[pdal-commits] [PDAL/PDAL] e3ab71: Fix segfault when reading from las into multiple b...
GitHub
noreply at github.com
Mon Jul 1 08:19:56 PDT 2013
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: e3ab7125b993542e7e793a28e3e61ec04d7279d9
https://github.com/PDAL/PDAL/commit/e3ab7125b993542e7e793a28e3e61ec04d7279d9
Author: Chris Foster <chris42f at gmail.com>
Date: 2013-06-28 (Fri, 28 Jun 2013)
Changed paths:
M include/pdal/drivers/las/Reader.hpp
M src/drivers/las/Reader.cpp
Log Message:
Fix segfault when reading from las into multiple buffers
In the presence of multiple buffers (such as the temporary buffers used
by the Mosaic stage) caching the dimensions when reading las doesn't
work: dimensions may be in different locations in different buffers.
The previously used buffers may even be deallocated, in which case the
cached dimensions will be stale pointers, leading to segfaults.
The fix here simply removes dimension caching entirely. With any
reasonable chunk size this shouldn't lead to performance degradation.
Commit: 7672ab0042ba89f106971123dd35912b801b31e3
https://github.com/PDAL/PDAL/commit/7672ab0042ba89f106971123dd35912b801b31e3
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2013-07-01 (Mon, 01 Jul 2013)
Changed paths:
Log Message:
Merge pull request #146 from c42f/las_reader_cache_dim_fix
Compare: https://github.com/PDAL/PDAL/compare/418fffb0fb0c...7672ab0042ba
More information about the pdal-commits
