[pdal-commits] [PDAL/PDAL] 47bf75: add skip parameter to pc2pc and pcpipeline to allo...
GitHub
noreply at github.com
Tue Jun 12 12:35:03 PDT 2012
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 47bf759d6657d1c7c34d4a66bc03838078cdc275
https://github.com/PDAL/PDAL/commit/47bf759d6657d1c7c34d4a66bc03838078cdc275
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2012-06-12 (Tue, 12 Jun 2012)
Changed paths:
M apps/pc2pc.cpp
M apps/pcpipeline.cpp
Log Message:
add skip parameter to pc2pc and pcpipeline to allow you to position where to start reading
Commit: 5bcdbc6032582247297803d7be053de595496cae
https://github.com/PDAL/PDAL/commit/5bcdbc6032582247297803d7be053de595496cae
Changed paths:
M include/pdal/Utils.hpp
Log Message:
only test if the stream is .good(), don't entirely cast to bool to check stream state
Commit: fac28e4540cc5d3e18da649afbd217b5f13276b9
https://github.com/PDAL/PDAL/commit/fac28e4540cc5d3e18da649afbd217b5f13276b9
Changed paths:
M include/pdal/Writer.hpp
M src/Writer.cpp
Log Message:
add a startingPosition default argument to Writer::write to set the starting point (used in pc2pc and pcpipeline as the --skip argument
Commit: 2fe714cdcfeca9782b8478e9861c3c39740dbbd6
https://github.com/PDAL/PDAL/commit/2fe714cdcfeca9782b8478e9861c3c39740dbbd6
Changed paths:
M include/pdal/PointBuffer.hpp
Log Message:
get PointBuffer::getField out of the coversion business -- too slow to do checks inside the critical path here anyway.
Compare: https://github.com/PDAL/PDAL/compare/578d6054eabb...2fe714cdcfec
More information about the pdal-commits
