[pdal-commits] [PDAL/PDAL] 6a4bf9: Port ALL kernels
GitHub noreply at github.com
Wed Dec 3 06:42:34 PST 2014
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 6a4bf9dcb0b159cf737ad84e73fd12bf3d66309a
      https://github.com/PDAL/PDAL/commit/6a4bf9dcb0b159cf737ad84e73fd12bf3d66309a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2014-12-02 (Tue, 02 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/pdal.cpp
    M doc/tutorial/writing.rst
    A include/pdal/Kernels.hpp
    R include/pdal/kernel/Application.hpp
    R include/pdal/kernel/Delta.hpp
    R include/pdal/kernel/Diff.hpp
    R include/pdal/kernel/Info.hpp
    R include/pdal/kernel/Kernel.hpp
    R include/pdal/kernel/KernelFactory.hpp
    R include/pdal/kernel/KernelInfo.hpp
    R include/pdal/kernel/Kernels.hpp
    R include/pdal/kernel/Pipeline.hpp
    R include/pdal/kernel/Random.hpp
    R include/pdal/kernel/Sort.hpp
    R include/pdal/kernel/Support.hpp
    R include/pdal/kernel/Translate.hpp
    A kernels/Application.hpp
    A kernels/CMakeLists.txt
    A kernels/Kernel.cpp
    A kernels/Kernel.hpp
    A kernels/KernelFactory.cpp
    A kernels/KernelFactory.hpp
    A kernels/KernelInfo.cpp
    A kernels/KernelInfo.hpp
    A kernels/KernelSupport.cpp
    A kernels/KernelSupport.hpp
    A kernels/delta/CMakeLists.txt
    A kernels/delta/DeltaKernel.cpp
    A kernels/delta/DeltaKernel.hpp
    A kernels/diff/CMakeLists.txt
    A kernels/diff/DiffKernel.cpp
    A kernels/diff/DiffKernel.hpp
    A kernels/info/CMakeLists.txt
    A kernels/info/InfoKernel.cpp
    A kernels/info/InfoKernel.hpp
    A kernels/pipeline/CMakeLists.txt
    A kernels/pipeline/PipelineKernel.cpp
    A kernels/pipeline/PipelineKernel.hpp
    A kernels/random/CMakeLists.txt
    A kernels/random/RandomKernel.cpp
    A kernels/random/RandomKernel.hpp
    A kernels/sort/CMakeLists.txt
    A kernels/sort/SortKernel.cpp
    A kernels/sort/SortKernel.hpp
    A kernels/translate/CMakeLists.txt
    A kernels/translate/TranslateKernel.cpp
    A kernels/translate/TranslateKernel.hpp
    M plugins/pcl/CMakeLists.txt
    R plugins/pcl/kernel/Ground.cpp
    R plugins/pcl/kernel/Ground.hpp
    A plugins/pcl/kernel/GroundKernel.cpp
    A plugins/pcl/kernel/GroundKernel.hpp
    R plugins/pcl/kernel/PCL.cpp
    R plugins/pcl/kernel/PCL.hpp
    A plugins/pcl/kernel/PCLKernel.cpp
    A plugins/pcl/kernel/PCLKernel.hpp
    R plugins/pcl/kernel/Smooth.cpp
    R plugins/pcl/kernel/Smooth.hpp
    A plugins/pcl/kernel/SmoothKernel.cpp
    A plugins/pcl/kernel/SmoothKernel.hpp
    R plugins/pcl/kernel/View.cpp
    R plugins/pcl/kernel/View.hpp
    A plugins/pcl/kernel/ViewKernel.cpp
    A plugins/pcl/kernel/ViewKernel.hpp
    M src/CMakeLists.txt
    R src/kernel/Delta.cpp
    R src/kernel/Diff.cpp
    R src/kernel/Info.cpp
    R src/kernel/Kernel.cpp
    R src/kernel/KernelFactory.cpp
    R src/kernel/KernelInfo.cpp
    R src/kernel/Pipeline.cpp
    R src/kernel/Random.cpp
    R src/kernel/Sort.cpp
    R src/kernel/Support.cpp
    R src/kernel/Translate.cpp
    M test/unit/CMakeLists.txt
  Log Message:
  Port ALL kernels
  Commit: 83b3d914f55940a28710e49313cec502091a20bf
      https://github.com/PDAL/PDAL/commit/83b3d914f55940a28710e49313cec502091a20bf
  Changed paths:
    M CMakeLists.txt
  Log Message:
  remove extraneous clearing of PDAL_TARGET_OBJECTS
  Commit: 2ac26c08e495052a3107bf4fa40fe466b88f98d5
      https://github.com/PDAL/PDAL/commit/2ac26c08e495052a3107bf4fa40fe466b88f98d5
  Changed paths:
    M kernels/translate/TranslateKernel.cpp
  Log Message:
  missed rename of Support to KernelSupport
  Commit: e3bb026419a248c18d57747994f39abbde5c294e
      https://github.com/PDAL/PDAL/commit/e3bb026419a248c18d57747994f39abbde5c294e
  Changed paths:
    M cmake/pdal_targets.cmake
    M kernels/CMakeLists.txt
  Log Message:
  remove cruft, fPIC seems to be required for Kernel common object library
  Commit: eba599d16238104d7585add155ea517f90275a2d
      https://github.com/PDAL/PDAL/commit/eba599d16238104d7585add155ea517f90275a2d
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-12-03 (Wed, 03 Dec 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
  Log Message:
  Merge pull request #636 from PDAL/move-kernels
Move kernels
Compare: https://github.com/PDAL/PDAL/compare/0c945da112d4...eba599d16238
More information about the pdal-commits mailing list
