[pdal-commits] [PDAL/PDAL] 616c78: related to #234 and #235, CMake "improvements"
GitHub
noreply at github.com
Mon Jan 27 10:35:26 PST 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 616c7858dbfc1e354395380d50033eaa9f775b88
https://github.com/PDAL/PDAL/commit/616c7858dbfc1e354395380d50033eaa9f775b88
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-01-27 (Mon, 27 Jan 2014)
Changed paths:
M CMakeLists.txt
M apps/CMakeLists.txt
A cmake/pdal_options.cmake
A cmake/pdal_targets.cmake
M cmake/pdal_utils.cmake
M src/CMakeLists.txt
M test/unit/CMakeLists.txt
Log Message:
- moved some options (e.g., PDAL_BUILD_STATIC) to pdal_options.cmake
- created (really borrowed from PCL) macros for adding libraries and
executables: PDAL_ADD_LIBRARY, PDAL_ADD_EXECUTABLE
- library linkage (i.e., PUBLIC/PRIVATE) determined at the top level
in pdal_options.cmake
- embedded boost lib name does not need quotes, in fact, we lose the
correct path on Windows if they're there
- install commands (mostly) moved inside the PDAL_ADD_* macros
Commit: c9052de97b57e5ef03646b41746c5349e095cf72
https://github.com/PDAL/PDAL/commit/c9052de97b57e5ef03646b41746c5349e095cf72
Changed paths:
Log Message:
tests don't fail locally, perhaps this has something to do with the unit
tests being installed, or linked with boost libraries multiple times,
let's try without the macro
Commit: b3474b9e842e22ce625b8ac4326ae61632ead639
https://github.com/PDAL/PDAL/commit/b3474b9e842e22ce625b8ac4326ae61632ead639
Changed paths:
M cmake/pdal_options.cmake
Log Message:
if (NOT PDAL_BUILD_STATIC) seemed a little confusing; also seeing if the boost linkage is the problem with the build
Commit: 8fb52738ba9af52320e879af66077fd117d6a431
https://github.com/PDAL/PDAL/commit/8fb52738ba9af52320e879af66077fd117d6a431
Changed paths:
Log Message:
linking PDAL_UTILITY against Boost appears to have been the source of all the havoc
Commit: e4b8f212b44546d62a08f9b5a60366c146382bae
https://github.com/PDAL/PDAL/commit/e4b8f212b44546d62a08f9b5a60366c146382bae
Author: Howard Butler <howard at hobu.co>
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #237 from PDAL/tweaking-cmake-files
proposed CMake modifications
Compare: https://github.com/PDAL/PDAL/compare/1a37e0a3377e...e4b8f212b445
More information about the pdal-commits
