[pdal-commits] [PDAL/PDAL] e4517d: Convert unit tests from Boost Test to Google Test
GitHub
noreply at github.com
Tue Dec 9 19:25:26 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: e4517d8a83587990cf0623614bf2bc0206183653
https://github.com/PDAL/PDAL/commit/e4517d8a83587990cf0623614bf2bc0206183653
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-12-09 (Tue, 09 Dec 2014)
Changed paths:
M CMakeLists.txt
M cmake/pdal_targets.cmake
M doc/development/testing.rst
M include/pdal/Utils.hpp
M plugins/hexbin/test/HexbinFilterTest.cpp
M plugins/icebridge/test/IcebridgeReaderTest.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/nitf/test/NitfWriterTest.cpp
M plugins/oci/CMakeLists.txt
M plugins/oci/test/OCITest.cpp
M plugins/pcl/test/PCLBlockFilterTest.cpp
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
M plugins/rxp/test/RxpReaderTest.cpp
M plugins/sqlite/test/SQLiteTest.cpp
M test/unit/BoundsTest.cpp
M test/unit/CMakeLists.txt
M test/unit/CompressionTest.cpp
M test/unit/ConfigTest.cpp
M test/unit/EnvironmentTest.cpp
M test/unit/FileUtilsTest.cpp
M test/unit/GDALUtilsTest.cpp
M test/unit/LogTest.cpp
M test/unit/MetadataTest.cpp
M test/unit/OptionsTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/PointBufferTest.cpp
M test/unit/PointContextTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/StreamFactoryTest.cpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/SupportTest.cpp
M test/unit/TestConfig.cpp
M test/unit/TestConfig.hpp.in
R test/unit/UnitTest.hpp
M test/unit/UserCallbackTest.cpp
M test/unit/UtilsTest.cpp
M test/unit/XMLSchemaTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/ColorizationFilterTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/MergeTest.cpp
M test/unit/filters/ReprojectionFilterTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/filters/SplitterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/io/bpf/BPFTest.cpp
M test/unit/io/buffer/BufferTest.cpp
M test/unit/io/faux/FauxReaderTest.cpp
M test/unit/io/las/LasReaderTest.cpp
M test/unit/io/las/LasWriterTest.cpp
M test/unit/io/qfit/QFITReaderTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
M test/unit/io/sbet/SbetWriterTest.cpp
M test/unit/plang/PLangTest.cpp
M test/unit/plang/PredicateFilterTest.cpp
M test/unit/plang/ProgrammableFilterTest.cpp
A vendor/gtest-1.7.0/CHANGES
A vendor/gtest-1.7.0/CMakeLists.txt
A vendor/gtest-1.7.0/CONTRIBUTORS
A vendor/gtest-1.7.0/LICENSE
A vendor/gtest-1.7.0/Makefile.am
A vendor/gtest-1.7.0/Makefile.in
A vendor/gtest-1.7.0/README
A vendor/gtest-1.7.0/aclocal.m4
A vendor/gtest-1.7.0/build-aux/config.guess
A vendor/gtest-1.7.0/build-aux/config.h.in
A vendor/gtest-1.7.0/build-aux/config.sub
A vendor/gtest-1.7.0/build-aux/depcomp
A vendor/gtest-1.7.0/build-aux/install-sh
A vendor/gtest-1.7.0/build-aux/ltmain.sh
A vendor/gtest-1.7.0/build-aux/missing
A vendor/gtest-1.7.0/cmake/internal_utils.cmake
A vendor/gtest-1.7.0/codegear/gtest.cbproj
A vendor/gtest-1.7.0/codegear/gtest.groupproj
