[pdal-commits] [PDAL/PDAL] 77593f: silence annoying warning now that boost is not a S...
    GitHub
    noreply at github.com
    Thu Sep 26 13:26:14 PDT 2013
  Branch: refs/heads/issues/180-sqlite-driver
  Home:   https://github.com/PDAL/PDAL
  Commit: 77593f51d1d860466ea78bd1aaacdc9ebd0375f4
      https://github.com/PDAL/PDAL/commit/77593f51d1d860466ea78bd1aaacdc9ebd0375f4
  Author: Howard Butler <howard at hobu.co>
  Date:   2013-09-03 (Tue, 03 Sep 2013)
  Changed paths:
    M boost/boost/functional/hash/detail/hash_float.hpp
  Log Message:
  silence annoying warning now that boost is not a SYSTEM include again
  Commit: d2fdfc0f36f5e20c9456b0978a64d5e6e609b6e8
      https://github.com/PDAL/PDAL/commit/d2fdfc0f36f5e20c9456b0978a64d5e6e609b6e8
  Changed paths:
    M include/pdal/PointBuffer.hpp
    M src/PointBuffer.cpp
    M src/filters/Index.cpp
    M test/unit/PointBufferTest.cpp
  Log Message:
  some scaffolding for IndexedPointBuffer, including adding PointBuffer::applyScaling method to bring up from filters
  Commit: 8544ad36d449c6349e02a6dae3564dda4df49bcf
      https://github.com/PDAL/PDAL/commit/8544ad36d449c6349e02a6dae3564dda4df49bcf
  Date:   2013-09-04 (Wed, 04 Sep 2013)
  Changed paths:
    M include/pdal/filters/Colorization.hpp
    M include/pdal/filters/Crop.hpp
    M include/pdal/filters/InPlaceReprojection.hpp
    M src/filters/Colorization.cpp
    M src/filters/Crop.cpp
    M src/filters/InPlaceReprojection.cpp
  Log Message:
  remove dead getScaledValue code that has been put into PointBuffer::applyScaling so as to not copy it all over the place
  Commit: c9076d4038f16c77018457448c4a456bcf8227ed
      https://github.com/PDAL/PDAL/commit/c9076d4038f16c77018457448c4a456bcf8227ed
  Date:   2013-09-06 (Fri, 06 Sep 2013)
  Changed paths:
  Log Message:
  FLANN-based index for nearest, not yet radius
  Commit: 7b492774d98c29a4bddb9fb36742e5ebb2769641
      https://github.com/PDAL/PDAL/commit/7b492774d98c29a4bddb9fb36742e5ebb2769641
  Changed paths:
    M include/pdal/filters/Scaling.hpp
  Log Message:
  add note for #177
  Commit: 8468e4ffdfcf37cbc13f7727596be32de5b5a5c1
      https://github.com/PDAL/PDAL/commit/8468e4ffdfcf37cbc13f7727596be32de5b5a5c1
  Date:   2013-09-18 (Wed, 18 Sep 2013)
  Changed paths:
  Log Message:
  Commit: f0b290589ed171046d54f24a4d7db3cc03263fac
      https://github.com/PDAL/PDAL/commit/f0b290589ed171046d54f24a4d7db3cc03263fac
  Date:   2013-09-19 (Thu, 19 Sep 2013)
  Changed paths:
  Log Message:
  Merge branch 'issues/177-scaling-filter'
  Commit: 756fffbd298c1524c06aaa23211f371329ad0e03
      https://github.com/PDAL/PDAL/commit/756fffbd298c1524c06aaa23211f371329ad0e03
  Date:   2013-09-20 (Fri, 20 Sep 2013)
  Changed paths:
  Log Message:
  clean up definition of buffer's byte sizes to use a single typedef instead of uint64_t's
  Commit: 6023c12b93998cc44996c46600c778b2a4e75208
      https://github.com/PDAL/PDAL/commit/6023c12b93998cc44996c46600c778b2a4e75208
  Date:   2013-09-23 (Mon, 23 Sep 2013)
  Changed paths:
    M src/filters/Cache.cpp
  Log Message:
  clean up dimension maps when destructing filters.cache iterator
  Commit: 2ce11e18c969143e19eb87e979ab5a68dae7804b
      https://github.com/PDAL/PDAL/commit/2ce11e18c969143e19eb87e979ab5a68dae7804b
  Changed paths:
    M src/drivers/las/SummaryData.cpp
  Log Message:
  turn off return number data checks for now
  Commit: ffe49c508780c3c393a476219f2535a40ffe8d8e
      https://github.com/PDAL/PDAL/commit/ffe49c508780c3c393a476219f2535a40ffe8d8e
  Changed paths:
  Log Message:
  clean up PointBuffer's byte size calculations to be more clear
  Commit: 61489f28eb1686464dd75674fb54e05adbd68088
      https://github.com/PDAL/PDAL/commit/61489f28eb1686464dd75674fb54e05adbd68088
  Author: Howard Butler <hobu.inc at gmail.com>
  Changed paths:
    M src/Writer.cpp
  Log Message:
  merge 01c84eb5ebc2314c3afbae66e6c7db01a85b2c74 into master make sure to writeBufferBegin, even if we're not writing any points, so we can write 0-point files
Conflicts:
	src/Writer.cpp
  Commit: cc7ff7ff3b75b82318aabef45d9e37eab3fbf47f
      https://github.com/PDAL/PDAL/commit/cc7ff7ff3b75b82318aabef45d9e37eab3fbf47f
  Changed paths:
  Log Message:
  can't call methods until we're actually constructed
  Commit: 7834135058a9a8b327b6916c15c83dda1ba91b0e
      https://github.com/PDAL/PDAL/commit/7834135058a9a8b327b6916c15c83dda1ba91b0e
  Date:   2013-09-26 (Thu, 26 Sep 2013)
  Changed paths:
  Log Message:
  turn off radiusSearch because it is causing Travis to fail
  Commit: 9dba0d400fcda5c8827e14a77ea0d1ff48fa06d1
      https://github.com/PDAL/PDAL/commit/9dba0d400fcda5c8827e14a77ea0d1ff48fa06d1
  Changed paths:
    M test/unit/filters/CacheFilterTest.cpp
  Log Message:
  add large cache example (but mostly turned off for now due to the memory allocation taking forever
  Commit: d80934a4d7e8b5b8acb95050bf9773bfe1462fee
      https://github.com/PDAL/PDAL/commit/d80934a4d7e8b5b8acb95050bf9773bfe1462fee
  Changed paths:
    M src/Writer.cpp
  Log Message:
  Merge branch 'master' into issues/180-sqlite-driver
Compare: https://github.com/PDAL/PDAL/compare/b9bf12a73efc...d80934a4d7e8
More information about the pdal-commits
