[pdal-commits] [PDAL/PDAL] 8dbc74: turn on app tests, make tests work with new pdal::...
GitHub noreply at github.com
Tue Oct 15 19:02:51 PDT 2013
  Branch: refs/heads/issues/192-merge-pc2pc-pcpipeline
  Home:   https://github.com/PDAL/PDAL
  Commit: 8dbc746f40750e5d82cdfff7a21d5dbcaffce3d0
      https://github.com/PDAL/PDAL/commit/8dbc746f40750e5d82cdfff7a21d5dbcaffce3d0
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2013-10-15 (Tue, 15 Oct 2013)
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/kernel/Application.hpp
    M include/pdal/kernel/Info.hpp
    M include/pdal/kernel/Pipeline.hpp
    M include/pdal/kernel/Translate.hpp
    M src/kernel/Application.cpp
    M src/kernel/Info.cpp
    M src/kernel/Pipeline.cpp
    M src/kernel/Query.cpp
    R test/data/apps/pcinfo_point.txt
    R test/data/apps/pcinfo_schema.txt
    R test/data/apps/pcinfo_stage.txt
    R test/data/apps/pcinfo_stage_nosrs.txt
    R test/data/apps/pcinfo_stats-win32.txt
    R test/data/apps/pcinfo_stats.txt
    A test/data/apps/pdainfo_stats-win32.txt
    A test/data/apps/pdalinfo_point.txt
    A test/data/apps/pdalinfo_schema.txt
    A test/data/apps/pdalinfo_stage.txt
    A test/data/apps/pdalinfo_stage_nosrs.txt
    A test/data/apps/pdalinfo_stats.txt
    M test/unit/CMakeLists.txt
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcinfoTest.cpp
    M test/unit/apps/pcpipelineTest.cpp
    M test/unit/drivers/oci/OCITest.cpp
    M test/unit/drivers/soci/Writer.cpp
  Log Message:
  turn on app tests, make tests work with new pdal::kernel::
More information about the pdal-commits mailing list