A vendor/gtest-1.7.0/codegear/gtest_all.cc
A vendor/gtest-1.7.0/codegear/gtest_link.cc
A vendor/gtest-1.7.0/codegear/gtest_main.cbproj
A vendor/gtest-1.7.0/codegear/gtest_unittest.cbproj
A vendor/gtest-1.7.0/configure
A vendor/gtest-1.7.0/configure.ac
A vendor/gtest-1.7.0/fused-src/gtest/gtest-all.cc
A vendor/gtest-1.7.0/fused-src/gtest/gtest.h
A vendor/gtest-1.7.0/fused-src/gtest/gtest_main.cc
A vendor/gtest-1.7.0/include/gtest/gtest-death-test.h
A vendor/gtest-1.7.0/include/gtest/gtest-message.h
A vendor/gtest-1.7.0/include/gtest/gtest-param-test.h
A vendor/gtest-1.7.0/include/gtest/gtest-param-test.h.pump
A vendor/gtest-1.7.0/include/gtest/gtest-printers.h
A vendor/gtest-1.7.0/include/gtest/gtest-spi.h
A vendor/gtest-1.7.0/include/gtest/gtest-test-part.h
A vendor/gtest-1.7.0/include/gtest/gtest-typed-test.h
A vendor/gtest-1.7.0/include/gtest/gtest.h
A vendor/gtest-1.7.0/include/gtest/gtest_pred_impl.h
A vendor/gtest-1.7.0/include/gtest/gtest_prod.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-death-test-internal.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-filepath.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-internal.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-linked_ptr.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util-generated.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util-generated.h.pump
A vendor/gtest-1.7.0/include/gtest/internal/gtest-param-util.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-port.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-string.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-tuple.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-tuple.h.pump
A vendor/gtest-1.7.0/include/gtest/internal/gtest-type-util.h
A vendor/gtest-1.7.0/include/gtest/internal/gtest-type-util.h.pump
A vendor/gtest-1.7.0/m4/acx_pthread.m4
A vendor/gtest-1.7.0/m4/gtest.m4
A vendor/gtest-1.7.0/m4/libtool.m4
A vendor/gtest-1.7.0/m4/ltoptions.m4
A vendor/gtest-1.7.0/m4/ltsugar.m4
A vendor/gtest-1.7.0/m4/ltversion.m4
A vendor/gtest-1.7.0/m4/lt~obsolete.m4
A vendor/gtest-1.7.0/msvc/gtest-md.vcproj
A vendor/gtest-1.7.0/msvc/gtest.vcproj
A vendor/gtest-1.7.0/msvc/gtest_main-md.vcproj
A vendor/gtest-1.7.0/msvc/gtest_main.vcproj
A vendor/gtest-1.7.0/msvc/gtest_prod_test-md.vcproj
A vendor/gtest-1.7.0/msvc/gtest_prod_test.vcproj
A vendor/gtest-1.7.0/msvc/gtest_unittest-md.vcproj
A vendor/gtest-1.7.0/msvc/gtest_unittest.vcproj
A vendor/gtest-1.7.0/samples/prime_tables.h
A vendor/gtest-1.7.0/samples/sample1.cc
A vendor/gtest-1.7.0/samples/sample1.h
A vendor/gtest-1.7.0/samples/sample10_unittest.cc
A vendor/gtest-1.7.0/samples/sample1_unittest.cc
A vendor/gtest-1.7.0/samples/sample2.cc
A vendor/gtest-1.7.0/samples/sample2.h
A vendor/gtest-1.7.0/samples/sample2_unittest.cc
A vendor/gtest-1.7.0/samples/sample3-inl.h
A vendor/gtest-1.7.0/samples/sample3_unittest.cc
A vendor/gtest-1.7.0/samples/sample4.cc
A vendor/gtest-1.7.0/samples/sample4.h
A vendor/gtest-1.7.0/samples/sample4_unittest.cc
