[pdal-commits] [PDAL/PDAL] c5e157: start on a common #include <pdal/pdal.hpp> for ext...
    GitHub
    noreply at github.com
    Tue Jan 28 08:22:23 PST 2014
  Branch: refs/heads/issues/227-rest-for-pdal-schema-metadata
  Home:   https://github.com/PDAL/PDAL
  Commit: c5e1579ed5294109cd72f2c08263a09e4499e295
      https://github.com/PDAL/PDAL/commit/c5e1579ed5294109cd72f2c08263a09e4499e295
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2014-01-20 (Mon, 20 Jan 2014)
  Changed paths:
    A include/pdal/Drivers.hpp
    A include/pdal/Filters.hpp
    A include/pdal/Kernel.hpp
    A include/pdal/pdal.hpp
    M src/CMakeLists.txt
    M src/StageFactory.cpp
  Log Message:
  start on a common #include <pdal/pdal.hpp> for external  usage #228
  Commit: fcc59a7ec4005761c3124cb53b5ac22ce7758a8d
      https://github.com/PDAL/PDAL/commit/fcc59a7ec4005761c3124cb53b5ac22ce7758a8d
  Changed paths:
    M include/pdal/drivers/sqlite/common.hpp
  Log Message:
  remove unnecessary includes
  Commit: e73e7f80f68cb42368274739676992c8c4c1e6a2
      https://github.com/PDAL/PDAL/commit/e73e7f80f68cb42368274739676992c8c4c1e6a2
  Changed paths:
    M src/drivers/pgpointcloud/Writer.cpp
  Log Message:
  optimize pgpointcloud insert #229
  Commit: a3568bc40416ea7e19f22ef7bf25488c84fe0f12
      https://github.com/PDAL/PDAL/commit/a3568bc40416ea7e19f22ef7bf25488c84fe0f12
  Author: Paul Ramsey <pramsey at cleverelephant.ca>
  Changed paths:
  Log Message:
  Merge pull request #229 from PDAL/issues/229-speedup-pgpointcloud
First attempt at speeding up pgpointcloud
  Commit: 5b53f38f0fe8e2e2996123d1e555d622d6a3d3e3
      https://github.com/PDAL/PDAL/commit/5b53f38f0fe8e2e2996123d1e555d622d6a3d3e3
  Date:   2014-01-21 (Tue, 21 Jan 2014)
  Changed paths:
    M doc/Makefile
  Log Message:
  update 'make publish' target of docs
  Commit: ebdc292f129f62fc64aa32751073f414094ab804
      https://github.com/PDAL/PDAL/commit/ebdc292f129f62fc64aa32751073f414094ab804
  Changed paths:
    M include/pdal/drivers/pgpointcloud/Writer.hpp
  Log Message:
  cleanup #229 to output correct hex and always construct insert statement in the same string
  Commit: ab6b78b78adfe610be2024eaf6cc96cb4d75a068
      https://github.com/PDAL/PDAL/commit/ab6b78b78adfe610be2024eaf6cc96cb4d75a068
  Date:   2014-01-23 (Thu, 23 Jan 2014)
  Changed paths:
    M doc/stages/filters.programmable.txt
  Log Message:
  Syntax error
  Commit: 5a13337bc08244ec73f880ad814ad77f3bb92e9e
      https://github.com/PDAL/PDAL/commit/5a13337bc08244ec73f880ad814ad77f3bb92e9e
  Changed paths:
    M include/pdal/PointBuffer.hpp
    M src/PointBuffer.cpp
  Log Message:
  provide new static implementation of PointBuffer::pack that doesn't always create a new PointBuffer, use that for class method call
  Commit: 1e8498744b002fc2523cef8040476a64953b6900
      https://github.com/PDAL/PDAL/commit/1e8498744b002fc2523cef8040476a64953b6900
  Changed paths:
  Log Message:
  use static PointBuffer::pack method and reuse buffer so as to not keep alloc'ing it over and over
  Commit: bab25e7ecb2d71f70dcb94ced97c9d374f4197bb
      https://github.com/PDAL/PDAL/commit/bab25e7ecb2d71f70dcb94ced97c9d374f4197bb
  Date:   2014-01-24 (Fri, 24 Jan 2014)
  Changed paths:
    M include/pdal/Dimension.hpp
    M include/pdal/filters/Scaling.hpp
  Log Message:
  output correct number in error reporting in descaling ops
  Commit: c86842cd48ae9c5a44074b7d5e188f0b2cc7e770
      https://github.com/PDAL/PDAL/commit/c86842cd48ae9c5a44074b7d5e188f0b2cc7e770
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M include/pdal/kernel/Query.hpp
  Log Message:
  add PDAL_DLL to Query and IndexedPointBuffer #230
  Commit: 105d09ba1aca72b4cd3115fe942334a71cacc5b4
      https://github.com/PDAL/PDAL/commit/105d09ba1aca72b4cd3115fe942334a71cacc5b4
  Changed paths:
  Log Message:
  only link LASzip and python when selected #231
  Commit: 6ca483926138b15f396fe515fbf2c1462f25a20a
      https://github.com/PDAL/PDAL/commit/6ca483926138b15f396fe515fbf2c1462f25a20a
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #232 from PDAL/issues/230-missing-export
