[pdal-commits] Build failed in Jenkins: PDAL #9
Github
noreply at github.com
Mon Feb 6 17:13:21 EST 2012
See <http://jenkins.pointcloud.org/job/PDAL/9/>
Started by user gadomski
Building in workspace <http://jenkins.pointcloud.org/job/PDAL/ws/>
Checkout:workspace / <http://jenkins.pointcloud.org/job/PDAL/ws/> - hudson.remoting.LocalChannel at 77e655d8
Using strategy: Default
Last Built Revision: Revision 43ee1cafbadc645af02d3fec7375dfc60260ac87 (origin/HEAD, origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from git at github.com:PDAL/PDAL.git
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Error performing command: git fetch -t git at github.com:PDAL/PDAL.git +refs/heads/*:refs/remotes/origin/*
Command "git fetch -t git at github.com:PDAL/PDAL.git +refs/heads/*:refs/remotes/origin/*" returned status code 128: Permission denied (publickey).
fatal: The remote end hung up unexpectedly
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:776)
at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:741)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:190)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:978)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:765)
at hudson.plugins.git.GitSCM.access$100(GitSCM.java:80)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:1003)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:970)
at hudson.FilePath.act(FilePath.java:788)
at hudson.FilePath.act(FilePath.java:770)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:970)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1195)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:576)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:465)
at hudson.model.Run.run(Run.java:1409)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:238)
Caused by: hudson.plugins.git.GitException: Command "git fetch -t git at github.com:PDAL/PDAL.git +refs/heads/*:refs/remotes/origin/*" returned status code 128: Permission denied (publickey).
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:771)
... 17 more
ERROR: Could not fetch from any repository
FATAL: Could not fetch from any repository
hudson.plugins.git.GitException: Could not fetch from any repository
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:1010)
More information about the pdal-commits