A vendor/gtest-1.7.0/samples/sample5_unittest.cc
A vendor/gtest-1.7.0/samples/sample6_unittest.cc
A vendor/gtest-1.7.0/samples/sample7_unittest.cc
A vendor/gtest-1.7.0/samples/sample8_unittest.cc
A vendor/gtest-1.7.0/samples/sample9_unittest.cc
A vendor/gtest-1.7.0/scripts/fuse_gtest_files.py
A vendor/gtest-1.7.0/scripts/gen_gtest_pred_impl.py
A vendor/gtest-1.7.0/scripts/gtest-config.in
A vendor/gtest-1.7.0/scripts/pump.py
A vendor/gtest-1.7.0/src/gtest-all.cc
A vendor/gtest-1.7.0/src/gtest-death-test.cc
A vendor/gtest-1.7.0/src/gtest-filepath.cc
A vendor/gtest-1.7.0/src/gtest-internal-inl.h
A vendor/gtest-1.7.0/src/gtest-port.cc
A vendor/gtest-1.7.0/src/gtest-printers.cc
A vendor/gtest-1.7.0/src/gtest-test-part.cc
A vendor/gtest-1.7.0/src/gtest-typed-test.cc
A vendor/gtest-1.7.0/src/gtest.cc
A vendor/gtest-1.7.0/src/gtest_main.cc
A vendor/gtest-1.7.0/test/gtest-death-test_ex_test.cc
A vendor/gtest-1.7.0/test/gtest-death-test_test.cc
A vendor/gtest-1.7.0/test/gtest-filepath_test.cc
A vendor/gtest-1.7.0/test/gtest-linked_ptr_test.cc
A vendor/gtest-1.7.0/test/gtest-listener_test.cc
A vendor/gtest-1.7.0/test/gtest-message_test.cc
A vendor/gtest-1.7.0/test/gtest-options_test.cc
A vendor/gtest-1.7.0/test/gtest-param-test2_test.cc
A vendor/gtest-1.7.0/test/gtest-param-test_test.cc
A vendor/gtest-1.7.0/test/gtest-param-test_test.h
A vendor/gtest-1.7.0/test/gtest-port_test.cc
A vendor/gtest-1.7.0/test/gtest-printers_test.cc
A vendor/gtest-1.7.0/test/gtest-test-part_test.cc
A vendor/gtest-1.7.0/test/gtest-tuple_test.cc
A vendor/gtest-1.7.0/test/gtest-typed-test2_test.cc
A vendor/gtest-1.7.0/test/gtest-typed-test_test.cc
A vendor/gtest-1.7.0/test/gtest-typed-test_test.h
A vendor/gtest-1.7.0/test/gtest-unittest-api_test.cc
A vendor/gtest-1.7.0/test/gtest_all_test.cc
A vendor/gtest-1.7.0/test/gtest_break_on_failure_unittest.py
A vendor/gtest-1.7.0/test/gtest_break_on_failure_unittest_.cc
A vendor/gtest-1.7.0/test/gtest_catch_exceptions_test.py
A vendor/gtest-1.7.0/test/gtest_catch_exceptions_test_.cc
A vendor/gtest-1.7.0/test/gtest_color_test.py
A vendor/gtest-1.7.0/test/gtest_color_test_.cc
A vendor/gtest-1.7.0/test/gtest_env_var_test.py
A vendor/gtest-1.7.0/test/gtest_env_var_test_.cc
A vendor/gtest-1.7.0/test/gtest_environment_test.cc
A vendor/gtest-1.7.0/test/gtest_filter_unittest.py
A vendor/gtest-1.7.0/test/gtest_filter_unittest_.cc
A vendor/gtest-1.7.0/test/gtest_help_test.py
A vendor/gtest-1.7.0/test/gtest_help_test_.cc
A vendor/gtest-1.7.0/test/gtest_list_tests_unittest.py
A vendor/gtest-1.7.0/test/gtest_list_tests_unittest_.cc
A vendor/gtest-1.7.0/test/gtest_main_unittest.cc
A vendor/gtest-1.7.0/test/gtest_no_test_unittest.cc
A vendor/gtest-1.7.0/test/gtest_output_test.py
A vendor/gtest-1.7.0/test/gtest_output_test_.cc
A vendor/gtest-1.7.0/test/gtest_output_test_golden_lin.txt
A vendor/gtest-1.7.0/test/gtest_pred_impl_unittest.cc
A vendor/gtest-1.7.0/test/gtest_premature_exit_test.cc
A vendor/gtest-1.7.0/test/gtest_prod_test.cc
