[pdal-commits] [PDAL/PDAL] 0576b5: put the dimensions under a 'schema' object so the ...
GitHub noreply at github.com
Mon Jun 16 12:30:25 PDT 2014
  Branch: refs/heads/point-context
  Home:   https://github.com/PDAL/PDAL
  Commit: 0576b587d2608bfa9441276826fdf622cba4f9ea
      https://github.com/PDAL/PDAL/commit/0576b587d2608bfa9441276826fdf622cba4f9ea
  Author: Howard Butler <hobu.inc at gmail.com>
  Date:   2014-06-16 (Mon, 16 Jun 2014)
  Changed paths:
    M src/kernel/Info.cpp
  Log Message:
  put the dimensions under a 'schema' object so the xml that --schema outputs is valid
  Commit: 311c4be506a37a3f483b01405185663ac1200100
      https://github.com/PDAL/PDAL/commit/311c4be506a37a3f483b01405185663ac1200100
  Changed paths:
    M src/Dimension.cpp
  Log Message:
  put the interpretation name into the toPTree() output of pdal::Dimension
Compare: https://github.com/PDAL/PDAL/compare/2214a103fe43...311c4be506a3
More information about the pdal-commits mailing list
