[pdal-commits] [PDAL/PDAL] 8bd3e0: do a proper check to find out of PointSourceId dim...
GitHub
noreply at github.com
Fri Oct 11 13:48:33 PDT 2013
Branch: refs/heads/issues/192-merge-pc2pc-pcpipeline
Home: https://github.com/PDAL/PDAL
Commit: 8bd3e09d07000888b88a4c8390b88ec3402f8799
https://github.com/PDAL/PDAL/commit/8bd3e09d07000888b88a4c8390b88ec3402f8799
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2013-10-09 (Wed, 09 Oct 2013)
Changed paths:
M src/drivers/oci/Reader.cpp
Log Message:
do a proper check to find out of PointSourceId dimension is available for #193
Commit: f60c307285e5ca7a7f009c9e1b75414b91564769
https://github.com/PDAL/PDAL/commit/f60c307285e5ca7a7f009c9e1b75414b91564769
Author: Howard Butler <howard at hobu.co>
Date: 2013-10-10 (Thu, 10 Oct 2013)
Changed paths:
Log Message:
Merge pull request #193 from PDAL/issues/193-populate-pointsourceid
populate_pointsourceid is broken if there's no PointSourceId dimension
Commit: 5e6f86755b6ce6be84b4d78aad69c0652492639f
https://github.com/PDAL/PDAL/commit/5e6f86755b6ce6be84b4d78aad69c0652492639f
Changed paths:
Log Message:
Commit: 65391776336fc164bd63ffb956dbdaca104489d9
https://github.com/PDAL/PDAL/commit/65391776336fc164bd63ffb956dbdaca104489d9
Author: Paul Ramsey <pramsey at opengeo.org>
Changed paths:
A doc/pipeline/drivers.p2g.writer.txt
M doc/pipeline/index.txt
Log Message:
p2g writer
Commit: 79a8454c1e93595eac8eea7e891e540d287e3a7f
https://github.com/PDAL/PDAL/commit/79a8454c1e93595eac8eea7e891e540d287e3a7f
Changed paths:
A doc/pipeline/drivers.qfit.reader.txt
Log Message:
drivers.qfit.reader
Commit: 14e46ffb76ce6b34e9e8d509c7ec4afc62df407e
https://github.com/PDAL/PDAL/commit/14e46ffb76ce6b34e9e8d509c7ec4afc62df407e
Changed paths:
M src/filters/InPlaceReprojection.cpp
Log Message:
Fix #194, default to specified offsets instead of throwing an exception when their reprojection fails
Commit: 07a8a208bf456b9cf6b24a2bfb61f96827b30ef8
https://github.com/PDAL/PDAL/commit/07a8a208bf456b9cf6b24a2bfb61f96827b30ef8
Changed paths:
M src/filters/HexBin.cpp
Log Message:
don't throw in filters.hexer's destructor
Commit: db64c35f83ee1648d3a04e965439e781ab890437
https://github.com/PDAL/PDAL/commit/db64c35f83ee1648d3a04e965439e781ab890437
Changed paths:
A doc/pipeline/drivers.text.writer.txt
M doc/pipeline/filters.hexbin.txt
Log Message:
drivers.text.writer
Commit: 4225a5bbb5e5c19f4fa685972a224c355ba8777a
https://github.com/PDAL/PDAL/commit/4225a5bbb5e5c19f4fa685972a224c355ba8777a
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Conflicts:
Commit: fa160fdafcd9b2e4607ddeb00ef4679c0830c551
https://github.com/PDAL/PDAL/commit/fa160fdafcd9b2e4607ddeb00ef4679c0830c551
Date: 2013-10-11 (Fri, 11 Oct 2013)
Changed paths:
M include/pdal/third/nanoflann.hpp
Log Message:
update nanoflann
Commit: 68a507eea83e1a95dc5ccdfb53ec9481a72a23b7
https://github.com/PDAL/PDAL/commit/68a507eea83e1a95dc5ccdfb53ec9481a72a23b7
Changed paths:
Log Message:
remove ticks
Commit: 23dbaffe11cf3ee0f382aab9b596f798bbce4355
https://github.com/PDAL/PDAL/commit/23dbaffe11cf3ee0f382aab9b596f798bbce4355
Changed paths:
Log Message:
update blocksize parameter
Commit: e52664f3617883c142b88551f20fe7c93c5e23d0
https://github.com/PDAL/PDAL/commit/e52664f3617883c142b88551f20fe7c93c5e23d0
Changed paths:
Log Message:
Commit: 46ff5140610a7f33105d7df1bf8082f0657479ef
https://github.com/PDAL/PDAL/commit/46ff5140610a7f33105d7df1bf8082f0657479ef
Changed paths:
M apps/pcequal.cpp
M apps/pdalinfo.cpp
M include/pdal/PointBuffer.hpp
M src/PointBuffer.cpp
M test/unit/PointBufferTest.cpp
Log Message:
make IndexedPointBuffer based on nanoflann instead of FLANN to remove external dependency #176
Commit: a83ac953f5b5b1956ec6c52937d7bc4b60ff3aa8
https://github.com/PDAL/PDAL/commit/a83ac953f5b5b1956ec6c52937d7bc4b60ff3aa8
Changed paths:
Log Message:
fix up dimensionality so both 2d and 3d indexes work properly
Commit: 8843645e113b4c6cee3711a7d8f429c6ee78b558
https://github.com/PDAL/PDAL/commit/8843645e113b4c6cee3711a7d8f429c6ee78b558
Changed paths:
M CMakeLists.txt
M apps/pcequal.cpp
M include/pdal/drivers/soci/Writer.hpp
R include/pdal/filters/Index.hpp
M pdal_defines.h.in
M src/CMakeLists.txt
M src/StageFactory.cpp
M src/drivers/soci/Writer.cpp
R src/filters/Index.cpp
M test/unit/CMakeLists.txt
R test/unit/filters/IndexFilterTest.cpp
Log Message:
filters.index is no more. Use the IndexedPointBuffer instead
Commit: 3b67d09ca34a14ce30a2938cb9e905f4e6266996
https://github.com/PDAL/PDAL/commit/3b67d09ca34a14ce30a2938cb9e905f4e6266996
Changed paths:
M CMakeLists.txt
M apps/pcequal.cpp
M apps/pdalinfo.cpp
M pdal_defines.h.in
Log Message:
Merge branch 'master' into issues/192-merge-pc2pc-pcpipeline
Compare: https://github.com/PDAL/PDAL/compare/d6bd5e23406f...3b67d09ca34a
More information about the pdal-commits
