[pdal-commits] [PDAL/PDAL] fcc59a: remove unnecessary includes
GitHub
noreply at github.com
Sun Jan 26 09:26:36 PST 2014
Branch: refs/heads/issues/228-common-include
Home: https://github.com/PDAL/PDAL
Commit: fcc59a7ec4005761c3124cb53b5ac22ce7758a8d
https://github.com/PDAL/PDAL/commit/fcc59a7ec4005761c3124cb53b5ac22ce7758a8d
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-01-20 (Mon, 20 Jan 2014)
Changed paths:
M include/pdal/drivers/sqlite/common.hpp
Log Message:
Commit: e73e7f80f68cb42368274739676992c8c4c1e6a2
https://github.com/PDAL/PDAL/commit/e73e7f80f68cb42368274739676992c8c4c1e6a2
Changed paths:
M src/drivers/pgpointcloud/Writer.cpp
Log Message:
optimize pgpointcloud insert #229
Commit: a3568bc40416ea7e19f22ef7bf25488c84fe0f12
https://github.com/PDAL/PDAL/commit/a3568bc40416ea7e19f22ef7bf25488c84fe0f12
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Changed paths:
Log Message:
Merge pull request #229 from PDAL/issues/229-speedup-pgpointcloud
First attempt at speeding up pgpointcloud
Commit: 5b53f38f0fe8e2e2996123d1e555d622d6a3d3e3
https://github.com/PDAL/PDAL/commit/5b53f38f0fe8e2e2996123d1e555d622d6a3d3e3
Date: 2014-01-21 (Tue, 21 Jan 2014)
Changed paths:
M doc/Makefile
Log Message:
update 'make publish' target of docs
Commit: ebdc292f129f62fc64aa32751073f414094ab804
https://github.com/PDAL/PDAL/commit/ebdc292f129f62fc64aa32751073f414094ab804
Changed paths:
M include/pdal/drivers/pgpointcloud/Writer.hpp
Log Message:
cleanup #229 to output correct hex and always construct insert statement in the same string
Commit: ab6b78b78adfe610be2024eaf6cc96cb4d75a068
https://github.com/PDAL/PDAL/commit/ab6b78b78adfe610be2024eaf6cc96cb4d75a068
Date: 2014-01-23 (Thu, 23 Jan 2014)
Changed paths:
M doc/stages/filters.programmable.txt
Log Message:
Syntax error
Commit: 5a13337bc08244ec73f880ad814ad77f3bb92e9e
https://github.com/PDAL/PDAL/commit/5a13337bc08244ec73f880ad814ad77f3bb92e9e
Changed paths:
M include/pdal/PointBuffer.hpp
M src/PointBuffer.cpp
Log Message:
provide new static implementation of PointBuffer::pack that doesn't always create a new PointBuffer, use that for class method call
Commit: 1e8498744b002fc2523cef8040476a64953b6900
https://github.com/PDAL/PDAL/commit/1e8498744b002fc2523cef8040476a64953b6900
Changed paths:
Log Message:
use static PointBuffer::pack method and reuse buffer so as to not keep alloc'ing it over and over
Commit: bab25e7ecb2d71f70dcb94ced97c9d374f4197bb
https://github.com/PDAL/PDAL/commit/bab25e7ecb2d71f70dcb94ced97c9d374f4197bb
Date: 2014-01-24 (Fri, 24 Jan 2014)
Changed paths:
M include/pdal/Dimension.hpp
M include/pdal/filters/Scaling.hpp
Log Message:
output correct number in error reporting in descaling ops
Commit: c86842cd48ae9c5a44074b7d5e188f0b2cc7e770
https://github.com/PDAL/PDAL/commit/c86842cd48ae9c5a44074b7d5e188f0b2cc7e770
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M include/pdal/kernel/Query.hpp
Log Message:
add PDAL_DLL to Query and IndexedPointBuffer #230
Commit: 105d09ba1aca72b4cd3115fe942334a71cacc5b4
https://github.com/PDAL/PDAL/commit/105d09ba1aca72b4cd3115fe942334a71cacc5b4
Changed paths:
M src/CMakeLists.txt
Log Message:
only link LASzip and python when selected #231
Commit: 6ca483926138b15f396fe515fbf2c1462f25a20a
https://github.com/PDAL/PDAL/commit/6ca483926138b15f396fe515fbf2c1462f25a20a
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #232 from PDAL/issues/230-missing-export
Commit: d6a7b9de4e438f1b6b0bd8c4b7d906da3baf1c68
https://github.com/PDAL/PDAL/commit/d6a7b9de4e438f1b6b0bd8c4b7d906da3baf1c68
