[pdal-commits] [PDAL/PDAL] 9bc5f9: Fix minor memory leak of stage factory
GitHub
noreply at github.com
Thu Jul 11 09:09:24 PDT 2013
Branch: refs/heads/issues/153-make-getdimension-faster
Home: https://github.com/PDAL/PDAL
Commit: 9bc5f9a829fe029e05ea2b2867db25a7c50d7147
https://github.com/PDAL/PDAL/commit/9bc5f9a829fe029e05ea2b2867db25a7c50d7147
Author: Chris Foster <chris42f at gmail.com>
Date: 2013-07-10 (Wed, 10 Jul 2013)
Changed paths:
M apps/AppSupport.cpp
Log Message:
Commit: edf66e1b38598cee0861ba4685e242c345ec1165
https://github.com/PDAL/PDAL/commit/edf66e1b38598cee0861ba4685e242c345ec1165
Changed paths:
M CMakeLists.txt
M src/drivers/las/Header.cpp
M src/drivers/las/Writer.cpp
M src/filters/HexBin.cpp
M src/filters/Selector.cpp
Log Message:
Fix various compiler warnings
* Mark boost and python headers as system headers to avoid a pile of
(mostly boost) warnings in headers we don't control.
* Remove assertion about the return value of memcpy, because memcpy
unconditionally returns the dest buffer regardless of success.
* Avoid unused variable warnings
- When building without hexer
- Due to variables only used in asserts
- Unused endianess variable
* Fix bug in las writer when reading uint8_t intensity from buffer,
which would have accessed a bogus pointer and caused a segfault.
Commit: 65e4b31ee2d8d8fe32d05e186f79b65e29ebf1e8
https://github.com/PDAL/PDAL/commit/65e4b31ee2d8d8fe32d05e186f79b65e29ebf1e8
Author: Howard Butler <hobu.inc at gmail.com>
Changed paths:
M include/pdal/PointBuffer.hpp
M src/PointBuffer.cpp
Log Message:
add reset and default constructor
Commit: 971024bb953c4d3ebd35b3a7092a3a009dec8cbf
https://github.com/PDAL/PDAL/commit/971024bb953c4d3ebd35b3a7092a3a009dec8cbf
Date: 2013-07-11 (Thu, 11 Jul 2013)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #158 from c42f/cjf-warnings-fix
Fix various compiler warnings and minor bugs
Commit: 62cfe2cbe2bf8747299c8b55ac056362113eb78b
https://github.com/PDAL/PDAL/commit/62cfe2cbe2bf8747299c8b55ac056362113eb78b
Changed paths:
M CMakeLists.txt
Log Message:
Merge branch 'master' into issues/153-make-getdimension-faster
Commit: 55aa8bcca9e873e93f2257b01b8d231a636bdf7c
https://github.com/PDAL/PDAL/commit/55aa8bcca9e873e93f2257b01b8d231a636bdf7c
Changed paths:
M src/drivers/las/Support.cpp
Log Message:
macroize the dimension caching method
Compare: https://github.com/PDAL/PDAL/compare/2d738d0d2033...55aa8bcca9e8
More information about the pdal-commits
