[pdal-commits] [PDAL/PDAL] 488cef: drivers.sqlite.writer based on sqlite3 C API. remo...
GitHub
noreply at github.com
Sun Jul 27 10:21:14 PDT 2014
Branch: refs/heads/point-context
Home: https://github.com/PDAL/PDAL
Commit: 488cefb9a503a047b87048b7dae5a59723d9c338
https://github.com/PDAL/PDAL/commit/488cefb9a503a047b87048b7dae5a59723d9c338
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-07-24 (Thu, 24 Jul 2014)
Changed paths:
M CMakeLists.txt
M include/pdal/drivers/sqlite/Reader.hpp
M include/pdal/drivers/sqlite/Writer.hpp
M include/pdal/drivers/sqlite/common.hpp
M pdal_defines.h.in
M src/CMakeLists.txt
M src/drivers/sqlite/Reader.cpp
M src/drivers/sqlite/Writer.cpp
M test/unit/drivers/sqlite/Writer.cpp
Log Message:
drivers.sqlite.writer based on sqlite3 C API. remove SOCI dependency
Commit: a5738e5490e9240cc836d5a9b1e2927f1022c5f2
https://github.com/PDAL/PDAL/commit/a5738e5490e9240cc836d5a9b1e2927f1022c5f2
Changed paths:
M include/pdal/Drivers.hpp
R include/pdal/drivers/sqlite/Reader.hpp
A include/pdal/drivers/sqlite/SQLiteCommon.hpp
A include/pdal/drivers/sqlite/SQLiteReader.hpp
A include/pdal/drivers/sqlite/SQLiteWriter.hpp
R include/pdal/drivers/sqlite/Writer.hpp
R include/pdal/drivers/sqlite/common.hpp
M src/StageFactory.cpp
R src/drivers/sqlite/Reader.cpp
A src/drivers/sqlite/SQLiteReader.cpp
A src/drivers/sqlite/SQLiteWriter.cpp
R src/drivers/sqlite/Writer.cpp
M test/unit/CMakeLists.txt
A test/unit/drivers/sqlite/SQLiteWriterTest.cpp
R test/unit/drivers/sqlite/Writer.cpp
Log Message:
rename drivers.sqlite to SQLiteWriter/SQLiteReader
Commit: 304ac6a6797a1080e2ef6fe7a130d3ec4dba2c85
https://github.com/PDAL/PDAL/commit/304ac6a6797a1080e2ef6fe7a130d3ec4dba2c85
Changed paths:
Log Message:
add sqlite to StageFactory
Commit: 0e5392fc675cb48b8ee6a6ed24c6096b187c7f2d
https://github.com/PDAL/PDAL/commit/0e5392fc675cb48b8ee6a6ed24c6096b187c7f2d
Changed paths:
M include/pdal/drivers/sqlite/SQLiteCommon.hpp
M src/drivers/sqlite/SQLiteWriter.cpp
Log Message:
fix ups for drivers.sqlite.writer to actually work
Commit: 177af28755efdc9b4ed176d092cba342ddbec342
https://github.com/PDAL/PDAL/commit/177af28755efdc9b4ed176d092cba342ddbec342
Changed paths:
Log Message:
handle situation where a query doesn't return any rows. insert schema correctly into cloud table
Commit: 1197542dd452878a6939ca19d839a2f1ac8869f2
https://github.com/PDAL/PDAL/commit/1197542dd452878a6939ca19d839a2f1ac8869f2
Date: 2014-07-25 (Fri, 25 Jul 2014)
Changed paths:
A include/pdal/drivers/sqlite/SQLiteIterator.hpp
M include/pdal/drivers/sqlite/SQLiteReader.hpp
A src/drivers/sqlite/SQLiteIterator.cpp
M src/drivers/sqlite/SQLiteReader.cpp
Log Message:
almost working drivers.sqlite.reader
Commit: f38a71a7a9ab0e89ad866a2be8268f9485090081
https://github.com/PDAL/PDAL/commit/f38a71a7a9ab0e89ad866a2be8268f9485090081
Changed paths:
Log Message:
put some more logging in, shutdown/initialize for sqlite3
Commit: 465481f593f1c9a0618025485e6b69fae6f258d6
https://github.com/PDAL/PDAL/commit/465481f593f1c9a0618025485e6b69fae6f258d6
Date: 2014-07-27 (Sun, 27 Jul 2014)
Changed paths:
M include/pdal/PointBuffer.hpp
Log Message:
ask ABELL about what happens when appendPoint is given bad input
Commit: ebaab646b015d22cf55d47d6ef0e3949282a45dd
https://github.com/PDAL/PDAL/commit/ebaab646b015d22cf55d47d6ef0e3949282a45dd
Changed paths:
Log Message:
some cleanups, more logs
Commit: d9ce4f818c7f6c7899b05af365d31e45ff6e3097
https://github.com/PDAL/PDAL/commit/d9ce4f818c7f6c7899b05af365d31e45ff6e3097
Changed paths:
M include/pdal/drivers/sqlite/SQLiteIterator.hpp
M src/drivers/sqlite/SQLiteIterator.cpp
Log Message:
more drivers.sqlite.reader -- still not quite working
Commit: 018cee1cbdb1d204c5adf7ff4f57cb441d2632a5
https://github.com/PDAL/PDAL/commit/018cee1cbdb1d204c5adf7ff4f57cb441d2632a5
Changed paths:
A test/data/drivers/sqlite-reader.xml
A test/data/drivers/sqlite-writer.xml
A test/unit/drivers/sqlite/SQLiteTest.cpp
R test/unit/drivers/sqlite/SQLiteWriterTest.cpp
Log Message:
working drivers.sqlite.reader with tests
Commit: 1c04ea598044817e8195d8f04273e354f17623cd
https://github.com/PDAL/PDAL/commit/1c04ea598044817e8195d8f04273e354f17623cd
Changed paths:
Log Message:
turn off sqlite3_enable_load_extension which isn't quite working yet
Compare: https://github.com/PDAL/PDAL/compare/d29b4b49e285...1c04ea598044
More information about the pdal-commits
