[pdal-commits] Build failed in Jenkins: PDAL #223
Github
noreply at github.com
Tue May 8 17:31:58 EDT 2012
See <http://jenkins.pointcloud.org/job/PDAL/223/changes>
Changes:
[mpg] raw addition of Mateusz's redirector code
[mpg] remove Python3 code; gratuitously refactor into a class
[...truncated 58 lines...]
-- Found Python: /usr/lib/libpython2.7.so
-- Using boost lib: optimized;/var/lib/jenkins/local/lib/libboost_program_options.a;debug;/var/lib/jenkins/local/lib/libboost_program_options.a;optimized;/var/lib/jenkins/local/lib/libboost_thread.a;debug;/var/lib/jenkins/local/lib/libboost_thread.a;optimized;/var/lib/jenkins/local/lib/libboost_iostreams.a;debug;/var/lib/jenkins/local/lib/libboost_iostreams.a;optimized;/var/lib/jenkins/local/lib/libboost_filesystem.a;debug;/var/lib/jenkins/local/lib/libboost_filesystem.a;optimized;/var/lib/jenkins/local/lib/libboost_system.a;debug;/var/lib/jenkins/local/lib/libboost_system.a;optimized;/var/lib/jenkins/local/lib/libboost_unit_test_framework.a;debug;/var/lib/jenkins/local/lib/libboost_unit_test_framework.a;optimized;/var/lib/jenkins/local/lib/libboost_random.a;debug;/var/lib/jenkins/local/lib/libboost_random.a
-- Building with PDAL unit tests
-- Static boost for boost::unit_test, not setting BOOST_TEST_DYN_LINK
-- Configuring done
-- Generating done
-- Build files have been written to: <http://jenkins.pointcloud.org/job/PDAL/ws/>
Scanning dependencies of target pdal
[ 0%] Building CXX object src/CMakeFiles/pdal.dir/GDALUtils.cpp.o
[ 1%] Building CXX object src/CMakeFiles/pdal.dir/Bounds.cpp.o
[ 2%] Building CXX object src/CMakeFiles/pdal.dir/Dimension.cpp.o
[ 2%] Building CXX object src/CMakeFiles/pdal.dir/Environment.cpp.o
[ 3%] Building CXX object src/CMakeFiles/pdal.dir/FileUtils.cpp.o
[ 4%] Building CXX object src/CMakeFiles/pdal.dir/Filter.cpp.o
[ 5%] Building CXX object src/CMakeFiles/pdal.dir/FilterIterator.cpp.o
[ 5%] Building CXX object src/CMakeFiles/pdal.dir/Log.cpp.o
[ 6%] Building CXX object src/CMakeFiles/pdal.dir/Metadata.cpp.o
In file included from /var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:15:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/Metadata.cpp>:47:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp: In function ‘std::basic_string<_CharT> boost::property_tree::json_parser::create_escapes(const std::basic_string<_CharT>&) [with Ch = char]’:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:78:67: instantiated from ‘void boost::property_tree::json_parser::write_json_helper(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, int, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char]’
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:162:9: instantiated from ‘void boost::property_tree::json_parser::write_json_internal(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, const std::string&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, std::string = std::basic_string<char>]’
/var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:98:9: instantiated from ‘void boost::property_tree::json_parser::write_json(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/Metadata.cpp>:290:60: instantiated from here
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:35:13: warning: comparison is always true due to limited range of data type
[ 7%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilter.cpp.o
[ 7%] Building CXX object src/CMakeFiles/pdal.dir/MultiFilterIterator.cpp.o
[ 8%] Building CXX object src/CMakeFiles/pdal.dir/Object.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/Object.cpp>:38:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/Object.cpp>:51:60: instantiated from here
[ 9%] Building CXX object src/CMakeFiles/pdal.dir/Options.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/Options.cpp>:39:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/Options.cpp>:273:48: instantiated from here
[ 9%] Building CXX object src/CMakeFiles/pdal.dir/PipelineManager.cpp.o
[ 10%] Building CXX object src/CMakeFiles/pdal.dir/PipelineReader.cpp.o
[ 11%] Building CXX object src/CMakeFiles/pdal.dir/PipelineWriter.cpp.o
[ 11%] Building CXX object src/CMakeFiles/pdal.dir/PointBuffer.cpp.o
[ 12%] Building CXX object src/CMakeFiles/pdal.dir/Range.cpp.o
[ 13%] Building CXX object src/CMakeFiles/pdal.dir/Reader.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/ReaderIterator.cpp.o
[ 14%] Building CXX object src/CMakeFiles/pdal.dir/Schema.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/Schema.cpp>:48:
