[pdal-commits] [PDAL/PDAL] 4d4c7b: noticed these lines were missing
    noreply at github.com
    Sat Aug 27 00:43:56 EDT 2011
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 4d4c7b7f25988718ab6048061d895e467cdcdbd9
      https://github.com/PDAL/PDAL/commit/4d4c7b7f25988718ab6048061d895e467cdcdbd9
  Author: Michael P. Gerlek <mpg at flaxen.com>
  Date:   2011-08-26 (Fri, 26 Aug 2011)
  Changed paths:
    M src/drivers/oci/Reader.cpp
  Log Message:
  Commit: 9b472fe54e4757ed48d097d3f20f6d5dd4d075fe
      https://github.com/PDAL/PDAL/commit/9b472fe54e4757ed48d097d3f20f6d5dd4d075fe
  Changed paths:
    A doc/_static/pdal_bubbles_only.png
  A doc/_static/pdal_logo.png
  A doc/_static/sphinx.css
  A doc/_templates/indexsidebar.html
  A doc/_templates/layout.html
  M doc/conf.py
  A doc/development/index.txt
  A doc/development/model/Model.sln
  A doc/development/model/ModelDefinition/ModelProject.uml
  A doc/development/model/ModelProject.modelproj
  A doc/development/model/PointData.classdiagram
  A doc/development/model/PointData.classdiagram.layout
  A doc/development/model/Stage.classdiagram
  A doc/development/model/Stage.classdiagram.layout
  A doc/development/notes/apps.txt
  A doc/development/notes/bindings.txt
  A doc/development/notes/c-api.txt
  A doc/development/notes/coding-conventions.txt
  A doc/development/notes/core-classes.txt
  A doc/development/notes/docs.txt
  A doc/development/notes/future.txt
  A doc/development/notes/goals.txt
  A doc/development/notes/index.txt
  A doc/development/notes/intro.txt
  A doc/development/notes/io.txt
  A doc/development/notes/makefile
  A doc/development/notes/misc.txt
  A doc/development/notes/pipeline.txt
  A doc/development/notes/pipeline_xml.txt
  A doc/development/notes/stages.txt
  A doc/development/notes/testing.txt
  A doc/development/notes/use-cases.txt
  A doc/docs.txt
  A doc/faq.txt
  M doc/index.txt
  R doc/model/Model.sln
  R doc/model/ModelDefinition/ModelProject.uml
  R doc/model/ModelProject.modelproj
  R doc/model/PointData.classdiagram
  R doc/model/PointData.classdiagram.layout
  R doc/model/Stage.classdiagram
  R doc/model/Stage.classdiagram.layout
  R doc/notes/apps.txt
  R doc/notes/bindings.txt
  R doc/notes/c-api.txt
  R doc/notes/coding-conventions.txt
  R doc/notes/core-classes.txt
  R doc/notes/docs.txt
  R doc/notes/future.txt
  R doc/notes/goals.txt
  R doc/notes/intro.txt
  R doc/notes/io.txt
  R doc/notes/makefile
  R doc/notes/misc.txt
  R doc/notes/pipeline.txt
  R doc/notes/pipeline_xml.txt
  R doc/notes/stages.txt
  R doc/notes/testing.txt
  R doc/notes/use-cases.txt
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
Compare: https://github.com/PDAL/PDAL/compare/f7f5ea5...9b472fe
More information about the pdal-commits
