[pdal-commits] [PDAL/PDAL] 1fe33c: put --stage in a <stage> element so the output is ...
GitHub
noreply at github.com
Wed Jul 11 09:33:42 PDT 2012
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 1fe33cb47e259e42701f605c28284a2db4791377
https://github.com/PDAL/PDAL/commit/1fe33cb47e259e42701f605c28284a2db4791377
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2012-07-11 (Wed, 11 Jul 2012)
Changed paths:
M apps/pcinfo.cpp
Log Message:
put --stage in a <stage> element so the output is valid xml
Commit: 501f9578e0d4a1744b792d523355bfab3eb791ec
https://github.com/PDAL/PDAL/commit/501f9578e0d4a1744b792d523355bfab3eb791ec
Changed paths:
M include/pdal/StageBase.hpp
Log Message:
make Stage a friend of StageBase so they can interact with StageBase private data members
Commit: 31e93181184e937597c0a70090959456108dfa66
https://github.com/PDAL/PDAL/commit/31e93181184e937597c0a70090959456108dfa66
Changed paths:
M include/pdal/Metadata.hpp
Log Message:
make getMetadata throw a proper error if it can't find an entry with the requested path. add a deleteMetadata method to remove a requested entry
Commit: 73a37e829803fed73a5bb15699966c0832f1fd69
https://github.com/PDAL/PDAL/commit/73a37e829803fed73a5bb15699966c0832f1fd69
Changed paths:
M src/Stage.cpp
Log Message:
have setSpatialReference also update the srs entry in the metadata, where this should probably be by default instead as a special data member
Commit: 83f8923c3f025ca83d980fda888f0b5a38ee1384
https://github.com/PDAL/PDAL/commit/83f8923c3f025ca83d980fda888f0b5a38ee1384
Changed paths:
M src/filters/Index.cpp
Log Message:
include guard again
Commit: ba3f7956b1d048790e9e778d16e7bb09f71a5e08
https://github.com/PDAL/PDAL/commit/ba3f7956b1d048790e9e778d16e7bb09f71a5e08
Changed paths:
M test/unit/MetadataTest.cpp
Log Message:
fix up test to reflect keeping srs in metadata
Compare: https://github.com/PDAL/PDAL/compare/37a5fbb4b068...ba3f7956b1d0
More information about the pdal-commits