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:78:67: instantiated from ‘void boost::property_tree::json_parser::write_json_helper(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, int, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char]’
/var/lib/jenkins/local/include/boost/property_tree/detail/json_parser_write.hpp:162:9: instantiated from ‘void boost::property_tree::json_parser::write_json_internal(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, const std::string&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char, std::string = std::basic_string<char>]’
/var/lib/jenkins/local/include/boost/property_tree/json_parser.hpp:98:9: instantiated from ‘void boost::property_tree::json_parser::write_json(std::basic_ostream<typename Ptree::key_type::value_type>&, const Ptree&, bool) [with Ptree = boost::property_tree::basic_ptree<std::basic_string<char>, std::basic_string<char> >, typename Ptree::key_type::value_type = char, typename Ptree::key_type::value_type = char]’
<http://jenkins.pointcloud.org/job/PDAL/ws/src/Schema.cpp>:506:46: instantiated from here
[ 15%] Building CXX object src/CMakeFiles/pdal.dir/SpatialReference.cpp.o
In file included from /var/lib/jenkins/local/include/ogr_srs_api.h:34:0,
from /var/lib/jenkins/local/include/ogr_spatialref.h:34,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/SpatialReference.cpp>:45:
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:58:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:58:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h: In member function ‘int OGREnvelope3D::IsInit() const’:
/var/lib/jenkins/local/include/ogr_core.h:155:42: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:55: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:68: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:81: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:94: warning: comparing floating point with == or != is unsafe
/var/lib/jenkins/local/include/ogr_core.h:155:107: warning: comparing floating point with == or != is unsafe
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/Stage.cpp.o
[ 16%] Building CXX object src/CMakeFiles/pdal.dir/StageBase.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/StageBase.cpp>:39:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/StageBase.cpp>:243:48: instantiated from here
[ 17%] Building CXX object src/CMakeFiles/pdal.dir/StageFactory.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/oci/common.hpp>:40:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/oci/Reader.hpp>:42,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/StageFactory.cpp>:45:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/oci/oci_wrapper.h>:64:61: warning: type qualifiers ignored on function return type
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/StageIterator.cpp.o
[ 18%] Building CXX object src/CMakeFiles/pdal.dir/StreamFactory.cpp.o
[ 19%] Building CXX object src/CMakeFiles/pdal.dir/UserCallback.cpp.o
[ 20%] Building CXX object src/CMakeFiles/pdal.dir/Utils.cpp.o
[ 20%] Building CXX object src/CMakeFiles/pdal.dir/Vector.cpp.o
[ 21%] Building CXX object src/CMakeFiles/pdal.dir/Writer.cpp.o
[ 22%] Building CXX object src/CMakeFiles/pdal.dir/XMLSchema.cpp.o
[ 22%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Reader.cpp.o
[ 23%] Building CXX object src/CMakeFiles/pdal.dir/drivers/faux/Writer.cpp.o
[ 24%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/GeotiffSupport.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/las/GeotiffSupport.cpp>:40:
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/ZipPoint.cpp.o
[ 25%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Header.cpp.o
[ 26%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderReader.cpp.o
[ 27%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/LasHeaderWriter.cpp.o
[ 27%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Reader.cpp.o
[ 28%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/SummaryData.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Support.cpp.o
[ 29%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/VariableLengthRecord.cpp.o
[ 30%] Building CXX object src/CMakeFiles/pdal.dir/drivers/las/Writer.cpp.o
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/oci_wrapper.cpp.o
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/oci_wrapper.cpp>:31:0:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/oci_wrapper.cpp>:2150:58: warning: type qualifiers ignored on function return type
[ 31%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/common.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/common.cpp>:36:
