[pdal-commits] [PDAL/PDAL] f55780: Clean up tests that invoked deprecated filters
GitHub
noreply at github.com
Tue Dec 23 12:08:38 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: f55780539be72997c9929c21076fcabbcc9b577f
https://github.com/PDAL/PDAL/commit/f55780539be72997c9929c21076fcabbcc9b577f
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-12-18 (Thu, 18 Dec 2014)
Changed paths:
M test/data/drivers/text-writer-geojson.xml
M test/data/drivers/text-writer-space-delimited.xml
M test/data/filters/chip.xml
M test/data/filters/colorize-multi.xml
M test/data/filters/crop_reproject.xml
M test/data/filters/decimate.xml
M test/data/filters/reproject.xml
M test/data/oracle/big-read.xml
M test/data/oracle/big-write.xml
M test/data/oracle/qfit-write.xml
M test/data/oracle/read.xml
M test/data/oracle/view-read.xml
M test/data/oracle/write.xml
M test/data/pipeline/drop_color.xml
M test/data/pipeline/pipeline_interpolate.xml
M test/data/pipeline/pipeline_mississippi.xml
M test/data/pipeline/pipeline_mississippi_reverse.xml
M test/data/pipeline/pipeline_write2.xml
M test/data/soci/sthelens-write.xml
M test/data/soci/write-utm.xml
M test/data/soci/write.xml
M test/perf/chipper.xml
Log Message:
Commit: 2aacd644ff32ca544dab0de5de4cb97f255a6bda
https://github.com/PDAL/PDAL/commit/2aacd644ff32ca544dab0de5de4cb97f255a6bda
Date: 2014-12-22 (Mon, 22 Dec 2014)
Changed paths:
M CMakeLists.txt
M plugins/nitf/test/NitfReaderTest.cpp
R test/data/bpf/bpf.xml
A test/data/bpf/bpf.xml.in
R test/data/bpf/bpf2nitf.xml
A test/data/bpf/bpf2nitf.xml.in
R test/data/drivers/p2g-writer.xml
R test/data/drivers/sqlite-reader.xml
R test/data/drivers/sqlite-writer.xml
R test/data/drivers/text-writer-csv.xml
R test/data/drivers/text-writer-geojson.xml
R test/data/drivers/text-writer-space-delimited.xml
R test/data/filters/attribute.xml
A test/data/filters/attribute.xml.in
R test/data/filters/chip.xml
A test/data/filters/chip.xml.in
R test/data/filters/chipper.xml
A test/data/filters/chipper.xml.in
R test/data/filters/colorize-multi.xml
A test/data/filters/colorize-multi.xml.in
R test/data/filters/colorize.xml
A test/data/filters/colorize.xml.in
R test/data/filters/crop_reproject.xml
A test/data/filters/crop_reproject.xml.in
R test/data/filters/crop_wkt.xml
A test/data/filters/crop_wkt.xml.in
R test/data/filters/crop_wkt_2d.xml
A test/data/filters/crop_wkt_2d.xml.in
R test/data/filters/crop_wkt_2d_classification.xml
A test/data/filters/crop_wkt_2d_classification.xml.in
R test/data/filters/decimate.xml
A test/data/filters/decimate.xml.in
R test/data/filters/ferry.xml
A test/data/filters/ferry.xml.in
R test/data/filters/hexbin-info.xml
A test/data/filters/hexbin-info.xml.in
R test/data/filters/hexbin.xml
A test/data/filters/hexbin.xml.in
R test/data/filters/index.xml
R test/data/filters/merge.xml
A test/data/filters/merge.xml.in
R test/data/filters/reproject.xml
A test/data/filters/reproject.xml.in
R test/data/filters/scaling.xml
R test/data/filters/selector.xml
R test/data/filters/sort.xml
A test/data/filters/sort.xml.in
R test/data/filters/splitter.xml
A test/data/filters/splitter.xml.in
R test/data/filters/stats.xml
A test/data/filters/stats.xml.in
R test/data/hole/crop.xml
A test/data/hole/crop.xml.in
R test/data/icebridge/pipeline.xml
A test/data/icebridge/pipeline.xml.in
A test/data/io/p2g-writer.xml.in
A test/data/io/sqlite-reader.xml.in
A test/data/io/sqlite-writer.xml.in
A test/data/io/text-writer-csv.xml.in
A test/data/io/text-writer-geojson.xml.in
A test/data/io/text-writer-space-delimited.xml.in
R test/data/nitf/chipper.xml
A test/data/nitf/chipper.xml.in
R test/data/nitf/conversion.xml
A test/data/nitf/conversion.xml.in
R test/data/nitf/las2nitf.xml
A test/data/nitf/las2nitf.xml.in
R test/data/nitf/write_laz.xml
