[pdal-commits] Build failed in Jenkins: PDAL #301
Github
noreply at github.com
Mon Jun 4 20:41:09 PDT 2012
See <http://jenkins.pointcloud.org/job/PDAL/301/changes>
Changes:
[hobu.inc] clean up character literal comparison that didn't have tight enough parentheses to even work anyway
[...truncated 144 lines...]
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
In file included from /var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:15:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/StageBase.cpp>:39:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp: In function ‘std::basic_string<_CharT> boost::property_tree::json_parser::create_escapes(const std::basic_string<_CharT>&) [with Ch = char]’:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:78:67: instantiated from ‘void boost::property_tree::json_parser::write_json_helper(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, int, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char]’
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:162:9: instantiated from ‘void boost::property_tree::json_parser::write_json_internal(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, const std::string&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char, std::string = std::basic_string<char>]’
/var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:98:9: instantiated from ‘void boost::property_tree::json_parser::write_json(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageBase.cpp>:265:48: instantiated from here
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:35:13: warning: comparison is always true due to limited range of data type
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/StreamFactory.cpp.o
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/ThreadEnvironment.cpp.o
In file included from /var/lib/jenkins/local/include/boost/thread/condition_variable.hpp:16:0,
from /var/lib/jenkins/local/include/boost/thread/pthread/shared_mutex.hpp:13,
from /var/lib/jenkins/local/include/boost/thread/shared_mutex.hpp:16,
from /var/lib/jenkins/local/include/boost/thread/detail/thread_group.hpp:9,
from /var/lib/jenkins/local/include/boost/thread/thread.hpp:24,
from /var/lib/jenkins/local/include/boost/thread.hpp:13,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/ThreadEnvironment.hpp>:41,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/ThreadEnvironment.cpp>:35:
/var/lib/jenkins/local/include/boost/thread/pthread/condition_variable.hpp:19:51: warning: redundant redeclaration of ‘void boost::this_thread::interruption_point()’ in same scope
/var/lib/jenkins/local/include/boost/thread/detail/thread.hpp:379:32: warning: previous declaration of ‘void boost::this_thread::interruption_point()’
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 20%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 21%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 21%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 22%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 23%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 23%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/las/GeotiffSupport.cpp>:40:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 26%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 27%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_api.h:42:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Writer.cpp>:47:
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/text/Writer.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/mpg_nitffile.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>: In function ‘mpg::NITFFile* mpg::NITFOpen(const char*, int)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>:281:55: warning: comparison between signed and unsigned integer expressions
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>: In function ‘void mpg::NITFGotoOffset(VSILFILE*, GUIntBig)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>:492:48: warning: comparison between signed and unsigned integer expressions
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>: In function ‘int mpg::NITFWriteBLOCKA(VSILFILE*, vsi_l_offset, vsi_l_offset, int*, char**)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>:1394:41: warning: comparison of unsigned expression < 0 is always false
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>: In function ‘void mpg::NITFExtractMetadata(char***, const char*, int, int, const char*)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>:1654:37: warning: comparison between signed and unsigned integer expressions
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>: In function ‘const mpg::NITFSeries* mpg::NITFGetSeriesInfo(const char*)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/nitf/mpg_nitffile.cpp>:1816:68: warning: comparison between signed and unsigned integer expressions
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/NitfFile.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Reader.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Writer.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:45:
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Predicate.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/GlobalEnvironment.hpp>:39,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Predicate.cpp>:40:
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Programmable.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Programmable.cpp>:38:
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/plang/BufferedInvocation.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/plang/PythonEnvironment.cpp.o
In file included from /usr/include/python2.7/Python.h:8:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/PythonEnvironment.cpp>:45:
/usr/include/python2.7/pyconfig.h:1155:0: warning: "_POSIX_C_SOURCE" redefined
/usr/include/features.h:163:0: note: this is the location of the previous definition
/usr/include/python2.7/pyconfig.h:1177:0: warning: "_XOPEN_SOURCE" redefined
/usr/include/features.h:165:0: note: this is the location of the previous definition
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/plang/Invocation.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Invocation.cpp>:46:
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Invocation.cpp>:36:
[ 51%] Building CXX object src/CMakeFiles/pdal.dir/plang/Redirector.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.hpp>:19,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>:12:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>: In static member function ‘static void pdal::plang::Redirector::init()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>:146:9: warning: dereferencing type-punned pointer will break strict-aliasing rules
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>: In member function ‘void pdal::plang::Redirector::set_stdout(pdal::plang::Redirector::stdout_write_type)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>:172:50: warning: deprecated conversion from string constant to ‘char*’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>:178:39: warning: deprecated conversion from string constant to ‘char*’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>: In member function ‘void pdal::plang::Redirector::reset_stdout()’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.cpp>:185:49: warning: deprecated conversion from string constant to ‘char*’
[ 52%] Building CXX object src/CMakeFiles/pdal.dir/plang/Script.cpp.o
[ 53%] Building CXX object src/CMakeFiles/pdal.dir/pdal_config.cpp.o
Linking CXX shared library ../bin/libpdal.so
[ 53%] Built target pdal
Scanning dependencies of target pc2pc
[ 53%] Building CXX object apps/CMakeFiles/pc2pc.dir/pc2pc.cpp.o
[ 54%] Building CXX object apps/CMakeFiles/pc2pc.dir/Application.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/../include/pdal/ThreadEnvironment.hpp>:41,
from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/../include/pdal/GlobalEnvironment.hpp>:39,
from <http://jenkins.pointcloud.org/job/PDAL/ws/apps/Application.cpp>:40:
[ 55%] Building CXX object apps/CMakeFiles/pc2pc.dir/AppSupport.cpp.o
Linking CXX executable ../bin/pc2pc
../bin/libpdal.so.0: undefined reference to `mpg::NITFImageDeaccess(mpg::NITFImage*)'
../bin/libpdal.so.0: undefined reference to `mpg::NITFDESDeaccess(mpg::NITFDES*)'
../bin/libpdal.so.0: undefined reference to `mpg::NITFImageAccess(mpg::NITFFile*, int)'
collect2: ld returned 1 exit status
make[2]: *** [bin/pc2pc] Error 1
make[1]: *** [apps/CMakeFiles/pc2pc.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 16: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits
