[pdal-commits] [PDAL/PDAL] be6cf3: have dimension::size_type be a
boost::int32_t to s...
noreply at github.com
Mon Nov 28 11:44:14 EST 2011
Branch: refs/heads/dimension_types
Home: https://github.com/PDAL/PDAL
Commit: be6cf353d6a35d65184a256b302e7c1d396bb006
https://github.com/PDAL/PDAL/commit/be6cf353d6a35d65184a256b302e7c1d396bb006
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2011-11-28 (Mon, 28 Nov 2011)
Changed paths:
M include/pdal/dimension/Dimension.hpp
M src/Dimension.cpp
Log Message:
have dimension::size_type be a boost::int32_t to support negative indices -- add a createUUID() convenience method
Commit: 735ea7746656df508ee3d813dadbfe04ced5b6fa
https://github.com/PDAL/PDAL/commit/735ea7746656df508ee3d813dadbfe04ced5b6fa
Changed paths:
M doc/index.txt
Log Message:
reformatting
Commit: c9529bf83b56ea1abd061c23508056f9f6e5c05e
https://github.com/PDAL/PDAL/commit/c9529bf83b56ea1abd061c23508056f9f6e5c05e
Changed paths:
M include/pdal/PointBuffer.hpp
M src/PointBuffer.cpp
Log Message:
remove extra m_pointSize field from pdal::PointBuffer... we will always fetch it as a const& from the Schema::getByteSize() in case the PointBuffer's schema were to ever change
Commit: 48eaceed3fbfe2200e1928233726fcebf30efc16
https://github.com/PDAL/PDAL/commit/48eaceed3fbfe2200e1928233726fcebf30efc16
Changed paths:
M include/pdal/Schema.hpp
Log Message:
typedef a schema::size_type and set it to boost::uint32_t so it can't be <0 -- we can change this later if we need to
Compare: https://github.com/PDAL/PDAL/compare/d95d989...48eacee
More information about the pdal-commits
