[pdal-commits] [PDAL/PDAL] 760c6f: Remove returns from BOOST_AUTO_TEST_CASEs
GitHub
noreply at github.com
Thu May 1 10:49:23 PDT 2014
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 760c6f46aec8d26eff3017b13080b3943d15fe7e
https://github.com/PDAL/PDAL/commit/760c6f46aec8d26eff3017b13080b3943d15fe7e
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2014-05-01 (Thu, 01 May 2014)
Changed paths:
M test/unit/BoundsTest.cpp
M test/unit/ConfigTest.cpp
M test/unit/DimensionTest.cpp
M test/unit/EnvironmentTest.cpp
M test/unit/FileUtilsTest.cpp
M test/unit/GDALUtilsTest.cpp
M test/unit/LogTest.cpp
M test/unit/MetadataTest.cpp
M test/unit/OptionsTest.cpp
M test/unit/PipelineManagerTest.cpp
M test/unit/PointBufferCacheTest.cpp
M test/unit/PointBufferTest.cpp
M test/unit/RangeTest.cpp
M test/unit/SchemaLayoutTest.cpp
M test/unit/SchemaTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/StageFactoryTest.cpp
M test/unit/StreamFactoryTest.cpp
M test/unit/Support.cpp
M test/unit/SupportTest.cpp
M test/unit/ThreadTest.cpp
M test/unit/UserCallbackTest.cpp
M test/unit/UtilsTest.cpp
M test/unit/VectorTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/apps/pcinfoTest.cpp
M test/unit/apps/pcpipelineTest.cpp
M test/unit/drivers/buffer/BufferReaderTest.cpp
M test/unit/drivers/caris/CarisReaderTest.cpp
M test/unit/drivers/faux/FauxReaderTest.cpp
M test/unit/drivers/faux/FauxWriterTest.cpp
M test/unit/drivers/las/LasReaderTest.cpp
M test/unit/drivers/las/LasWriterTest.cpp
M test/unit/drivers/nitf/NitfReaderTest.cpp
M test/unit/drivers/nitf/NitfWriterTest.cpp
M test/unit/drivers/pipeline/PipelineReaderTest.cpp
M test/unit/drivers/pipeline/PipelineWriterTest.cpp
M test/unit/drivers/qfit/QFITReaderTest.cpp
M test/unit/drivers/sbet/SbetReaderTest.cpp
M test/unit/drivers/sqlite/Writer.cpp
M test/unit/drivers/terrasolid/TerraSolidReaderTest.cpp
M test/unit/drivers/text/TextWriterTest.cpp
M test/unit/filters/ByteSwapFilterTest.cpp
M test/unit/filters/CacheFilterTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/ColorFilterTest.cpp
M test/unit/filters/ColorizationFilterTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/HexbinFilterTest.cpp
M test/unit/filters/InPlaceReprojectionFilterTest.cpp
M test/unit/filters/MosaicFilterTest.cpp
M test/unit/filters/PCLBlockFilterTest.cpp
M test/unit/filters/ScalingFilterTest.cpp
M test/unit/filters/SelectorFilterTest.cpp
M test/unit/filters/SplitterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/plang/PLangTest.cpp
M test/unit/plang/PredicateFilterTest.cpp
M test/unit/plang/ProgrammableFilterTest.cpp
Log Message:
These returns are not needed for the tests to run properly, and their
inconsistent use could cause confusion down the road.
Fixes #337.
Commit: 6e216d464791b6b6ce09e7a1908facfabcb675af
https://github.com/PDAL/PDAL/commit/6e216d464791b6b6ce09e7a1908facfabcb675af
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #338 from gadomski/issue/337-test-case-return
Compare: https://github.com/PDAL/PDAL/compare/ffcc61c963f0...6e216d464791
More information about the pdal-commits
