[pdal-commits] [PDAL/PDAL] a9fcb5: don't chop off classification bits #403
GitHub
noreply at github.com
Mon Jul 14 14:01:25 PDT 2014
Branch: refs/heads/greyhound
Home: https://github.com/PDAL/PDAL
Commit: a9fcb5ad1317ffd8d3937821f38adfe33b2552ac
https://github.com/PDAL/PDAL/commit/a9fcb5ad1317ffd8d3937821f38adfe33b2552ac
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-07-02 (Wed, 02 Jul 2014)
Changed paths:
M src/drivers/las/Reader.cpp
Log Message:
Commit: 41fa0c9daf54ada36d2b1e7228d466a3061350a7
https://github.com/PDAL/PDAL/commit/41fa0c9daf54ada36d2b1e7228d466a3061350a7
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2014-07-07 (Mon, 07 Jul 2014)
Changed paths:
A include/pdal/KDIndex.hpp
M include/pdal/PointBuffer.hpp
M include/pdal/Writer.hpp
M include/pdal/drivers/sqlite/Reader.hpp
M include/pdal/filters/Mosaic.hpp
M include/pdal/kernel/Delta.hpp
M include/pdal/kernel/Diff.hpp
M include/pdal/kernel/Info.hpp
M include/pdal/kernel/Pipeline.hpp
M src/CMakeLists.txt
A src/KDIndex.cpp
M src/PointBuffer.cpp
M src/Writer.cpp
M src/drivers/icebridge/Reader.cpp
M src/drivers/p2g/Writer.cpp
M src/drivers/pgpointcloud/Reader.cpp
M src/drivers/pgpointcloud/Writer.cpp
M src/drivers/qfit/Reader.cpp
M src/drivers/sqlite/Reader.cpp
M src/drivers/sqlite/Writer.cpp
M src/drivers/terrasolid/Reader.cpp
M src/drivers/text/Writer.cpp
M src/filters/Color.cpp
M src/filters/HexBin.cpp
M src/filters/Mosaic.cpp
M src/kernel/Delta.cpp
M src/kernel/Diff.cpp
M src/kernel/Info.cpp
M src/kernel/PCL.cpp
M src/kernel/Pipeline.cpp
M src/kernel/Translate.cpp
M src/plang/BufferedInvocation.cpp
M test/unit/Support.cpp
M test/unit/Support.hpp
M test/unit/drivers/oci/OCITest.cpp
Log Message:
Purge old copying code from PointBuffer. Remove depedent calls().
Commit: 1dcdffff981541add1002f82186f690318dad9e4
https://github.com/PDAL/PDAL/commit/1dcdffff981541add1002f82186f690318dad9e4
Changed paths:
M include/pdal/Metadata.hpp
M include/pdal/PointContext.hpp
M include/pdal/SpatialReference.hpp
M include/pdal/Stage.hpp
M include/pdal/UserCallback.hpp
M include/pdal/filters/Stats.hpp
M include/pdal/kernel/Support.hpp
M include/pdal/kernel/Translate.hpp
M src/SpatialReference.cpp
M src/Stage.cpp
R src/UserCallback.cpp
M src/drivers/caris/CloudReader.cpp
M src/drivers/las/Writer.cpp
M src/drivers/oci/Writer.cpp
M src/drivers/sbet/Writer.cpp
M src/filters/InPlaceReprojection.cpp
M src/filters/Reprojection.cpp
M src/filters/Stats.cpp
M src/kernel/Support.cpp
M test/unit/CMakeLists.txt
M test/unit/StageTester.hpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/InPlaceReprojectionFilterTest.cpp
M test/unit/filters/ReprojectionFilterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
Merge branch 'point-context' of https://github.com/PDAL/PDAL into point-context
Conflicts:
src/Writer.cpp
Commit: 246743a892ac3c1fc7d5d0de555e3506ae82d5c3
https://github.com/PDAL/PDAL/commit/246743a892ac3c1fc7d5d0de555e3506ae82d5c3
Changed paths:
M include/pdal/drivers/qfit/Reader.hpp
M include/pdal/drivers/terrasolid/Reader.hpp
M src/Stage.cpp
M src/drivers/las/LasHeaderReader.cpp
M src/drivers/las/LasHeaderReader.hpp
Log Message:
Remove schema from stage.