  Commit: d6a7b9de4e438f1b6b0bd8c4b7d906da3baf1c68
      https://github.com/PDAL/PDAL/commit/d6a7b9de4e438f1b6b0bd8c4b7d906da3baf1c68
  Changed paths:
  Log Message:
  Merge pull request #233 from PDAL/issues/231-conditional-linkage
  Commit: 9c13e43f48acdf9932403de56a69d7a5efaed8f2
      https://github.com/PDAL/PDAL/commit/9c13e43f48acdf9932403de56a69d7a5efaed8f2
  Changed paths:
    M CMakeLists.txt
  Log Message:
  make CMake aware of possible OSGeo4W64 installation path
  Commit: ea22e03c2286298bc84ccf11000ce71446fa403c
      https://github.com/PDAL/PDAL/commit/ea22e03c2286298bc84ccf11000ce71446fa403c
  Changed paths:
  Log Message:
  use boost::shared_array to back PointBuffer
  Commit: 15581404e1e18fa4325a4fafcbd5d51ab481f28b
      https://github.com/PDAL/PDAL/commit/15581404e1e18fa4325a4fafcbd5d51ab481f28b
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 8d5f9c14dda9b18f2c53eaabec34e572c51c8299
      https://github.com/PDAL/PDAL/commit/8d5f9c14dda9b18f2c53eaabec34e572c51c8299
  Changed paths:
    M CMakeLists.txt
    M cmake/pdal_utils.cmake
  Log Message:
  build/install directories are still a bit of mess, but should be working on windows now
  Commit: 68e7c9ec37c6ffbd3093976d9a6dc58e4200aaf5
      https://github.com/PDAL/PDAL/commit/68e7c9ec37c6ffbd3093976d9a6dc58e4200aaf5
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #235 from PDAL/issues/234-missing-lib-directory
build/install directories are still a bit of mess, but should be working...
  Commit: 51ee4137c58ffeb40496de0487cfebc32ffcc162
      https://github.com/PDAL/PDAL/commit/51ee4137c58ffeb40496de0487cfebc32ffcc162
  Author: Uday Verma <uday.karan at gmail.com>
  Date:   2014-01-25 (Sat, 25 Jan 2014)
  Changed paths:
    M test/unit/PointBufferTest.cpp
  Log Message:
  copyLikeDimension fast paths and special cases with elaborate unit tests
  Commit: 8e86f698a309c6838a23e250eedada6c345c7cf9
      https://github.com/PDAL/PDAL/commit/8e86f698a309c6838a23e250eedada6c345c7cf9
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'verma/master'
  Commit: e9959b563b3e4ea4f0960b862bb318a148fc75a4
      https://github.com/PDAL/PDAL/commit/e9959b563b3e4ea4f0960b862bb318a148fc75a4
  Changed paths:
  Log Message:
  Merge pull request #236 from verma/master
  Commit: bf2254f6389eb81eb01f3252c3fb0941ea54262d
      https://github.com/PDAL/PDAL/commit/bf2254f6389eb81eb01f3252c3fb0941ea54262d
  Log Message:
  Commit: 71994209a57286ef29254c7327f1b164df65fabe
      https://github.com/PDAL/PDAL/commit/71994209a57286ef29254c7327f1b164df65fabe
  Changed paths:
  Log Message:
  Get rid of std::vector in copyLikeDimenions, use a local array instead
  Commit: cc9379607933e1c8f26d26237d88cda9944dee57
      https://github.com/PDAL/PDAL/commit/cc9379607933e1c8f26d26237d88cda9944dee57
  Date:   2014-01-26 (Sun, 26 Jan 2014)
  Changed paths:
    M include/pdal/Schema.hpp
    M src/Schema.cpp
    M src/drivers/oci/Reader.cpp
  Log Message:
  memoize the encoded offset vector into schema::DimensionMap so it is updated every time a pair is inserted rather than every time copyLikeDimensions is called
  Commit: 1784dd099f695ff68bee17bbb84f53d03d84d7a5
      https://github.com/PDAL/PDAL/commit/1784dd099f695ff68bee17bbb84f53d03d84d7a5
  Changed paths:
    M src/drivers/pgpointcloud/Reader.cpp
  Log Message:
  don't do as much work when copying hex data from pg
  Commit: 21f75927903970ca221f88082680fac6c7adcb5f
      https://github.com/PDAL/PDAL/commit/21f75927903970ca221f88082680fac6c7adcb5f
  Changed paths:
    M CMakeLists.txt
    M doc/Makefile
    M src/Schema.cpp
  Log Message:
  Merge branch 'master' into issues/228-common-include
  Commit: 62ed48701cdbdd0ea94a05135a90b6a026181e37
      https://github.com/PDAL/PDAL/commit/62ed48701cdbdd0ea94a05135a90b6a026181e37
  Changed paths:
  Log Message:
  fix up vector resize() to 0 so that we can push_back the new bytes as we decode them
  Commit: 1a37e0a3377e786ca6cac502f94da02289ad21a8
      https://github.com/PDAL/PDAL/commit/1a37e0a3377e786ca6cac502f94da02289ad21a8
  Changed paths:
    M include/pdal/drivers/pgpointcloud/Reader.hpp