A test/data/nitf/write_laz.xml.in
R test/data/nitf/write_options.xml
A test/data/nitf/write_options.xml.in
R test/data/pipeline/drop_color.xml
A test/data/pipeline/drop_color.xml.in
R test/data/pipeline/pipeline_interpolate.xml
A test/data/pipeline/pipeline_interpolate.xml.in
R test/data/pipeline/pipeline_metadata_reader.xml
A test/data/pipeline/pipeline_metadata_reader.xml.in
R test/data/pipeline/pipeline_metadata_writer.xml
A test/data/pipeline/pipeline_metadata_writer.xml.in
R test/data/pipeline/pipeline_mississippi.xml
A test/data/pipeline/pipeline_mississippi.xml.in
R test/data/pipeline/pipeline_mississippi_reverse.xml
A test/data/pipeline/pipeline_mississippi_reverse.xml.in
R test/data/pipeline/pipeline_multioptions.xml
A test/data/pipeline/pipeline_multioptions.xml.in
R test/data/pipeline/pipeline_read.xml
A test/data/pipeline/pipeline_read.xml.in
R test/data/pipeline/pipeline_read_notype.xml
A test/data/pipeline/pipeline_read_notype.xml.in
R test/data/pipeline/pipeline_readcomments.xml
A test/data/pipeline/pipeline_readcomments.xml.in
R test/data/pipeline/pipeline_write.xml
A test/data/pipeline/pipeline_write.xml.in
R test/data/pipeline/pipeline_write2.xml
A test/data/pipeline/pipeline_write2.xml.in
R test/data/pipeline/pipeline_writecomments.xml
A test/data/pipeline/pipeline_writecomments.xml.in
R test/data/plang/from-module.xml
A test/data/plang/from-module.xml.in
R test/data/plang/predicate-embed.xml
A test/data/plang/predicate-embed.xml.in
R test/data/plang/predicate-keep-ground-and-unclass.xml
A test/data/plang/predicate-keep-ground-and-unclass.xml.in
R test/data/plang/predicate-keep-last-return.xml
A test/data/plang/predicate-keep-last-return.xml.in
R test/data/plang/predicate-keep-specified-returns.xml
A test/data/plang/predicate-keep-specified-returns.xml.in
R test/data/plang/programmable-update-y-dims.xml
A test/data/plang/programmable-update-y-dims.xml.in
R test/data/qfit/conversion.xml
A test/data/qfit/conversion.xml.in
R test/data/qfit/little-endian-conversion.xml
A test/data/qfit/little-endian-conversion.xml.in
R test/data/qfit/pipeline.xml
A test/data/qfit/pipeline.xml.in
R test/data/qfit/reader.xml
A test/data/qfit/reader.xml.in
R test/data/sbet/pipeline.xml
A test/data/sbet/pipeline.xml.in
M test/perf/chipper_nocache.xml
M test/unit/CMakeLists.txt
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/TestConfig.cpp
M test/unit/TestConfig.hpp.in
M test/unit/apps/pcpipelineTest.cpp
M test/unit/filters/MergeTest.cpp
Log Message:
configure tests to more reliably locate test data, beef up pcpipelineTest to test the sample pipelines
Commit: fa9ceb4b030de2e2920052c879210c509d843eb3
https://github.com/PDAL/PDAL/commit/fa9ceb4b030de2e2920052c879210c509d843eb3
Changed paths:
M plugins/python/test/PredicateFilterTest.cpp
M plugins/python/test/ProgrammableFilterTest.cpp
M test/data/bpf/bpf.xml.in
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/io/sbet/SbetReaderTest.cpp
Log Message:
tidying up, fixing paths to XMLs in the unit tests
Commit: 5cda1d270d73d106aa4005858522e4d4e79c88fd
https://github.com/PDAL/PDAL/commit/5cda1d270d73d106aa4005858522e4d4e79c88fd
Changed paths:
M plugins/icebridge/test/IcebridgeReaderTest.cpp
M test/data/plang/from-module.xml.in
Log Message:
fix two more paths to configured pipelines
Commit: 5ad5cd11254093fbea7fc8244e8604350cc7b5d6
https://github.com/PDAL/PDAL/commit/5ad5cd11254093fbea7fc8244e8604350cc7b5d6
Author: Howard Butler <howard at hobu.co>
Date: 2014-12-23 (Tue, 23 Dec 2014)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #670 from PDAL/update-tests-using-deprecated-filters
Sample pipeline udpates, added tests
Compare: https://github.com/PDAL/PDAL/compare/ac0cfd827ae6...5ad5cd112540
More information about the pdal-commits