A vendor/gtest-1.7.0/test/gtest_repeat_test.cc
A vendor/gtest-1.7.0/test/gtest_shuffle_test.py
A vendor/gtest-1.7.0/test/gtest_shuffle_test_.cc
A vendor/gtest-1.7.0/test/gtest_sole_header_test.cc
A vendor/gtest-1.7.0/test/gtest_stress_test.cc
A vendor/gtest-1.7.0/test/gtest_test_utils.py
A vendor/gtest-1.7.0/test/gtest_throw_on_failure_ex_test.cc
A vendor/gtest-1.7.0/test/gtest_throw_on_failure_test.py
A vendor/gtest-1.7.0/test/gtest_throw_on_failure_test_.cc
A vendor/gtest-1.7.0/test/gtest_uninitialized_test.py
A vendor/gtest-1.7.0/test/gtest_uninitialized_test_.cc
A vendor/gtest-1.7.0/test/gtest_unittest.cc
A vendor/gtest-1.7.0/test/gtest_xml_outfile1_test_.cc
A vendor/gtest-1.7.0/test/gtest_xml_outfile2_test_.cc
A vendor/gtest-1.7.0/test/gtest_xml_outfiles_test.py
A vendor/gtest-1.7.0/test/gtest_xml_output_unittest.py
A vendor/gtest-1.7.0/test/gtest_xml_output_unittest_.cc
A vendor/gtest-1.7.0/test/gtest_xml_test_utils.py
A vendor/gtest-1.7.0/test/production.cc
A vendor/gtest-1.7.0/test/production.h
A vendor/gtest-1.7.0/xcode/Config/DebugProject.xcconfig
A vendor/gtest-1.7.0/xcode/Config/FrameworkTarget.xcconfig
A vendor/gtest-1.7.0/xcode/Config/General.xcconfig
A vendor/gtest-1.7.0/xcode/Config/ReleaseProject.xcconfig
A vendor/gtest-1.7.0/xcode/Config/StaticLibraryTarget.xcconfig
A vendor/gtest-1.7.0/xcode/Config/TestTarget.xcconfig
A vendor/gtest-1.7.0/xcode/Resources/Info.plist
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/Info.plist
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/WidgetFramework.xcodeproj/project.pbxproj
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/runtests.sh
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget.cc
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget.h
A vendor/gtest-1.7.0/xcode/Samples/FrameworkSample/widget_test.cc
A vendor/gtest-1.7.0/xcode/Scripts/runtests.sh
A vendor/gtest-1.7.0/xcode/Scripts/versiongenerate.py
A vendor/gtest-1.7.0/xcode/gtest.xcodeproj/project.pbxproj
Log Message:
Commit: 6f69572ced2dec897d4222b89d1c5acba007a346
https://github.com/PDAL/PDAL/commit/6f69572ced2dec897d4222b89d1c5acba007a346
Changed paths:
M CMakeLists.txt
Log Message:
update tests to address warnings, most of which were signed/unsigned or int/float comparisons
Commit: e1fdf423f4f5827784e914e51196cda245da88be
https://github.com/PDAL/PDAL/commit/e1fdf423f4f5827784e914e51196cda245da88be
Changed paths:
Log Message:
malformed test in GDALUtilsTest
Commit: b3f684fcc12d54973145a13eb6e0a9a928854933
https://github.com/PDAL/PDAL/commit/b3f684fcc12d54973145a13eb6e0a9a928854933
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
gtest unsigned comparison cleanups
Commit: 672e119c75e2a4c79cd927bacddce29124cf34d1
https://github.com/PDAL/PDAL/commit/672e119c75e2a4c79cd927bacddce29124cf34d1
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #644 from PDAL/convert-boost-test-to-google-test
Compare: https://github.com/PDAL/PDAL/compare/2c827f90a9ce...672e119c75e2
More information about the pdal-commits