[ 32%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Reader.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Reader.cpp>:35:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Reader.cpp>:374:14: warning: unused parameter ‘statement’
[ 33%] Building CXX object src/CMakeFiles/pdal.dir/drivers/oci/Writer.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/../include/pdal/drivers/oci/Writer.hpp>:44,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Writer.cpp>:41:
In file included from /var/lib/jenkins/local/include/ogr_api.h:42:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/drivers/oci/Writer.cpp>:47:
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/pipeline/Reader.cpp.o
[ 34%] Building CXX object src/CMakeFiles/pdal.dir/drivers/qfit/Reader.cpp.o
[ 35%] Building CXX object src/CMakeFiles/pdal.dir/drivers/terrasolid/Reader.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/text/Writer.cpp.o
[ 36%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/NitfFile.cpp.o
[ 37%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Reader.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/drivers/nitf/Writer.cpp.o
[ 38%] Building CXX object src/CMakeFiles/pdal.dir/filters/ByteSwap.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>: In member function ‘virtual uint32_t pdal::filters::iterators::sequential::ByteSwap::readBufferImpl(pdal::PointBuffer&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/ByteSwap.cpp>:185:31: warning: unused variable ‘numSrcPointsRead’
[ 39%] Building CXX object src/CMakeFiles/pdal.dir/filters/Cache.cpp.o
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Chipper.cpp.o
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>: In member function ‘void pdal::filters::Chipper::Load(pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&, pdal::filters::chipper::RefList&)’:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Chipper.cpp>:203:25: warning: unused variable ‘num_to_read’
[ 40%] Building CXX object src/CMakeFiles/pdal.dir/filters/Color.cpp.o
[ 41%] Building CXX object src/CMakeFiles/pdal.dir/filters/Colorization.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Colorization.cpp>:45:
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Crop.cpp.o
[ 42%] Building CXX object src/CMakeFiles/pdal.dir/filters/Decimation.cpp.o
[ 43%] Building CXX object src/CMakeFiles/pdal.dir/filters/InPlaceReprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:43:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>: At global scope:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/InPlaceReprojection.cpp>:503:6: warning: unused parameter ‘buffer’
[ 44%] Building CXX object src/CMakeFiles/pdal.dir/filters/Mosaic.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/PointBufferCache.cpp.o
[ 45%] Building CXX object src/CMakeFiles/pdal.dir/filters/Predicate.cpp.o
[ 46%] Building CXX object src/CMakeFiles/pdal.dir/filters/Programmable.cpp.o
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Reprojection.cpp.o
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/filters/Reprojection.cpp>:44:
[ 47%] Building CXX object src/CMakeFiles/pdal.dir/filters/Scaling.cpp.o
[ 48%] Building CXX object src/CMakeFiles/pdal.dir/filters/Selector.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/filters/Stats.cpp.o
[ 49%] Building CXX object src/CMakeFiles/pdal.dir/plang/BufferedInvocation.cpp.o
[ 50%] Building CXX object src/CMakeFiles/pdal.dir/plang/Environment.cpp.o
In file included from /usr/include/python2.7/Python.h:8:0,
from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Environment.cpp>:45:
/usr/include/python2.7/pyconfig.h:1155:0: warning: "_POSIX_C_SOURCE" redefined
/usr/include/features.h:163:0: note: this is the location of the previous definition
/usr/include/python2.7/pyconfig.h:1177:0: warning: "_XOPEN_SOURCE" redefined
/usr/include/features.h:165:0: note: this is the location of the previous definition
In file included from <http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Environment.cpp>:46:0:
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.hpp>:42:13: error: ‘function’ in namespace ‘std’ does not name a type
<http://jenkins.pointcloud.org/job/PDAL/ws/src/plang/Redirector.hpp>:45:28: error: ‘stdout_write_type’ has not been declared
make[2]: *** [src/CMakeFiles/pdal.dir/plang/Environment.cpp.o] Error 1
make[1]: *** [src/CMakeFiles/pdal.dir/all] Error 2
make: *** [all] Error 2
test/jenkins.sh: line 16: ./bin/pdal_test: No such file or directory
Build step 'Execute shell' marked build as failure
More information about the pdal-commits
