[pdal-commits] [PDAL/PDAL] 091409: shut off unused
    GitHub
    noreply at github.com
    Wed May  9 18:12:49 EDT 2012
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 0914093d6dcd08284b9e0a55c933eceaffa61801
      https://github.com/PDAL/PDAL/commit/0914093d6dcd08284b9e0a55c933eceaffa61801
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2012-05-08 (Tue, 08 May 2012)
  Changed paths:
    M src/filters/InPlaceReprojection.cpp
  Log Message:
  shut off unused
  Commit: 287e94e8021479c6323f294b94ce241c73d3aef1
      https://github.com/PDAL/PDAL/commit/287e94e8021479c6323f294b94ce241c73d3aef1
  Changed paths:
    M include/pdal/StageBase.hpp
    M src/StageBase.cpp
  Log Message:
  option to collectMetadata from all stages into a single pdal::Metadata instance
  Commit: ee61f803eba73742d643ac4c51f5d99d8941317e
      https://github.com/PDAL/PDAL/commit/ee61f803eba73742d643ac4c51f5d99d8941317e
  Changed paths:
    M src/drivers/las/Writer.cpp
  Log Message:
  a hacky forward_metadata option that sets metadata entries of some header values using the metadata that exists in the pipeline up to this stage
  Commit: 407e3f97a1523f36721aded60241a44979310a60
      https://github.com/PDAL/PDAL/commit/407e3f97a1523f36721aded60241a44979310a60
  Changed paths:
    M src/drivers/faux/Reader.cpp
    M src/filters/Programmable.cpp
    A test/data/logtest.txt
    M test/unit/CMakeLists.txt
    A test/unit/LogTest.cpp
    M test/unit/drivers/oci/OCITest.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 934fba28028e1b57fa47d029512cf038e016e367
      https://github.com/PDAL/PDAL/commit/934fba28028e1b57fa47d029512cf038e016e367
  Changed paths:
    M apps/pcpipeline.cpp
  Log Message:
  add a --validate option to pcpipeline that does initialize() of the pipeline but does not actually execute the write() of the points. This allows pipeline-serialization to fetch metadata and the user to check some things before running a big operation
  Commit: d6ccf38e5ff178be9c1d07afdfc203231532e095
      https://github.com/PDAL/PDAL/commit/d6ccf38e5ff178be9c1d07afdfc203231532e095
  Date:   2012-05-09 (Wed, 09 May 2012)
  Changed paths:
    M apps/Application.cpp
    M include/pdal/Dimension.hpp
    R include/pdal/Environment.hpp
    A include/pdal/GlobalEnvironment.hpp
    A include/pdal/ThreadEnvironment.hpp
    M include/pdal/filters/Predicate.hpp
    M include/pdal/filters/Programmable.hpp
    R include/pdal/plang/Environment.hpp
    M include/pdal/plang/Invocation.hpp
    A include/pdal/plang/PythonEnvironment.hpp
    M src/CMakeLists.txt
    M src/Dimension.cpp
    R src/Environment.cpp
    A src/GlobalEnvironment.cpp
    M src/PipelineReader.cpp
    A src/ThreadEnvironment.cpp
    M src/drivers/oci/Reader.cpp
    M src/filters/Predicate.cpp
    R src/plang/Environment.cpp
    M src/plang/Invocation.cpp
    A src/plang/PythonEnvironment.cpp
    A src/plang/Redirector.cpp
    A src/plang/Redirector.hpp
    A test/data/log_py.txt
    M test/unit/EnvironmentTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/drivers/bpf/BPFTest.cpp
    M test/unit/main.cpp
  Log Message:
  Commit: dad386ddee36c822e532ea23ffd070eda990e1a4
      https://github.com/PDAL/PDAL/commit/dad386ddee36c822e532ea23ffd070eda990e1a4
  Changed paths:
    M test/unit/drivers/las/LasWriterTest.cpp
  Log Message:
  we can't change properties of the writer after initialize() and expect to get what we want
  Commit: 8c9536215a429d8371aa895d3a7198316f5a4945
      https://github.com/PDAL/PDAL/commit/8c9536215a429d8371aa895d3a7198316f5a4945
  Changed paths:
    M src/drivers/las/Header.cpp
  Log Message:
  default to 1.0 for scales rather than 0.01
  Commit: 85bd8a2938af75728254603a417fec190257fd27
      https://github.com/PDAL/PDAL/commit/85bd8a2938af75728254603a417fec190257fd27
  Changed paths:
  Log Message:
  reorganize metadata setting a bit, add some log noise
  Commit: c59b997ae057561107ffd5c725bfd967a88962de
      https://github.com/PDAL/PDAL/commit/c59b997ae057561107ffd5c725bfd967a88962de
  Changed paths:
  Log Message:
  move initialize() to after we set properties, not before
  Commit: 8634579dab43a823a7a999f8811782669b7a36f4
      https://github.com/PDAL/PDAL/commit/8634579dab43a823a7a999f8811782669b7a36f4
  Changed paths:
  Log Message:
  set defaults in constructor, not initialize()
  Commit: ee55934183f46bd64b03b77c3baec274302d26ca
      https://github.com/PDAL/PDAL/commit/ee55934183f46bd64b03b77c3baec274302d26ca
  Changed paths:
    M include/pdal/plang/PythonEnvironment.hpp
    M src/plang/PythonEnvironment.cpp
    M src/plang/Redirector.cpp
    M src/plang/Redirector.hpp
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/6d867e2...ee55934
More information about the pdal-commits