Commit: bee756c65fb9c644b082f8ee0d2007b25b720fed
https://github.com/PDAL/PDAL/commit/bee756c65fb9c644b082f8ee0d2007b25b720fed
Date: 2014-07-08 (Tue, 08 Jul 2014)
Changed paths:
M include/pdal/filters/HexBin.hpp
M test/unit/filters/HexbinFilterTest.cpp
Log Message:
HexBin to point context.
Commit: 0fe3d7ed1e22806775f966cec5df945d2a9099b0
https://github.com/PDAL/PDAL/commit/0fe3d7ed1e22806775f966cec5df945d2a9099b0
Changed paths:
A src/KDIndex.cpp
M src/Stage.cpp
M src/Writer.cpp
Log Message:
Conflicts:
Commit: 8edb00486ae54af079be84f24b9d34835f7ae33b
https://github.com/PDAL/PDAL/commit/8edb00486ae54af079be84f24b9d34835f7ae33b
Changed paths:
Log Message:
Add configuration ifdef guard.
Commit: 5910da9b5186f159ce0be93f31cd0ed65f3fa706
https://github.com/PDAL/PDAL/commit/5910da9b5186f159ce0be93f31cd0ed65f3fa706
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2014-07-09 (Wed, 09 Jul 2014)
Changed paths:
M doc/stages/filters.pclblock.txt
M doc/tutorial/pcl_block_tutorial.txt
Log Message:
update the pcl documentation to include ground filtering example and explanation of parameters
Commit: b730b806d9d57e7c81b4aa42cc12cb1f3458b9fb
https://github.com/PDAL/PDAL/commit/b730b806d9d57e7c81b4aa42cc12cb1f3458b9fb
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #404 from chambbj/pcl-doc-update
Commit: f3a044c7acbdd5c6f050fec3589c9c622ccff2bd
https://github.com/PDAL/PDAL/commit/f3a044c7acbdd5c6f050fec3589c9c622ccff2bd
Changed paths:
M src/StageFactory.cpp
M test/data/apps/pdalinfo_stats.txt
M test/unit/apps/pcinfoTest.cpp
Log Message:
Fix pipeline files as input to pdal info.
Fix stats output for pdal info.
Fix point listing output for pdal info.
Commit: 120074f3c4bc1b9eda7be7fd9f2a5f2f5c265f4a
https://github.com/PDAL/PDAL/commit/120074f3c4bc1b9eda7be7fd9f2a5f2f5c265f4a
Changed paths:
M cmake/examples/hobu-config.sh
Log Message:
tweak my cmake example
Commit: 4901ba9fcc806d4908ce91df8575ec70c78e87f0
https://github.com/PDAL/PDAL/commit/4901ba9fcc806d4908ce91df8575ec70c78e87f0
Changed paths:
M include/pdal/drivers/pgpointcloud/Writer.hpp
Log Message:
port drivers.pgpointcloud.writer to point-context
Commit: ae944a90d1177ef6bf7c5aca7b34a46f127c33dd
https://github.com/PDAL/PDAL/commit/ae944a90d1177ef6bf7c5aca7b34a46f127c33dd
Changed paths:
Log Message:
Merge branch 'point-context' of github.com:PDAL/PDAL into point-context
Commit: a609f0e349e78d32a2a871536b0abf2bdaba10d4
https://github.com/PDAL/PDAL/commit/a609f0e349e78d32a2a871536b0abf2bdaba10d4
Date: 2014-07-10 (Thu, 10 Jul 2014)
Changed paths:
A test/data/filters/hexbin.txt
A test/data/hextest.las
A test/data/hextest.txt
R test/data/log_py.txt
R test/data/text.txt
Log Message:
Make a simple hexbin test.
Commit: 4cb05405ecc5ba14fd69d28e92fdd4b57684901e
https://github.com/PDAL/PDAL/commit/4cb05405ecc5ba14fd69d28e92fdd4b57684901e
Changed paths:
Log Message:
Commit: 4cafd8f6d4a0972821372ce4f5509ca6897d763a
https://github.com/PDAL/PDAL/commit/4cafd8f6d4a0972821372ce4f5509ca6897d763a
Changed paths:
Log Message:
Merge branch 'master' of https://github.com/PDAL/PDAL into point-context
Conflicts:
Commit: f3941874c16c9f43e35c1a79f2e3f9269e9d5661
https://github.com/PDAL/PDAL/commit/f3941874c16c9f43e35c1a79f2e3f9269e9d5661
Changed paths:
M test/data/filters/hexbin.txt
Log Message:
Add hexbin output file with consistent origin.
