[pdal-commits] [PDAL/PDAL] 30d03f: cleanups related to #637
GitHub
noreply at github.com
Wed Dec 3 15:52:05 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 30d03fef88850add653d0886bd0d375c007be003
https://github.com/PDAL/PDAL/commit/30d03fef88850add653d0886bd0d375c007be003
Author: Howard Butler <howard at hobu.co>
Date: 2014-12-03 (Wed, 03 Dec 2014)
Changed paths:
M plugins/oci/test/OCITest.cpp
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
Log Message:
Commit: feb61fa61ffc1abac8435e719432b90cc6747e75
https://github.com/PDAL/PDAL/commit/feb61fa61ffc1abac8435e719432b90cc6747e75
Changed paths:
M filters/chipper/ChipperFilter.cpp
M filters/chipper/ChipperFilter.hpp
M filters/colorization/ColorizationFilter.hpp
M include/pdal/FileUtils.hpp
M include/pdal/KDIndex.hpp
M include/pdal/PipelineReader.hpp
M include/pdal/Stage.hpp
M include/pdal/StreamFactory.hpp
M include/pdal/Utils.hpp
M include/pdal/filters/Stats.hpp
M include/pdal/pdal_internal.hpp
M include/pdal/plang/Invocation.hpp
M io/bpf/BpfReader.cpp
M io/faux/FauxReader.cpp
M io/las/LasReader.cpp
M io/las/LasWriter.hpp
M io/terrasolid/TerrasolidReader.cpp
M io/text/TextWriter.cpp
M kernels/Application.hpp
M kernels/Kernel.cpp
M kernels/Kernel.hpp
M kernels/delta/DeltaKernel.cpp
M kernels/delta/DeltaKernel.hpp
M kernels/diff/DiffKernel.cpp
M kernels/info/InfoKernel.cpp
M kernels/info/InfoKernel.hpp
M kernels/random/RandomKernel.cpp
M kernels/random/RandomKernel.hpp
M kernels/sort/SortKernel.cpp
M kernels/translate/TranslateKernel.cpp
M plugins/icebridge/io/Hdf5Handler.cpp
M plugins/icebridge/io/Hdf5Handler.hpp
M plugins/mrsid/io/MrsidReader.cpp
M plugins/mrsid/io/MrsidReader.hpp
M plugins/nitf/io/NitfFile.cpp
M plugins/nitf/io/NitfFile.hpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/nitf/test/NitfWriterTest.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
M plugins/p2g/io/P2gWriter.cpp
M plugins/p2g/io/P2gWriter.hpp
M plugins/pcl/io/point_types.hpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/ViewKernel.cpp
M plugins/pgpointcloud/io/PgWriter.cpp
M plugins/pgpointcloud/io/PgWriter.hpp
M plugins/rxp/io/RxpReader.cpp
M plugins/rxp/test/RxpReaderTest.cpp
M plugins/sqlite/io/SQLiteWriter.hpp
M plugins/sqlite/test/SQLiteTest.cpp
M scripts/ci/script.sh
M src/FileUtils.cpp
M src/KDIndex.cpp
M src/PipelineReader.cpp
M src/Stage.cpp
M src/StageInfo.cpp
M src/StreamFactory.cpp
M src/Utils.cpp
M src/XMLSchema.cpp
M src/filters/Stats.cpp
M src/pdal_config.cpp
M src/plang/Invocation.cpp
M test/unit/CompressionTest.cpp
M test/unit/ConfigTest.cpp
M test/unit/DimensionTest.cpp
M test/unit/GDALUtilsTest.cpp
M test/unit/LogTest.cpp
M test/unit/OptionsTest.cpp
M test/unit/PointBufferTest.cpp
M test/unit/SchemaTest.cpp
M test/unit/StageFactoryTest.cpp
M test/unit/StreamFactoryTest.cpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/SupportTest.cpp
M test/unit/UtilsTest.cpp
M test/unit/XMLSchemaTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/io/las/LasReaderTest.cpp
M test/unit/io/las/LasWriterTest.cpp
M test/unit/io/terrasolid/TerraSolidReaderTest.cpp
M test/unit/io/text/TextWriterTest.cpp
M test/unit/plang/PLangTest.cpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Compare: https://github.com/PDAL/PDAL/compare/6e5c5f4d8706...feb61fa61ffc
More information about the pdal-commits
