[pdal-commits] [PDAL/PDAL] 24a0d4: some interprocess scaffolding, nothing done yet
GitHub noreply at github.com
Thu Oct 3 08:53:58 PDT 2013
  Branch: refs/heads/issues/180-sqlite-driver
  Home:   https://github.com/PDAL/PDAL
  Commit: 24a0d430aba7f73329a4477fca9fecefd36bc2e3
      https://github.com/PDAL/PDAL/commit/24a0d430aba7f73329a4477fca9fecefd36bc2e3
  Author: Howard Butler <howard at hobu.co>
  Date:   2013-09-27 (Fri, 27 Sep 2013)
  Changed paths:
    M include/pdal/PointBuffer.hpp
    M src/PointBuffer.cpp
  Log Message:
  Commit: 43fa812bbe14ca3580ccfff5893d938b3b59a232
      https://github.com/PDAL/PDAL/commit/43fa812bbe14ca3580ccfff5893d938b3b59a232
  Author: Mateusz Loskot <mateusz at loskot.net>
  Date:   2013-09-29 (Sun, 29 Sep 2013)
  Changed paths:
  Log Message:
  Do not ignore non-existent variables
Fix build issue reported on IRC by Massimo Di Stefano
  Commit: 06ba110c9a1b5696e6147243ebcf89fefcb104b2
      https://github.com/PDAL/PDAL/commit/06ba110c9a1b5696e6147243ebcf89fefcb104b2
  Date:   2013-10-01 (Tue, 01 Oct 2013)
  Changed paths:
    M src/filters/Cache.cpp
  Log Message:
  never add to cache from random iterator
Conflicts:
  Commit: 5c43edd66733a7d86d5130ae8a8f4c003f9dd284
      https://github.com/PDAL/PDAL/commit/5c43edd66733a7d86d5130ae8a8f4c003f9dd284
  Changed paths:
  Log Message:
  tighten up the 64bit calculations for PointBuffer offsets
  Commit: 13b11f25f6ce440f19f6a75d6060e0d0542940c0
      https://github.com/PDAL/PDAL/commit/13b11f25f6ce440f19f6a75d6060e0d0542940c0
  Changed paths:
    M src/drivers/las/Reader.cpp
  Log Message:
  make sure to use 64bit math for calculating buffer position when reading data
  Commit: e5e3a7a1ae67cd6cd894e05cb57ab83a9342e4f0
      https://github.com/PDAL/PDAL/commit/e5e3a7a1ae67cd6cd894e05cb57ab83a9342e4f0
  Changed paths:
  Log Message:
  Merge branch 'master' into issues/181-boost-interprocess-pointbuffer
Conflicts:
  Commit: 1c167cdf61da0c356e3d2753710174cef528abe3
      https://github.com/PDAL/PDAL/commit/1c167cdf61da0c356e3d2753710174cef528abe3
  Changed paths:
    M include/pdal/filters/Cache.hpp
    M src/drivers/buffer/Reader.cpp
    M test/unit/PointBufferTest.cpp
  Log Message:
  put DimensionMap and PointBufferByteSize into a pointbuffer:: namespace
  Commit: 2224aa76d7543c18957d74f256ac21630a03acbe
      https://github.com/PDAL/PDAL/commit/2224aa76d7543c18957d74f256ac21630a03acbe
  Date:   2013-10-02 (Wed, 02 Oct 2013)
  Changed paths:
    M include/pdal/GlobalEnvironment.hpp
  Log Message:
  a map to keep track of globally allocated memory segments
  Commit: 760d3eca3f0b564421a88d0d8eb36fd679d846a5
      https://github.com/PDAL/PDAL/commit/760d3eca3f0b564421a88d0d8eb36fd679d846a5
  Changed paths:
    M CMakeLists.txt
    M src/CMakeLists.txt
    M test/unit/CMakeLists.txt
  Log Message:
  quote path names for #182
  Commit: 68ae933c4637564a351191f17e7497fa48e2e918
      https://github.com/PDAL/PDAL/commit/68ae933c4637564a351191f17e7497fa48e2e918
  Changed paths:
    M CMakeLists.txt
  Log Message:
  include_directories can't have empty strings, so unquote those for now
  Commit: 08fbaf4d839c6a52014e3b12d8823a41922e737f
      https://github.com/PDAL/PDAL/commit/08fbaf4d839c6a52014e3b12d8823a41922e737f
  Changed paths:
    M include/pdal/drivers/pgpointcloud/Reader.hpp
  Log Message:
  fix pdal::poitncloud::DimensionMap member variable for rename in #181
  Commit: 1f9f4b99ec051454eafd2b2338ff4d558322e501
      https://github.com/PDAL/PDAL/commit/1f9f4b99ec051454eafd2b2338ff4d558322e501
  Changed paths:
  Log Message:
  typo'd 08fbaf4d839c6a52014e3b12d8823a41922e737f
  Commit: adab5211f12b15f5a359cd8f13c0758995067756
      https://github.com/PDAL/PDAL/commit/adab5211f12b15f5a359cd8f13c0758995067756
  Date:   2013-10-03 (Thu, 03 Oct 2013)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #182 from PDAL/issues/182-cmake-cleanup
Complete quoting for parameters of some CMake commands
  Commit: bce00e703e48c637a2b20100a90623d74e249338
      https://github.com/PDAL/PDAL/commit/bce00e703e48c637a2b20100a90623d74e249338
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'master' into issues/180-sqlite-driver
Conflicts:
	src/CMakeLists.txt
Compare: https://github.com/PDAL/PDAL/compare/d80934a4d7e8...bce00e703e48
More information about the pdal-commits mailing list
