[pdal-commits] [PDAL/PDAL] 46886d: whitespace normalization
GitHub
noreply at github.com
Sat Feb 8 19:28:06 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 46886d67882aa926d4114edfe06f62a2f5c1fe2c
https://github.com/PDAL/PDAL/commit/46886d67882aa926d4114edfe06f62a2f5c1fe2c
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-01-14 (Tue, 14 Jan 2014)
Changed paths:
M src/PointBuffer.cpp
Log Message:
Commit: dafb8cb3d2c8a9593829f7ee31e989ede2dd3aae
https://github.com/PDAL/PDAL/commit/dafb8cb3d2c8a9593829f7ee31e989ede2dd3aae
Changed paths:
M include/pdal/Schema.hpp
M src/Schema.cpp
Log Message:
implement pdal::Schema::toRST() to output the Schema object as reStructuredText
Commit: 1cd942da46e70a07f51d50c6bf1fdcbdbe8df13b
https://github.com/PDAL/PDAL/commit/1cd942da46e70a07f51d50c6bf1fdcbdbe8df13b
Changed paths:
M include/pdal/kernel/Info.hpp
M src/kernel/Info.cpp
Log Message:
use Schema::toRST to output the --schema information
Commit: 09329b4d7a4d3ed38058d3ba0aa92af9ae80947f
https://github.com/PDAL/PDAL/commit/09329b4d7a4d3ed38058d3ba0aa92af9ae80947f
Changed paths:
M src/Schema.cpp
Log Message:
::toRST() tweaks
Commit: 35ec3f79c57841dd5d8ed66c521ff6eddd69dd35
https://github.com/PDAL/PDAL/commit/35ec3f79c57841dd5d8ed66c521ff6eddd69dd35
Changed paths:
M test/data/apps/pdalinfo_schema.txt
Log Message:
update testoutput
Commit: 503c55be618b8952baa7acfea3bb8b68a4a46713
https://github.com/PDAL/PDAL/commit/503c55be618b8952baa7acfea3bb8b68a4a46713
Date: 2014-01-20 (Mon, 20 Jan 2014)
Changed paths:
M doc/Makefile
M doc/tutorial/writing.txt
M src/drivers/las/Writer.cpp
M src/drivers/pgpointcloud/Reader.cpp
M test/unit/DimensionTest.cpp
Log Message:
Merge branch 'master' into issues/227-rest-for-pdal-schema-metadata
Commit: 15aa3a44fb198176e788a02a2c9f14e059ad618d
https://github.com/PDAL/PDAL/commit/15aa3a44fb198176e788a02a2c9f14e059ad618d
Date: 2014-01-27 (Mon, 27 Jan 2014)
Changed paths:
M CMakeLists.txt
M apps/CMakeLists.txt
A cmake/pdal_options.cmake
A cmake/pdal_targets.cmake
M cmake/pdal_utils.cmake
M doc/Makefile
M doc/stages/filters.programmable.txt
M include/pdal/Dimension.hpp
A include/pdal/Drivers.hpp
A include/pdal/Filters.hpp
A include/pdal/Kernel.hpp
M include/pdal/PointBuffer.hpp
M include/pdal/drivers/pgpointcloud/Reader.hpp
M include/pdal/drivers/pgpointcloud/Writer.hpp
M include/pdal/drivers/sqlite/common.hpp
M include/pdal/filters/Scaling.hpp
M include/pdal/kernel/Query.hpp
A include/pdal/pdal.hpp
M src/CMakeLists.txt
M src/Schema.cpp
M src/StageFactory.cpp
M src/drivers/oci/Reader.cpp
M src/drivers/pgpointcloud/Writer.cpp
M test/unit/CMakeLists.txt
M test/unit/PointBufferTest.cpp
Log Message:
Commit: b889382078151c2ae73e80c9607c55f3b973ae05
https://github.com/PDAL/PDAL/commit/b889382078151c2ae73e80c9607c55f3b973ae05
Date: 2014-01-28 (Tue, 28 Jan 2014)
Changed paths:
M apps/pdal-config.in
A apps/pdal.pc.in
Log Message:
Commit: b97a8331a7957d6b25e841d2656d7f1b14b20ffe
https://github.com/PDAL/PDAL/commit/b97a8331a7957d6b25e841d2656d7f1b14b20ffe
Changed paths:
A test/data/hole/autzen-dd.las
A test/data/hole/crop.xml
A test/data/hole/hole.dbf
A test/data/hole/hole.las
A test/data/hole/hole.prj
A test/data/hole/hole.qpj
A test/data/hole/hole.shp
A test/data/hole/hole.shx
A test/data/hole/make-spurious.py
A test/data/hole/spurious.las
Log Message:
add crop and hole example
Commit: 10f546383b7975ac2ede910bad840b15ad3e8bfb
https://github.com/PDAL/PDAL/commit/10f546383b7975ac2ede910bad840b15ad3e8bfb
Date: 2014-02-08 (Sat, 08 Feb 2014)
Changed paths:
M CMakeLists.txt
M cmake/pdal_options.cmake
M hobu-config.sh
M include/pdal/drivers/mrsid/Reader.hpp
M include/pdal/filters/Chipper.hpp
M include/pdal/third/nanoflann.hpp
M python/CMakeLists.txt
R python/libpc.i
A python/pdal.i
M src/drivers/mrsid/Reader.cpp
M src/filters/Chipper.cpp
A test/data/autzen-utm-chipped-25.las
A test/data/filters/chip.xml
M test/unit/drivers/oci/OCITest.cpp
M test/unit/filters/ChipperTest.cpp
Log Message:
Commit: caed243686aec55643222cefceb2a32ec19617f8
https://github.com/PDAL/PDAL/commit/caed243686aec55643222cefceb2a32ec19617f8
Changed paths:
M cmake/modules/FindHexer.cmake
Log Message:
update hexer detection code
Commit: 86ae677d453e722d8e98d3de0ebec5a995f810c2
https://github.com/PDAL/PDAL/commit/86ae677d453e722d8e98d3de0ebec5a995f810c2
Changed paths:
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/90531416c50c...86ae677d453e
More information about the pdal-commits
