1) Point Feature
Distlabel define the minimum distance to have bw the label and the
point. It's usually used to forbid the label to overlap the symbol
displayed over the point
Distlabel doesn't set the size of the symbol since pal only cares about
label placement, but distlabel is set according to the radius of the
circumscribed circle of the symbol
2) Line feature
With a P_LINE_AROUND alignment, distlabel define the perpendicular
offset bw the line and the label. In this case, using a distlabel a
little bit bigger than half the stroke width is a good idea
regards
Maxence
On 30/06/10 11:00, Vianney Dugrain wrote:
> Hello,
> I have a question regarding the function Layer::setFeatureDistLabel().
> Does it set the size of the symbol displayed on the map, or the size of an invisible buffer area around the symbol, where a label cannot be placed?
> Thank you for your answer.
> Best regards!
> Vianney Dugrain
> pal-developer mailing list
> pal-developer at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pal-developer
More information about the pal-developer