  Log Message:
  don't alloc a new std::string copy of the patch's hex data
  Commit: 616c7858dbfc1e354395380d50033eaa9f775b88
      https://github.com/PDAL/PDAL/commit/616c7858dbfc1e354395380d50033eaa9f775b88
  Date:   2014-01-27 (Mon, 27 Jan 2014)
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    A cmake/pdal_options.cmake
    A cmake/pdal_targets.cmake
    M test/unit/CMakeLists.txt
  Log Message:
  related to #234 and #235, CMake "improvements"
  - moved some options (e.g., PDAL_BUILD_STATIC) to pdal_options.cmake
  - created (really borrowed from PCL) macros for adding libraries and
    executables: PDAL_ADD_LIBRARY, PDAL_ADD_EXECUTABLE
  - library linkage (i.e., PUBLIC/PRIVATE) determined at the top level
    in pdal_options.cmake
  - embedded boost lib name does not need quotes, in fact, we lose the
    correct path on Windows if they're there
  - install commands (mostly) moved inside the PDAL_ADD_* macros
  Commit: c9052de97b57e5ef03646b41746c5349e095cf72
      https://github.com/PDAL/PDAL/commit/c9052de97b57e5ef03646b41746c5349e095cf72
  Changed paths:
  Log Message:
  tests don't fail locally, perhaps this has something to do with the unit
tests being installed, or linked with boost libraries multiple times,
let's try without the macro
  Commit: b3474b9e842e22ce625b8ac4326ae61632ead639
      https://github.com/PDAL/PDAL/commit/b3474b9e842e22ce625b8ac4326ae61632ead639
  Changed paths:
    M cmake/pdal_options.cmake
  Log Message:
  if (NOT PDAL_BUILD_STATIC) seemed a little confusing; also seeing if the boost linkage is the problem with the build
  Commit: 8fb52738ba9af52320e879af66077fd117d6a431
      https://github.com/PDAL/PDAL/commit/8fb52738ba9af52320e879af66077fd117d6a431
  Changed paths:
  Log Message:
  linking PDAL_UTILITY against Boost appears to have been the source of all the havoc
  Commit: e4b8f212b44546d62a08f9b5a60366c146382bae
      https://github.com/PDAL/PDAL/commit/e4b8f212b44546d62a08f9b5a60366c146382bae
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #237 from PDAL/tweaking-cmake-files
proposed CMake modifications
  Commit: c3062b510cfda722557b19934f0f8548914351ef
      https://github.com/PDAL/PDAL/commit/c3062b510cfda722557b19934f0f8548914351ef
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Commit: c0f498b5b0395c1a53ff807dc3e59eba2f1a3b59
      https://github.com/PDAL/PDAL/commit/c0f498b5b0395c1a53ff807dc3e59eba2f1a3b59
  Changed paths:
    M doc/tutorial/writing.txt
    M include/pdal/pdal.hpp
  Log Message:
  only include base stuff in <pdal/pdal.hpp>, not Drivers, Filters, and Kernel, which a user can include separately as needed
  Commit: a807a4224c4d998941bf971d98732afe1628455c
      https://github.com/PDAL/PDAL/commit/a807a4224c4d998941bf971d98732afe1628455c
  Changed paths:
  Log Message:
  Merge pull request #228 from PDAL/issues/228-common-include
common include file for PDAL
  Commit: 15aa3a44fb198176e788a02a2c9f14e059ad618d
      https://github.com/PDAL/PDAL/commit/15aa3a44fb198176e788a02a2c9f14e059ad618d
  Changed paths:
    M CMakeLists.txt
    M doc/Makefile
    M src/Schema.cpp
  Log Message:
  Merge branch 'master' into issues/227-rest-for-pdal-schema-metadata
  Commit: bd6bcb3e8229ff3e32a6395bd9ceaf6a8cf4377f
      https://github.com/PDAL/PDAL/commit/bd6bcb3e8229ff3e32a6395bd9ceaf6a8cf4377f
  Changed paths:
    M apps/pdal-config.in
    A apps/pdal.pc.in
  Log Message:
  a passable pgk-config for PDAL #238
  Commit: 32030e41f64f26adada24393ef7a6b719808b2fd
      https://github.com/PDAL/PDAL/commit/32030e41f64f26adada24393ef7a6b719808b2fd
  Date:   2014-01-28 (Tue, 28 Jan 2014)
  Changed paths:
    A apps/pdal.pc.in
  Log Message:
  Merge pull request #238 from PDAL/issues/238-pkg-config-for-pdal
pkg-config configuration for PDAL
  Commit: b889382078151c2ae73e80c9607c55f3b973ae05
      https://github.com/PDAL/PDAL/commit/b889382078151c2ae73e80c9607c55f3b973ae05
  Changed paths:
    A apps/pdal.pc.in
  Log Message:
Compare: https://github.com/PDAL/PDAL/compare/503c55be618b...b88938207815
More information about the pdal-commits