Changed paths:
Log Message:
Merge pull request #233 from PDAL/issues/231-conditional-linkage
Commit: 9c13e43f48acdf9932403de56a69d7a5efaed8f2
https://github.com/PDAL/PDAL/commit/9c13e43f48acdf9932403de56a69d7a5efaed8f2
Changed paths:
M CMakeLists.txt
Log Message:
make CMake aware of possible OSGeo4W64 installation path
Commit: ea22e03c2286298bc84ccf11000ce71446fa403c
https://github.com/PDAL/PDAL/commit/ea22e03c2286298bc84ccf11000ce71446fa403c
Changed paths:
Log Message:
use boost::shared_array to back PointBuffer
Commit: 15581404e1e18fa4325a4fafcbd5d51ab481f28b
https://github.com/PDAL/PDAL/commit/15581404e1e18fa4325a4fafcbd5d51ab481f28b
Changed paths:
M CMakeLists.txt
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 8d5f9c14dda9b18f2c53eaabec34e572c51c8299
https://github.com/PDAL/PDAL/commit/8d5f9c14dda9b18f2c53eaabec34e572c51c8299
Changed paths:
M CMakeLists.txt
M cmake/pdal_utils.cmake
Log Message:
build/install directories are still a bit of mess, but should be working on windows now
Commit: 68e7c9ec37c6ffbd3093976d9a6dc58e4200aaf5
https://github.com/PDAL/PDAL/commit/68e7c9ec37c6ffbd3093976d9a6dc58e4200aaf5
Author: Howard Butler <howard at hobu.co>
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #235 from PDAL/issues/234-missing-lib-directory
build/install directories are still a bit of mess, but should be working...
Commit: 51ee4137c58ffeb40496de0487cfebc32ffcc162
https://github.com/PDAL/PDAL/commit/51ee4137c58ffeb40496de0487cfebc32ffcc162
Author: Uday Verma <uday.karan at gmail.com>
Date: 2014-01-25 (Sat, 25 Jan 2014)
Changed paths:
M test/unit/PointBufferTest.cpp
Log Message:
copyLikeDimension fast paths and special cases with elaborate unit tests
Commit: 8e86f698a309c6838a23e250eedada6c345c7cf9
https://github.com/PDAL/PDAL/commit/8e86f698a309c6838a23e250eedada6c345c7cf9
Changed paths:
Log Message:
Merge remote-tracking branch 'verma/master'
Commit: e9959b563b3e4ea4f0960b862bb318a148fc75a4
https://github.com/PDAL/PDAL/commit/e9959b563b3e4ea4f0960b862bb318a148fc75a4
Changed paths:
Log Message:
Merge pull request #236 from verma/master
Commit: bf2254f6389eb81eb01f3252c3fb0941ea54262d
https://github.com/PDAL/PDAL/commit/bf2254f6389eb81eb01f3252c3fb0941ea54262d
Log Message:
Commit: 71994209a57286ef29254c7327f1b164df65fabe
https://github.com/PDAL/PDAL/commit/71994209a57286ef29254c7327f1b164df65fabe
Changed paths:
Log Message:
Get rid of std::vector in copyLikeDimenions, use a local array instead
Commit: cc9379607933e1c8f26d26237d88cda9944dee57
https://github.com/PDAL/PDAL/commit/cc9379607933e1c8f26d26237d88cda9944dee57
Date: 2014-01-26 (Sun, 26 Jan 2014)
Changed paths:
M include/pdal/Schema.hpp
M src/Schema.cpp
M src/drivers/oci/Reader.cpp
Log Message:
memoize the encoded offset vector into schema::DimensionMap so it is updated every time a pair is inserted rather than every time copyLikeDimensions is called
Commit: 1784dd099f695ff68bee17bbb84f53d03d84d7a5
https://github.com/PDAL/PDAL/commit/1784dd099f695ff68bee17bbb84f53d03d84d7a5
Changed paths:
M src/drivers/pgpointcloud/Reader.cpp
Log Message:
don't do as much work when copying hex data from pg
Commit: 21f75927903970ca221f88082680fac6c7adcb5f
https://github.com/PDAL/PDAL/commit/21f75927903970ca221f88082680fac6c7adcb5f
Changed paths:
M CMakeLists.txt
M doc/Makefile
M src/Schema.cpp
Log Message:
Merge branch 'master' into issues/228-common-include
Compare: https://github.com/PDAL/PDAL/compare/c5e1579ed529...21f759279039
More information about the pdal-commits
