[pdal-commits] [PDAL/PDAL] d7b786: Remove m_pointCountType and references
GitHub
noreply at github.com
Tue Apr 29 12:25:53 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d7b786eb124953321a3b7682e0a85869f2dac149
https://github.com/PDAL/PDAL/commit/d7b786eb124953321a3b7682e0a85869f2dac149
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2014-04-29 (Tue, 29 Apr 2014)
Changed paths:
M include/pdal/Stage.hpp
M include/pdal/pdal_types.hpp
M src/Stage.cpp
M src/drivers/buffer/Reader.cpp
M src/drivers/faux/Reader.cpp
M src/drivers/mrsid/Reader.cpp
M src/drivers/pipeline/Reader.cpp
M src/drivers/qfit/Reader.cpp
M src/filters/ByteSwap.cpp
M src/filters/Chipper.cpp
M src/filters/Crop.cpp
M src/filters/Mosaic.cpp
M test/data/apps/pdalinfo_stage.txt
M test/data/apps/pdalinfo_stage_nosrs.txt
M test/unit/drivers/sbet/SbetReaderTest.cpp
Log Message:
Per discussion in #328, pointCountType is not and will mostly likely not
be used. This patch removes the member variable from Stage and all
references to that variable and its associated methods.
Closes #329.
Commit: 3e35b2e461aba47853e08ee0c93148709e6a8a1a
https://github.com/PDAL/PDAL/commit/3e35b2e461aba47853e08ee0c93148709e6a8a1a
Author: Howard Butler <howard at hobu.co>
Changed paths:
M src/Stage.cpp
Log Message:
Merge pull request #330 from gadomski/issue/329-remove-pointcounttype
Compare: https://github.com/PDAL/PDAL/compare/7a666ddfc21c...3e35b2e461ab
More information about the pdal-commits