Commit: 8e538bcee3575177aa5538f44fa945041275ddda
https://github.com/PDAL/PDAL/commit/8e538bcee3575177aa5538f44fa945041275ddda
Date: 2014-07-11 (Fri, 11 Jul 2014)
Changed paths:
Log Message:
Fix build with no hexer.
Commit: a3693132160b32eb0973672a7fb192abae7299c6
https://github.com/PDAL/PDAL/commit/a3693132160b32eb0973672a7fb192abae7299c6
Changed paths:
M include/pdal/drivers/sqlite/Writer.hpp
M test/unit/drivers/sqlite/Writer.cpp
Log Message:
port drivers.sqlite.writer to point-context -- not really tested yet because OSX sucks
Commit: ceaddac47fa68e16d46f27b5b8375bef44cbb36f
https://github.com/PDAL/PDAL/commit/ceaddac47fa68e16d46f27b5b8375bef44cbb36f
Changed paths:
M src/Stage.cpp
Log Message:
Remove dead code.
Commit: d8ca77944063c9a0aed7f6438fc10b5b17189592
https://github.com/PDAL/PDAL/commit/d8ca77944063c9a0aed7f6438fc10b5b17189592
Changed paths:
M include/pdal/drivers/las/Reader.hpp
M src/Stage.cpp
Log Message:
Remove more dead code.
Commit: f2b47982161d7efacb781266be7a82e7860c8784
https://github.com/PDAL/PDAL/commit/f2b47982161d7efacb781266be7a82e7860c8784
Changed paths:
Log Message:
Commit: 7332ec2c8cfec9e6366068832605e0235f0f5918
https://github.com/PDAL/PDAL/commit/7332ec2c8cfec9e6366068832605e0235f0f5918
Changed paths:
M include/pdal/Dimension.hpp
M include/pdal/pdal_types.hpp
M src/Dimension.cpp
M src/Schema.cpp
M src/Stage.cpp
M src/XMLSchema.cpp
M src/drivers/bpf/BpfReader.cpp
Log Message:
Commit: 46969c4d1b493c6c4d0f655cb2f830dcecc67f27
https://github.com/PDAL/PDAL/commit/46969c4d1b493c6c4d0f655cb2f830dcecc67f27
Date: 2014-07-14 (Mon, 14 Jul 2014)
Changed paths:
M include/pdal/drivers/faux/Reader.hpp
M src/drivers/faux/Reader.cpp
M src/filters/Programmable.cpp
A test/data/log_py.txt
M test/data/logtest_123.txt
A test/data/text.txt
M test/unit/DimensionTest.cpp
M test/unit/FileUtilsTest.cpp
M test/unit/LogTest.cpp
R test/unit/PointBufferCacheTest.cpp
R test/unit/drivers/buffer/BufferReaderTest.cpp
R test/unit/drivers/faux/FauxWriterTest.cpp
R test/unit/drivers/pipeline/PipelineReaderTest.cpp
R test/unit/drivers/pipeline/PipelineWriterTest.cpp
Log Message:
Fix some tests.
Commit: f7e22c617999df09c740f26b390376fbd7e8b67e
https://github.com/PDAL/PDAL/commit/f7e22c617999df09c740f26b390376fbd7e8b67e
Author: Connor Manning <connor at hobu.co>
Changed paths:
M include/pdal/RawPtBuf.hpp
M include/pdal/drivers/greyhound/Reader.hpp
M src/drivers/greyhound/Reader.cpp
Log Message:
Change GH reader to use setField since the remote schema is not necessarily the same as the final local schema.
Commit: 0c142529bf1c2c249c9784f791e59b8e7e52d5be
https://github.com/PDAL/PDAL/commit/0c142529bf1c2c249c9784f791e59b8e7e52d5be
Changed paths:
M src/Dimension.cpp
A src/KDIndex.cpp
M src/Schema.cpp
M src/Stage.cpp
M src/Writer.cpp
M src/XMLSchema.cpp
M test/data/log_py.txt
M test/data/text.txt
Log Message:
Merge point-context updates into Greyhound branch.
Compare: https://github.com/PDAL/PDAL/compare/fc27b0c435a2...0c142529bf1c
More information about the pdal-commits
