[pal-developer] VisualStudio Solution
Alexei Kolganov imagovrn at gmail.com
Thu Nov 17 09:36:59 EST 2011
Greetings, Developers.
Recently I have started integrating libPAL in my project and found that it
does not include any MS Visual Studio solution (or any
other convenient way) to build the library under Windows. Also, when I have
started building the library I have faced some issues (all of them were
minor, but still). Therefore I would like to submit a little patch which
would allow new users of libPAL build the library easily.
The patch is minor, it contains only the features required to build the
library in my environment.
It consists of:
- Solution files
- Changes to source files:
  - Minor: eliminated trailing spaces in files that I have modified.
  - Minor: eliminated few compiler warnings.
  - Minor: fixed compilation issue with M_PI.
One thing that, however, I am not sure is correct:
  #ifdef _MSC_VER
  #define _HAVE_WINDOWS_H_
  #endif // _MSC_VER
This code assumes that Windows SDK is always installed in MSVC, which,
frankly, is not.
The patch is submitted to Trac as Ticket #14 (
http://geosysin.iict.ch/pal-trac/ticket/14 )
If you have any suggestions or comments please don't hesitate to contact me.
Best regards, Alexey Kolganov
URL: http://lists.osgeo.org/pipermail/pal-developer/attachments/20111117/5fc30d2a/attachment.html
More information about the pal-developer mailing list
