[pdal-commits] [PDAL/PDAL] 1c0bb7: Customize Vagrantfile with environment variables
GitHub
noreply at github.com
Wed Apr 16 10:20:54 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 1c0bb7f17909a79300bfd3634f0b607d65b07af5
https://github.com/PDAL/PDAL/commit/1c0bb7f17909a79300bfd3634f0b607d65b07af5
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2014-04-16 (Wed, 16 Apr 2014)
Changed paths:
M Vagrantfile
Log Message:
This patch adds the ability for some `PDAL_VAGRANT_` prefixed
environment variables to customize the behavior of PDAL's Vagrantfile.
The general policy is to provide a 'switch' environment variable that
enables or disables a given behavior when the environment variable is
set to *any* value. For example, the variable
`PDAL_VAGRANT_DISABLE_NFS`, predictably, disables nfs mounting. A few
special cases actually use the value of the environment variable for
customization, usually some sort of integer value (e.g.
`PDAL_VAGRANT_VIRTUALBOX_MEMORY`).
This patch adds the following environment variables:
- `PDAL_VAGRANT_PORT_80_FORWARD`: set or disable forwarding from guest
port 80. If an integer value, set the host port. If non-integer or
zero, disable port forwarding for guest port 80.
- `PDAL_VAGRANT_VIRTUALBOX_MEMORY`: set or disable a custom memory value
for a VirtualBox vm.
- `PDAL_VAGRANT_VIRTUALBOX_CPUS`: set or disable a custom cpu value for
a VirtualBox vm.
- `PDAL_VAGRANT_VIRTUALBOX_IOAPIC`: set VirtualBox ioapic value.
- `PDAL_VAGRANT_VIRTUALBOX_ENABLE_GUI`: set to any value to turn on the
VirtualBox gui.
- `PDAL_VAGRANT_PRIVATE_NETWORK_IP`: set or diable a private network IP
for the vm.
- `PDAL_VAGRANT_DIABLE_NFS`: disable nfs mounting
The following values were added previously in
35b355f39b5d88801eeb80dfe038df05ed6c72fb, and are included here for
completeness:
- `PDAL_VAGRANT_SSH_FORWARD_AGENT`: enable ssh agent forwarding.
This patch closes #311.
Commit: 54a6b08b730768088257d149dbae43403b3bdf79
https://github.com/PDAL/PDAL/commit/54a6b08b730768088257d149dbae43403b3bdf79
Author: Howard Butler <howard at hobu.co>
Changed paths:
M Vagrantfile
Log Message:
Merge pull request #313 from PDAL/issues/311-configure-vagrant-with-envvars
Compare: https://github.com/PDAL/PDAL/compare/9f07d65dfb21...54a6b08b7307
More information about the pdal-commits
