[pdal-commits] [PDAL/PDAL] 3e10f7: Metadata lists.
GitHub
noreply at github.com
Tue Aug 26 12:52:07 PDT 2014
Branch: refs/heads/point-context-schema
Home: https://github.com/PDAL/PDAL
Commit: 3e10f7bdf258355b380c2376e55079a771a631c5
https://github.com/PDAL/PDAL/commit/3e10f7bdf258355b380c2376e55079a771a631c5
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2014-08-26 (Tue, 26 Aug 2014)
Changed paths:
M include/pdal/Metadata.hpp
M include/pdal/PipelineManager.hpp
M include/pdal/kernel/Info.hpp
M src/Metadata.cpp
M src/kernel/Info.cpp
M test/data/filters/hexbin.txt
Log Message:
Metadata lists.
Commit: 2beb0c122fcfbe36402f76817850840ed02e4dea
https://github.com/PDAL/PDAL/commit/2beb0c122fcfbe36402f76817850840ed02e4dea
Changed paths:
M doc/stages/drivers.las.writer.txt
M include/pdal/KDIndex.hpp
M include/pdal/Stage.hpp
M include/pdal/drivers/faux/Reader.hpp
M include/pdal/drivers/las/Writer.hpp
M src/Filter.cpp
M src/Stage.cpp
M src/Writer.cpp
M src/drivers/faux/Reader.cpp
M src/drivers/las/Writer.cpp
M src/kernel/Application.cpp
M src/kernel/Pipeline.cpp
A test/data/filters/chipper.xml
A test/data/filters/splitter.xml
R test/data/pipeline/chipper.xml
R test/data/pipeline/splitter.xml
M test/unit/drivers/faux/FauxReaderTest.cpp
M test/unit/drivers/las/LasWriterTest.cpp
Log Message:
Merge branch 'point-context-schema' of https://github.com/PDAL/PDAL into point-context-schema
Commit: ea239d9f8edb235f60394263aae5edd92a1dd1ad
https://github.com/PDAL/PDAL/commit/ea239d9f8edb235f60394263aae5edd92a1dd1ad
Changed paths:
M src/PipelineManager.cpp
M src/filters/HexBin.cpp
M src/filters/Stats.cpp
Log Message:
Use Metadata::addList for arrays.
Make sure stage metadata parent has a name.
Compare: https://github.com/PDAL/PDAL/compare/adc227e48c32...ea239d9f8edb
More information about the pdal-commits
