[pdal-commits] [PDAL/PDAL] ade409: move the PCL Block XML files to the filter folder, ...
GitHub
noreply at github.com
Fri Feb 21 13:50:52 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: ade40980e5394a8502651df5a8f93ecb292415c4
https://github.com/PDAL/PDAL/commit/ade40980e5394a8502651df5a8f93ecb292415c4
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-02-21 (Fri, 21 Feb 2014)
Changed paths:
A test/data/filters/pcl/grid_minimum.json
A test/data/filters/pcl/outlier_removal.json
A test/data/filters/pcl/passthrough.json
A test/data/filters/pcl/passthrough_outlier_removal.json
A test/data/filters/pcl/progressive_morphological_filter.json
A test/data/filters/pcl_grid_minimum.xml
A test/data/filters/pcl_outlier_removal.xml
A test/data/filters/pcl_passthrough.xml
A test/data/filters/pcl_passthrough_outlier_removal.xml
A test/data/filters/pcl_progressive_morphological_filter.xml
R test/data/pipeline/outlier_removal.json
R test/data/pipeline/passthrough.json
R test/data/pipeline/passthrough_outlier_removal.json
R test/data/pipeline/pipeline_pclblock.xml
R test/data/pipeline/pipeline_pclblock_combined.xml
R test/data/pipeline/pipeline_pclblock_outlier_removal.xml
R test/data/pipeline/pipeline_pclblock_passthrough.xml
R test/data/pipeline/pipeline_pclblock_progressive_morphological_filter.xml
R test/data/pipeline/pipeline_pclblock_voxel_grid.xml
R test/data/pipeline/pipeline_pclblock_voxel_grid_minimum.xml
R test/data/pipeline/progressive_morphological_filter.json
R test/data/pipeline/voxel_grid.json
R test/data/pipeline/voxel_grid_minimum.json
M test/unit/filters/PCLBlockFilterTest.cpp
Log Message:
move the PCL Block XML files to the filter folder, create subfolder for the JSON files, remove some deprecated PCL Block examples
More information about the pdal-commits
