[pdal-commits] [PDAL/PDAL] 6b97da: Merge filter and test.
GitHub noreply at github.com
Fri Aug 15 14:42:06 PDT 2014
  Branch: refs/heads/point-context-schema
  Home:   https://github.com/PDAL/PDAL
  Commit: 6b97dac23184cabfdf91030ed36b70a8b614d16c
      https://github.com/PDAL/PDAL/commit/6b97dac23184cabfdf91030ed36b70a8b614d16c
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2014-08-15 (Fri, 15 Aug 2014)
  Changed paths:
    M include/pdal/Filter.hpp
    M include/pdal/Filters.hpp
    R include/pdal/MultiFilter.hpp
    R include/pdal/MultiFilterIterator.hpp
    M include/pdal/PipelineManager.hpp
    M include/pdal/PipelineReader.hpp
    M include/pdal/PointBuffer.hpp
    R include/pdal/Schema.hpp
    M include/pdal/StageFactory.hpp
    A include/pdal/filters/Merge.hpp
    R include/pdal/filters/Mosaic.hpp
    M include/pdal/pdal_macros.hpp
    M src/CMakeLists.txt
    M src/Filter.cpp
    R src/MultiFilter.cpp
    R src/MultiFilterIterator.cpp
    M src/PipelineManager.cpp
    M src/PipelineReader.cpp
    M src/PipelineWriter.cpp
    M src/StageFactory.cpp
    R src/filters/Mosaic.cpp
    M src/kernel/Info.cpp
    A test/data/pipeline/merge.xml
    M test/unit/CMakeLists.txt
    M test/unit/PipelineManagerTest.cpp
    A test/unit/filters/MergeTest.cpp
    R test/unit/filters/MosaicFilterTest.cpp
  Log Message:
Modify PipelineReader to support merge filter.
Remove old MultiFilter handling.
Remove Schema, MultiFilter, MultiFilterIterator
  Commit: 89fbca1b169a9fe0a5cac620b0fb2ea04beb79c9
      https://github.com/PDAL/PDAL/commit/89fbca1b169a9fe0a5cac620b0fb2ea04beb79c9
  Changed paths:
    M include/pdal/Metadata.hpp
    M include/pdal/Stage.hpp
    M include/pdal/filters/Stats.hpp
    M include/pdal/kernel/Info.hpp
    M src/Metadata.cpp
    M src/filters/Stats.cpp
  Log Message:
  Merge branch 'point-context-schema' of https://github.com/PDAL/PDAL into point-context-schema
Conflicts:
	src/kernel/Info.cpp
Compare: https://github.com/PDAL/PDAL/compare/90ca3f906b50...89fbca1b169a
More information about the pdal-commits mailing list
